Jan Ysselstein Posted March 21, 2024 Author Posted March 21, 2024 (edited) IMG_5635.mov The gas forge is working well hot enough to roast/forge wootz ..I plan to use a coil to control the temperature…will post it if it works. The 6” channel welded to the top of the forge moves a lot of exhaust from the forge to the rear area and get very hot…I use it as a handle for picking up the forge and a place to use the DET for pattern development. I move the forge a lot as that is the location where the melting furnace goes as well. Redoing the dies for the press and should be ready to go with #4 ingot. Below are some pics of the forge furnace and a short video showing an emphasis in controlling the press…press is running at either 18 or 9 tons ( flip a switch while running or stopped ) . IMG_5635.mov Edited April 5, 2024 by Jan Ysselstein 1
Joshua States Posted March 23, 2024 Posted March 23, 2024 How long are you typically roasting an ingot? “So I'm lightin' out for the territory, ahead of the scared and the weak and the mean spirited, because Aunt Sally is fixin’ to adopt me and civilize me, and I can't stand it. I've been there before.” The only bad experience is the one from which you learn nothing. Josh http://www.dosgatosdesignsllc.com/#! https://www.youtube.com/channel/UCdJMFMqnbLYqv965xd64vYg J.States Bladesmith | Facebook https://www.facebook.com/dos.gatos.71 https://www.etsy.com/shop/JStatesBladesmith
Jan Ysselstein Posted March 23, 2024 Author Posted March 23, 2024 Typically I roast at 1150 C for two hours at heat and this last batch should have been air cooled but I left it in the furnace for a slow cool, creating the need for another soak when forging . I see a big change coming for me as the new press setup will allow me to forge fast…..not big bites but many small deformations ….trying to duplicate the guys at Stanford who developed the very soft steels by working them during the cooling from Austenite to a two phase state where the cementite is spheroids. Always something to look forward to. 1
Jan Ysselstein Posted April 29, 2024 Author Posted April 29, 2024 (edited) Well after lots of failed runs , I have 3 new ingots . All 3 were made to be at 1.5% C all were treated alike as close as we can expect ( no thermocouple ). The microstructures are all relatively similar. I will add some pics including some micrographs . Below are pics of the 3 ingots and the furnace after full heat. The micro structures are on another device. The little metal man came out of a leaking crucible during a failed run. Approaching the end of the topic. Edited April 29, 2024 by Jan Ysselstein 3
Jacob Christian Posted May 28, 2024 Posted May 28, 2024 On 3/22/2024 at 10:48 PM, Jan Ysselstein said: trying to duplicate the guys at Stanford who developed the very soft steels by working them during the cooling from Austenite to a two phase state where the cementite is spheroids. Always something to look forward to. Jan, Are you talking about getting the spheroidite microstructure?
Jan Ysselstein Posted May 30, 2024 Author Posted May 30, 2024 Jacob, yes , by doing mechanical work to a sample while it is cooling prevents large cementite structures from forming …letting it cool to below the transition temperature and heating into the austenite zone again for another cycle and do on. 1
Jan Ysselstein Posted August 26, 2024 Author Posted August 26, 2024 (edited) Digging in the trash. I have not melted for a long time and will start again in September. I have encountered some problems forging ( which used to be easy) . Made a new press which may be too powerful for the job at hand, putting too much energy into the work..my older press was much weaker...I did not think at the time that could be an advantage. By adjusting the pump pressure relief valve to a place where I can duplicate the pressure of the old pump I think I can proceed.. The only problem now is the flow rate is very high , I hope I can control it. To give the new adjustment a try I went into the trash to find ingots I had planned not to forge 4" diameter, both,...... one has small cracks on the top surface ....the other is very porous with a huge hole at the bottom. I have some pics of their current structures and of the ingots .....I wil post them later today. Below are the structures of the two ingots both have been roasted for two hours at 1150 C. I 'll post the ingot pics later today. I do not expect a large fault free forging, just a forging. time Edited August 27, 2024 by Jan Ysselstein Grammar mm. 2
Jan Ysselstein Posted September 4, 2024 Author Posted September 4, 2024 The two ingots ( lens shaped ) were partially cut in half cut in half, then broken in two with the gentle press. Initially the ingots were rejected based on their exterior appearance. Now they look pretty good inside. It is too hot to light my forge until Sunday and next week….so I will work on something else. Because of the large grain I see I will soak these and some other samples for 2 hrs at heat before forging….some of the samples go back to 2006. 3
Jan Ysselstein Posted September 7, 2024 Author Posted September 7, 2024 (edited) Later today (or next week) I am doing a test to see if I can eliminate the source of that big hole shown just above. The furnace (my furnace) is under some slight pressure during melting just enough to create that hole(s). Reducing the pressure by allowing the hot gasses to escape unobstructed. The test is expensive because I am using 1300 grams of homemade cast iron and 1700 grams of basic open hearth iron. Exiting, if it works I will be applying to get into the Wootz 1-B class. Edited September 7, 2024 by Jan Ysselstein 1
Alan Longmire Posted September 7, 2024 Posted September 7, 2024 I was wondering about that hole, but I just figured it was shrinkage. So furnace pressure alone will do that?
