Well Its been a while, but I am back in Thunder Bay Ontario and back in the shop. I have finished a half dozen blades or so, and decided to work on something for myself. I also decided to take some pictures to remember the process.
I bit the bullet and ordered some 1095 and 15n20 steel to do a Pattern welded blade. I have done low layer count blades in the past and also worked with steel cable, but this was to start with a 21 layer count, and hopefully end up some where around 200 including a 1095 core. If you have any questions or general tips for me, feel free to drop a comment.
I got started by making some Mokume Gane for my handle work, though im not sure exactly what I will be turning out. I am not to sure what kind of blade I want yet either, but how much steel I have left after welding will be a big decider there. I make my mokume by welding a little cage around the materials consisting of two U shaped pieces of mild steel. Seems to work ok, might work better to weld both of the U pieces to a section of round stock as a base. I tried leaving the paper wrapping on the discs to make it easier for welding and it didn't seem to cause any problems.
IMG_20141019_084502_1.jpgIMG_20141019_093429_1.jpgIMG_20141019_094450_1.jpgIMG_20141019_094627.jpgIMG_20141019_101148.jpgIMG_20141025_175101.jpgIMG_20141025_220715.jpg
So I start my Billet by cutting my stock into little squares, and then stacking them in alternating layers. I plan on wrapping this around a 1095 core, so I am not to worried about which the middle layer is at the moment. After they are cut and deburred, they are cleaned up a little and squared up in the vise. I weld the corners together and get the billet setup to weld a long handle on it. After a quick clean up with the wire wheel I fire up the forge.
IMG_20141202_190151.jpgIMG_20141202_190313.jpgIMG_20141202_190514.jpgIMG_20141202_193419.jpgIMG_20141202_194653.jpgIMG_20141202_200122.jpg
I can say that next time I will be starting with a longer narrower billet as apposed to the rectangle shape. But live and learn. I get the billet red hot and start on it with my borax setup. I keep heating and occasionally brush of junk and add more borax. On my first welding pass I use solid but lighter blows starting in the middle and then working the edges. Keeping in mind not to forge below a red
colour heat. I eventually ended up with a pancake, and I cut the corners where it had been welded so they didn't taint the final product. yay for pancakes!
IMG_20141202_201915.jpgIMG_20141202_201950.jpgIMG_20141202_202007.jpgIMG_20141202_205852.jpgIMG_20141202_212731.jpg
After doing an Annealling process to remove some stress from the piece, I cut my pancake into five pieces and clean up the surfaces on the 6x48 belt sander. Once they were all shiny, I mate them in the vice and welded the corners together as well as reattaching the handle. I will be repeating the first step again, but with more focus on drawing out the billet long an narrow. Once I was happy with what I had, I put it through another annealing process.
IMG_0127.jpgIMG_20141205_204204.jpgIMG_20141205_205620.jpgIMG_20141205_210204.jpgIMG_20141205_210221.jpgIMG_20141205_211639.jpgIMG_20141205_211703.jpgIMG_20141205_214223.jpgIMG_20141205_220729.jpg
Next, I cut what I had into two pieces and cleaned up the surface that I was going to weld. I prepped and cleaned my piece of 1095 that was to be the core. leaving the handle attached to a piece of the original billet was an easy base of operations. I seen a video of a smithy putting borax in between the layers of steel when he slipped in a carbon core, so I figured I would give it a try . This time I clamped the pieces together and used wire to bind them. I think I should have used more wire because I had an issue with the pieces separating and sliding slightly.
IMG_20141206_174106.jpgIMG_20141206_174113.jpgIMG_20141206_174308.jpgIMG_20141206_183216.jpgIMG_20141206_183550.jpgIMG_20141206_183558.jpgIMG_20141206_183647.jpgIMG_20141206_183817.jpgIMG_20141206_184606.jpgIMG_20141206_184756.jpg
So after repeating the beginning process and completing a solid welding pass, I quickly remove the wire and stuff it back in the fire. Don't need that wire ruining my hard work! I keep working the piece until I end up with a bar well thick enough to make a sturdy blade. It is important to try and work the piece evenly with your hammer blows to keep the core in the center. One thing I was aware of but fail at was hammering it to much. I forged it to close to shape and very little of the 1095 steel core is visible at the edge. Its not terrible but next time I will leave a little more for the grinder. After getting as much scale off as possible I put the steel to anneal.
IMG_20141206_190638.jpgIMG_20141206_192328.jpgIMG_20141206_192448.jpgIMG_20141206_193308.jpgIMG_20141206_194259.jpg
So I begin of my blade forging phase with a fairly clean piece of steel, I try to get of all the scale without grinding away my layers. I will start by forging the tang.
IMG_20141207_192547.jpgIMG_20141207_193122.jpgIMG_20141207_194156.jpgIMG_20141207_194939.jpgIMG_20141207_195134.jpgIMG_20141207_200152.jpg
Now, I will hammer the point and this is going to be a precurve, so when I start to hammer the bevel it wont have to do as much fixing. I find it helps to work the bevel on the edge of the anvil and push the material away from you with glancing blows. After a beveling pass on each side is done I fix up the profile of the blade and straighten it for the next pass of the hammer. I will repeat this process one more time before working the side opposite the edge to work in a taper. This also pushes the point back down into a drop point. Once I am happy with the over all shape, I give it a straightening pass and heat it for an annealing phase.
