Geko 14 Posted December 3, 2014 Share Posted December 3, 2014 every time i make micarta there is a little left over material (resin and paper). was thinking long time what to do with it. here is what i came up to. here you find the micarta tutorial http://www.bladesmithsforum.com/index.php?showtopic=29530 have a nice day, geko Link to post Share on other sites
Alan Longmire 2,749 Posted December 3, 2014 Share Posted December 3, 2014 That is brilliant! Link to post Share on other sites
Don Abbott 116 Posted December 3, 2014 Share Posted December 3, 2014 That is a great idea. The brown Dremel bands are way over priced and wear out quickly on metal. I'll probably never get around to making any of my own, but I certainly appreciate you sharing your information. Link to post Share on other sites
Jan Ysselstein 66 Posted December 3, 2014 Share Posted December 3, 2014 (edited) Geko, Very nice , good idea. Thanks The other day someone posted a very clean way of making micarta , by placing sheets in a polyethylene box ( very nice as well)...but this is even cleaner. Why not make some micarta over a paper covered mandrel say 3/4" to (larger) diameter and wrap the material ( saturate while it is under tension) , build up enough for the thickness of two scales, pull off and press. One could use the full width of material or work in scrap strips or banding and overlap. If sized just right the corners may even create an interesting look on the finished handle. I think this winding method is used for fishing poles and graphite shafts..( no pressing ). Jan Edited December 3, 2014 by Jan Ysselstein Link to post Share on other sites
Mike Johnston 8 Posted December 4, 2014 Share Posted December 4, 2014 Dremel is going to hate you, but I LOVE it. Boy can I think of LOTS of applications for that idea. Link to post Share on other sites
Geko 14 Posted December 4, 2014 Author Share Posted December 4, 2014 thank you guy´s. im happy that you like it. Geko, Very nice , good idea. Thanks The other day someone posted a very clean way of making micarta , by placing sheets in a polyethylene box ( very nice as well)...but this is even cleaner. Why not make some micarta over a paper covered mandrel say 3/4" to (larger) diameter and wrap the material ( saturate while it is under tension) , build up enough for the thickness of two scales, pull off and press. One could use the full width of material or work in scrap strips or banding and overlap. If sized just right the corners may even create an interesting look on the finished handle. I think this winding method is used for fishing poles and graphite shafts..( no pressing ). Jan sounds like a interesting idea. but i stay with my way of making micarta. cheers, geko Link to post Share on other sites
GEzell 136 Posted December 5, 2014 Share Posted December 5, 2014 You just solved a problem I've been struggling with. Brilliant indeed. Link to post Share on other sites
BradGalles 1 Posted December 5, 2014 Share Posted December 5, 2014 Great Idea! Thank you for sharing Link to post Share on other sites
