brown patina on heat-treated steel
Phil Ullrich
I'm planning a blade that includes steel bolster/guard and butt cap. Considering brown patina on blade and fittings. I've browned steel with casey birch chemicals before, which involves heating the steel over 200 f and then brushing on the solution. Steel needs to be hot enough to sizzle the solution when applied, which I think is over 200f.
Would heating the blade in this fashion spoil the heat treat? At what temperature would the heat treatment be spoiled? Off the top of my head I was thinking 400+ so the browning procedure should be safe, but correct me if I am wrong, please.
I have always thought that one man of tolerable abilities may work great changes, and accomplish great affairs among mankind, if he first forms a good plan....
- Benjamin Franklin
200F is well below the temperature required to affect the temper. Depending on the steel alloy used for the blade, though, the plum brown may not work as well as you hope. The amounts of trace materials because of steel recycling has been creeping up over the years- awhile ago I had an order of 1095 from Admiral which dang near had as much nickel as L6. A few years ago a gunsmith told me that he had to hot-blue gun barrels made in the last few years nearly twice as long as ones made over 30 years ago.
Thanks for the reassurance. Interesting info about steel composition changing, too.
- Benjamin Franklin
You can also use a cold browning solution like Laurel Mountain Forge or Wahkon Bay...no heating necessary...both are sold by Track of the Wolf as well as other muzzle loading suppliers..
Chuck Burrows
Wild Rose Trading Co
chuck@wrtcleather.com
www.wrtcleather.com
What's your take on the difference in results between the cold versus hot solutions?
- Benjamin Franklin
