Fred Crislip Posted June 21, 2014 Share Posted June 21, 2014 (edited) Hey all, just starting one and wanted your advice, this is what I have this far, any comments?the blade is from an old 12 inch file. fred Edited June 21, 2014 by Fred Crislip A bad day forging... is still better than pretty much anything else Link to comment Share on other sites More sharing options...
Jeppe Posted June 21, 2014 Share Posted June 21, 2014 I think you forgot to attach a picture. Link to comment Share on other sites More sharing options...
Fred Crislip Posted June 21, 2014 Author Share Posted June 21, 2014 Fixed! A bad day forging... is still better than pretty much anything else Link to comment Share on other sites More sharing options...
MatthewBerry Posted June 21, 2014 Share Posted June 21, 2014 (edited) remember that the blade will curve down if quenched in oil, or up if quenched in water. So if you want the finished edge to be straight then curve the opposite way during forging. A rough guess is that will curve down about 3/8" in oil, and curl up a bit more than that if you quench in water. Been dealing with this in making my own seaxes. I like to trace the rough ground blade on paper, and then again after quenching so I can see exactly how much it changed. Edited June 21, 2014 by MatthewBerry www.hopkinsforge.com hopkinsforge.blogspot.com heisenblade.deviantart.com Link to comment Share on other sites More sharing options...