IMG_20141207_201201.jpgIMG_20141207_201926.jpgIMG_20141207_202650.jpgIMG_20141207_203005.jpgIMG_20141207_203018.jpgIMG_20141207_203042.jpgIMG_20141207_203057.jpgIMG_20141207_203513.jpgIMG_20141207_204019.jpgIMG_20141207_204029.jpg
Well here we go. Isnt it beautiful? lol! After removing scale with the angle grinder, I will clean up the profile of the 2" belt grinder. Then I will take it to the 6" belt sander to flatten out the ricasso and tang areas. Then I will set it up in a filing jig and use a half round file to clean up the tang shoulders and choil areas. Next I reposition the blade in the jig and grind the bevel flat with a 36 grit belt on the 2'' grinder.
IMG_20141207_205407.jpgIMG_20141207_205644.jpgIMG_20141208_132056.jpgIMG_20141208_133608.jpgIMG_20141208_133630.jpgIMG_20141208_133747.jpgIMG_20141208_133943.jpgIMG_20141208_134028.jpgIMG_20141208_134231.jpgIMG_20141208_135015.jpg
IMG_20141208_135226.jpgIMG_20141208_141645.jpgIMG_20141208_141712.jpgIMG_20141208_141805.jpgIMG_20141208_142015.jpgIMG_20141208_151038.jpg
With blade rough ground I fired up the forge and got my oil heated for heat treating. This blade was annealed, then normalized three times at lower subsequent heats from around 1600f. Then heated to around 1475f and plunged into 140 degree canola oil. I tempered the blade at 400f three times allowing to cool each time. After all that the blade was back into the filing jig and the edge was inked and scribed with a center line. the bevels were ground to 320 grit on the 2'' grinder. Then I cleaned up the ricasso and tang on the 6" belt sander.
IMG_20141208_200801.jpgIMG_20141208_204055.jpgIMG_20141208_204230.jpgIMG_20141208_204301_1.jpgIMG_20141208_210605_1.jpg
Now for the hand finishing. Here are the tools I use, just a 1'' wide bar with mounting tape and a shop roll of emery cloth. I mount a piece of wood in the vice and clamp my work to that. Starting with 400 grit and working opposite to the lines of the grinder, I remove all the 320 grit lines on the bevel and the ricasso. Next is 600 grit, and that is worked perpendicular to the 400 grit marks. 600 grit is as far as I am going with this blade. Don't for get the spine and other parts of the blades profile. Now I will clean the blade and git it into the etching solution. I use Muratic acid because its easily obtainable at Canadian Tire. I set my glass container of acid in a boiling pot of water to help activate the acid. Use caution! This creates fumes! So I believe it is best to etch your blade for many short periods (5-10mins) and then remove it for cleaning and progress check. So here is the fruit of my labour thus far. I am going to be starting the guard and spacers next, so tune in again. Thanks for looking, john
IMG_20141208_210815_1.jpgIMG_20141208_210834_1.jpgIMG_20141208_230649_1.jpgIMG_20141208_233121_1.jpgIMG_20141208_233138_1.jpgIMG_20141216_184918.jpgIMG_20141216_184951.jpgIMG_20141216_185037.jpgIMG_20141216_185110.jpgIMG_20141216_185142.jpg
Edited by John C. Lewicki
John,
Very nice post....I like the final look of the steel very much. When welding up the elements for the pancake do you sometimes find the bottom cooling too fast during the setting of the weld (weld failure).......the appearance of the finished blade looks as though the slower etching material is the darker in color ..is that the case of is that only how it appears?
Thanks for the post.
Jan
Edited by Jan Ysselstein
Nice WIP, thanks! I noticed a lot of borax on the billet before welding, do you put that much between the layers when MIG welding it up? If so, you need to be careful to squeeze it all out when welding as you can get bubbles or inclusions, didn't happen here so never mind but be careful in future! Nice pattern!
JH
John,
Jan
I notice when I did the first welding pass with the original 21 layers, that the two outter layers expanded and bowed causing delamination. Not really sure what to do there but Wire might help. The pictures are a bit deceiving, the slower ethched material is a little brighter.
JH
Hi james, no I didn't put any borax in between the layers when I originally tacked it up. Im still not sure if this is the best way to do it, and the borax did seem to push the sections apart plus cause slippage. Maybe less borax is a good way to go next time.
you can get away with very little borax in the middle, or just make sure the surfaces mate very well and use No borax. But, if you do that, be ready to grind away a 1/8" from the circumference where the welds tend to tear apart or oxidize. No flux is great, but there is a little more grinding around the edges than if you use borax. But, there is NEVER a hidden slag inclusion!
nice work so far. keep posting your progress.
kc
  • 9 months later...
Well its been another summer of working up in the Yukon, and I survived the season. I will be back in the shop soon, and hard at it. I am stoked to get back to the forge and put the hammer to the metal and test out some ideas I have been mowing around.
I started this pattern weld post a while back and never updated with the finished product, well here it is. I am not overly happy with it, but I took what I learnt and did better on the second go of pattern welding.
I will post a couple pics here and a link to my website that I am working on. If you guys have any suggestions on design and content for my website I would love to hear them.
Thanks for looking,
johnny
Heres a link to my website http://www.lewickibladesmithing.com/
I really like the mokume on the blade! The website is good, but I'm not too big a fan of the site opening with a cover page. If you want to keep it, I would have a button that says "to home page" or something. IMO it would be better without the cover page because the home page shows the same thing anyways. Also a background other than black would be nice. Don't make it super light/overly detailed because you want the viewer's eye to look at the blades. I would go for something like an abstract, flowing, large pattern in dark green, blue, etc. Hope that helped!
Wes
that mokume is cool! continued good progress. I suggest you now work on getting the plunge cut to end with a radius just before it reaches the spine of the knife. If you overshoot, and cut all the way to the spine, you can put the blade/ricasso flat against the platen of the grinder, held vertically, and grind it back to a great radius. Or, you can file it back.
kc
