toddhill Posted May 29, 2005 Share Posted May 29, 2005 Hi. This is Todd Hill living in good ole hot AZ. I'm an amateur bladesmith and my driving passion has been traditional Japanese, hence my interest in Don Fogg and this forum. I've been working on clays and hamons and water quenching for about a year now and I think I'm getting close to some success. First, I ignored all the advice out there and "wasted" a lot of time messing with 5160, because it was so readily available. I finally succeeded in getting a hamon with it using a water quench. But, just like they all said, the hamon was "weak." So, I got over 5160 and moved on to 1080. I forged an 8 inch blade and clayed her up (first pic). I covered the spine to get as much sori as I could. I heated it to just above nonmagnetic and plunged it into the 100 deg. tap water. After a few seconds I felt and heard four distinct clicks as the blade cracked rather severely along the edge (second pic). The blade took significant sori. I asked the pros for feedback and they said I had my clay too high up. That much hardened edge couldn't handle the curving of the sori. So, I forged another 8 inch blade from 1080 and clayed it much lower (I guess there's a reason for the traditional one third ratio for the hamon). This time I played it extra safe and also scraped the spine to minimize sori. Again, I heated it to just above nonmagnetic and plunged it into my 92 deg. tap water. Heart beating, I waited. No clicks! No cracks! Also no sori. While the blade was still warm I put it into a 350 deg. tempering oven, clay and all. I took it out after an hour (third pic). After polishing and etching I found a delightful hamon (fourth pic). Sorry, the pics are so small. The forum won't allow me any more space. Never mind, it won't allow me any space. I'll have to put them on another post. I have a lot to learn still, but am getting closer to success. I'm seeing why bladesmiths can ask the prices they do for handmade knives. It's a lot of work, with a lot of mistakes along the way. So, even if they can put out a blade in a matter of hours, I know many days and months and failures are behind those hours. I want to learn more about how to apply clay and the patterns that work best. Do any of you have pics of blades with clay on them so I can learn from you? Thanks, Todd Link to comment Share on other sites More sharing options...
toddhill Posted May 29, 2005 Author Share Posted May 29, 2005 For some reason, I can't post the pics. It keeps saying I don't have enough global space. I tried starting another thread and it gives me the same message when I try to attach the pics--and they're really small. I'll keep trying. Link to comment Share on other sites More sharing options...
toddhill Posted May 29, 2005 Author Share Posted May 29, 2005 (edited) Ok, I finally figured it out. The forum saves all attachments and my storage was too full. Here are the pics. Todd Edited May 30, 2005 by forginhill Link to comment Share on other sites More sharing options...
toddhill Posted May 30, 2005 Author Share Posted May 30, 2005 I know I haven't "arrived" yet, but I'm really happy about getting a hamon and doing it with a water quench. Getting the right "clay" recipe was big and then applying it right and then quenching in water without cracks--these were all milestones for me and I couldn't have done it without a lot of personal help from Dan. So thank you, Dan. Todd Link to comment Share on other sites More sharing options...
dan pfanenstiel Posted May 30, 2005 Share Posted May 30, 2005 Cracking happens. Excellent job on working it out, Todd. I've gotten a lot less cracking by making sure to normalize at least once after rough grinding my forged blades. I'm also leaving 60 grit scratches for the clay coat to stick better but, smooth out the edge about an eighth inch up the blade sides to remove any stress risers. Any time I got a crack before this, I could trace it back to the edge where it usuall originated in a larger scratch than the others. By removing the 60 grit scratches along the edge, it slowed cracking down a lot. Dan Pfanenstiel Link to comment Share on other sites More sharing options...
robert washburn Posted May 30, 2005 Share Posted May 30, 2005 another thing that I do is heat the water to 140 deg..I have done several this way with no problems.Email and I`ll try and help you. Robert Link to comment Share on other sites More sharing options...
