Buck Hedges Posted February 8, 2014 Share Posted February 8, 2014 A while back I started on a pair of mountain-man style throwing knives. They were cut from some random square tubing a friend of mine had lying around. I wasn't too concerned with the quality of the steel, since they're going to get thrown and banged up any way. I got them ground down and shaped, and cold-hammered the edges (this was before I'd built my forge). When I got my forge built, I decided to use a clay temper to harden them. (Please keep in mind I was still mostly clueless about what I was doing at this point). For clay, I used white clay that is all over my place about 2 feet under ground. I mixed up a good thick paste, and smeared it on the blades, leaving the edges bare. I think it was about 1/4 inch thick on the spines. Then I heated them orange-hot in the forge, and quenched them in water. The clay all came off, and I was left with a weird "splatter" pattern all over the blades. It's fairly deep,too. It has a texture you can feel. What is it? What caused it? And how do I avoid it on future blades that I want to look good? Truth simply is. Whether you like that truth or not is totally irrelevant. https://www.facebook.com/StormsForge">https://www.facebook.com/StormsForge Link to comment Share on other sites More sharing options...
Victor Thomopoulos Posted February 8, 2014 Share Posted February 8, 2014 (edited) looks like this: http://www.bladesmithsforum.com/index.php?showtopic=28441&hl= overheated blade maybe Edited February 8, 2014 by Viktor Thomopoulos http://gatosforge.blogspot.gr/ Link to comment Share on other sites More sharing options...
Miles Hebbard Posted February 8, 2014 Share Posted February 8, 2014 Yep! Too hot! However, it's a look that I like and try manipulate, some succesfuly some not! You can remove it with sanding, but start to use a magnate to determine correct heat, as soon as the mag won't stick to the blade, it is ready for the. Quench, a very dull red... To become old and wise... You first have to survive being young and foolish! Ikisu.blogsot.com. Email; milesikisu@gmail.com mobile: +27784653651 Link to comment Share on other sites More sharing options...
JJ Simon Posted February 8, 2014 Share Posted February 8, 2014 Yep too hot and if I understand the process correctly, if you heat treat in the dark or dim light and you can actually see whats happening in the blade, up until the point you are ready to quench you will see a flickering in the steel, this is the carbon getting ready to go into solution. Once that flickering stops then you are ready to quench. You can hold the steel at temp for a few minutes if you can. The opposite phenomenon can be seen when you normalize. When you take a blade that is in solution out of the forge and hold it in still air you will see a shadow start in the edges and move to the center and that is the carbon going form the liquid state back to a solid state in the steel. Link to comment Share on other sites More sharing options...
Miles Hebbard Posted February 8, 2014 Share Posted February 8, 2014 This was clayed the taken to orange, cooled slowly to air temp , then heated to just non magnetic and quenched, To become old and wise... You first have to survive being young and foolish! Ikisu.blogsot.com. Email; milesikisu@gmail.com mobile: +27784653651 Link to comment Share on other sites More sharing options...
Caleb Harris Posted February 8, 2014 Share Posted February 8, 2014 I get that a little bit whenever I try clawing. Nice to know from what it is due! Trying to make each knife just a little better than the last Link to comment Share on other sites More sharing options...
Geoff Keyes Posted February 8, 2014 Share Posted February 8, 2014 JFYI, when I make throwers, I don't HT treat them at all. Mostly I make them from mild steel. But even if I were to make them from 1080, I wouldn't HT them. I have seen hard blades throw chips when striking another blade, and If you got enough torque on a bad throw, you could break a blade, So from a safety point of view, I leave them as forged. I'd much rather they bend (which can be fixed) than break. Caleb, it's heat alone that causes the alligator surface. You can get good results with clay, if you keep the temperatures right. That surface comes from being 400-500 degrees too hot. It's easy to overshoot the temps when using just your eye. Before I got a thermocouple, I did my HT in a dark forge, after dusk, to avoid that problem. Geoff "The worst day smithing is better than the best day working for someone else." I said that. If a thing is worth doing, it is worth doing badly. - - -G. K. Chesterton So, just for the record: the fact that it does work still should not be taken as definitive proof that you are not crazy. Grant Sarver Link to comment Share on other sites More sharing options...
Buck Hedges Posted February 9, 2014 Author Share Posted February 9, 2014 Thanks for letting me know what I did. I don't know if I will ever do that intentionally, but at least I know how. Truth simply is. Whether you like that truth or not is totally irrelevant. https://www.facebook.com/StormsForge">https://www.facebook.com/StormsForge Link to comment Share on other sites More sharing options...
Miles Hebbard Posted February 9, 2014 Share Posted February 9, 2014 Every now and again I mess around, here's another And one more, To become old and wise... You first have to survive being young and foolish! Ikisu.blogsot.com. Email; milesikisu@gmail.com mobile: +27784653651 Link to comment Share on other sites More sharing options...
Buck Hedges Posted February 9, 2014 Author Share Posted February 9, 2014 Now that I've seen what can be done with them Miles, I may have to take another look at my "junked" blades.... Truth simply is. Whether you like that truth or not is totally irrelevant. https://www.facebook.com/StormsForge">https://www.facebook.com/StormsForge Link to comment Share on other sites More sharing options...
R. Yates Posted February 9, 2014 Share Posted February 9, 2014 This was clayed the taken to orange, cooled slowly to air temp , then heated to just non magnetic and quenched, Every now and again I mess around, here's another And one more, Dagum Miles them look very bad you need to send them to me for proper disposal <Grins> Robert D. Yates , 13 & On Forge Link to comment Share on other sites More sharing options...
Miles Hebbard Posted February 9, 2014 Share Posted February 9, 2014 Thanks guys, if you are carefull with the clay you can manipulate it to get various pattening, I should be. HTing one on wednesday, so I'll take some pics of the process. To become old and wise... You first have to survive being young and foolish! Ikisu.blogsot.com. Email; milesikisu@gmail.com mobile: +27784653651 Link to comment Share on other sites More sharing options...
