Emiliano Carrillo 243 Posted October 11, 2016 Share Posted October 11, 2016 Jul if you do let me know I am so into that! 1 Link to post Share on other sites
Joshua States 1,717 Posted October 12, 2016 Share Posted October 12, 2016 (edited) I keep re-reading this thread periodically. I really want to make some spears, and some wolf's teeth. I wonder about the possibility of making a key die which both pieces of the wolf pattern are forged into, and then the two put together. I also wonder how much evidence we have for spear length as it relates to spear head styles... I've been thinking about this and I had an idea about making that die. I was thinking about two wedges set side by side shaped like the indentations for the teeth and a handle. The spacing, depth, and size is now controllable. The operation is simple, but probably takes two people. Set the die on the edge of the core and strike this makes two indents. don't set the die full depth, just enough to mark the spacing. Move the die over so one of the die halves is on the last mark and strike again. Move down the length of the core and set all the marks. Do the other side the same. Now reheat and line the die up in two marks and set the depth. Move to the next two marks and repeat. Continue down the side of the core and set all the depths. Now do the same on one edge piece. Set the edge piece on the anvil teeth up. Reheat the core and put it onto the cold edge piece on the anvil. This will keep the setting process on the second side of the core from disfiguring the first side while you set the depths on the second side. Do a second edge piece, assemble and weld. Attached drawing (admittedly very rough sketch) of the die concept. wolf's tooth die.pdf Edited October 12, 2016 by Joshua States Link to post Share on other sites
Niels Provos 165 Posted October 12, 2016 Share Posted October 12, 2016 I am getting close to posting a video on how I made the two Wolf's Tooth spears I have produced so far. I tried all kinds of approaches over the last couple of years, I settled with a simple double chisel to forge the teeth into the steel. Thats's pretty quick and not very complicated. I then either hammer or press the very hot wrought iron into the steel. Take it apart, clean and then forge weld. Link to post Share on other sites
MatthewBerry 68 Posted October 13, 2016 Share Posted October 13, 2016 Perhaps one day I could host a mini spear forging moot... Oh yes! That would be awesome. I'll bring 20 bottles of my pretty-bad mead (tastes like pinot grigio). Best for drinking after the good stuff. Link to post Share on other sites
J.Arthur Loose 102 Posted October 13, 2016 Share Posted October 13, 2016 Argh, I wish I had been able to buy the land next to me with the farmhouse and the barn to start up a metalsmithing school before it got bought and parsed out. It would be hard to host anything other than a very small gathering in my current arrangement. But it would be cool to have a Spear-In. Link to post Share on other sites
Dmitry Derevyago 4 Posted January 24, 2020 Share Posted January 24, 2020 Hello. Not so long ago became the owner of this Viking spear. There are not many mentions of wolf teeth spears on the net. Perhaps this topic contains the largest number of images of such copies. And only thanks to this topic I understood what I'm dealing with. The spear was mechanically cleaned of oxides and etched pattern on the blade. 4 Link to post Share on other sites
Pieter-Paul Derks 210 Posted January 24, 2020 Share Posted January 24, 2020 That is a beautiful spearhead, thanks for adding it to this thread. Link to post Share on other sites
Alan Longmire 2,717 Posted January 24, 2020 Share Posted January 24, 2020 Thanks indeed! That's a nice one. Link to post Share on other sites
Joshua States 1,717 Posted January 27, 2020 Share Posted January 27, 2020 Yeah, I like that spear head! It's still in pretty good shape too. Link to post Share on other sites
Justin Mercier 65 Posted January 27, 2020 Author Share Posted January 27, 2020 Gorgeously preserved spear with a lovely reinforced tip. Thank you for sharing ! Link to post Share on other sites