Jan Ysselstein Posted September 8, 2024 Author Posted September 8, 2024 (edited) Alan, it may be due to shrinkage but I am thinking O2 or CO2 may be migrating through the crucible. Edited September 8, 2024 by Jan Ysselstein
Jan Ysselstein Posted September 15, 2024 Author Posted September 15, 2024 (edited) So, I was faced with two problems, cracking ingots and large holes near the bottom surface of some of my ingots. I was able to forge the ingot shown above...it had some micro cracks but most of it held together and I am assigning my problems to a) micro cracks in the top surface of the ingots and too high a press force created difficulty forging b) the large bottom surface holes were eliminated ( mostly ) by using a crucible with a thicker bottom from about 3/8" to 3/4" in thickness. I am very happy with the pattern revealed so far of the ingot shown above cut into two with micro cracks. When I am done with the forging and grinding I will post a photo of the pattern. The test to control the large holes did not go as hoped. some of the ingredients did not incorporate into the sum ( maybe that 3/4" thick bottom affected the rate of incorporation ). I am not concerned as this was the first trial of a 5" diameter ingot ( heading towards 6" maybe 7" in diameter ) . I will repeat the 5" ingot and forge the two halves of the 4" ingot with the large holes. I will add some pics. Very exiting. Edit Here are a couple of pictures of the “failed ” 5” ingot the cast iron (.032 C ) did not make it to liquid state on time and began to lose carbon raising the melting temp. Edited September 18, 2024 by Jan Ysselstein 2
Jan Ysselstein Posted September 16, 2024 Author Posted September 16, 2024 I was able to get the ( micro cracks ) ingot down to 6mm using only the press. No attention was given to the probable microstructure. Stayed in the 950 C to 1000 C most of the time The first two pictures show the microstructure of the 6mm bar as forged. The second set are pictures of the same bar after holding at 945 C for 45 minutes and letting it cool in the furnace (off). My interpretation is a guess so please correct me if I am wrong. The as forged pics show a granular structure with lots of angular cementite particles at the grain boundaries. The areas light in color show spheroidal cementite in the areas defined by the grain boundaries. The pics showing the structure after a 45 minute roast now have the spheroidal cementite in the area occupied by the large angular cementite particles. The dark areas are pearlite. I have two bars of this material .....I will take this one to thermo cycle it, knowing the large particles will not go away. If the spheroidal cementite and the large particles occupy the same areas the pattern may still be pleasing. The other bar of the same ingot will be taken to 1100 C for about 45 minutes- 60 minutes and oil quenched , knowing it will not become martensite. Then thermo cycle. 1
Joshua States Posted September 17, 2024 Posted September 17, 2024 It's wild stuff no matter what. Soon, very soon, I will be able to start melting again. I still have a crucible loaded with the materials you sent me just waiting........ “So I'm lightin' out for the territory, ahead of the scared and the weak and the mean spirited, because Aunt Sally is fixin’ to adopt me and civilize me, and I can't stand it. I've been there before.” The only bad experience is the one from which you learn nothing. Josh http://www.dosgatosdesignsllc.com/#! https://www.youtube.com/channel/UCdJMFMqnbLYqv965xd64vYg J.States Bladesmith | Facebook https://www.facebook.com/dos.gatos.71 https://www.etsy.com/shop/JStatesBladesmith
Tim Mitchell Posted September 17, 2024 Posted September 17, 2024 On 9/16/2024 at 8:38 AM, Jan Ysselstein said: I am not concerned as this was the first trial of a 5" diameter ingot ( heading towards 6" maybe 7" in diameter ) . I will repeat the 5" ingot and forge the two halves of the 4" ingot with the large holes. I will add some pics. Very exiting. Hey Jan, I am curious if you are having issues with holes in the center of your ingots why you are wanting to go larger with your ingot diameter? Traditionally the largest size of disk ingot which was used seems to be between 4 and 5 inches with most ingots being around 1kg and 4 inch diameter. Even with that size it was very common to get porosity / shrinkage cavities in the upper center of the ingots. This is going to get worse as you increase the diameter, because the steel has to shrink over a larger distance and because it solidifies from the outside first it tears the structure apart in the middle. Slowing down your press is definitely a very good idea, forging too hard and fast will make your ingots fail in a heartbeat. Tim MitchellBuffalo River ForgeGreat Lakes, Australia.
Jan Ysselstein Posted September 17, 2024 Author Posted September 17, 2024 (edited) Joshua, I live in the mountains where the CZU fire burned. We have a lot of down dead trees and I will be making charcoal and iron this rainy season. I forgot what was sent but I have more coming. The short stack will be the first trial. Happy melting. Tim, yes the ingot I pulled from the trash was a disaster and full of holes in the interior. I threw it away again . Regarding the large diameter ingots. Somewhere I read these were once made or they could have made them. A 6” ingot would weigh about 9 lbs. I cut the lens shaped ingots into two pieces which would give me a lot of material having a rich pattern ( the middle of the half round. That size ingot would lend itself to removing a center hole and forging the ring over a mandrel and opening it up after a few cycles. The problem I am having to solve is how to heat that big shallow crucible , I have made some modifications to my furnace but have yet to get a really good ingot (close but not yet). There are a few other possible advantages with a large diameter ingot related to pattern formation, but those are a stretch. I am not concerned about a shrinkage cavity I am hoping to se it we can solve that problem should it arise. My concern is not dendrites forming from the walls but from the top surface of the mostly molten ingot….keeping it all as liquid can be a challenge. Today after my frustration I forged a bar from an ingot I made in 2006 . Must have been high in P as I was forging and grinding equally time wise. Edited September 17, 2024 by Jan Ysselstein 1
Tim Mitchell Posted September 17, 2024 Posted September 17, 2024 (edited) The crucibles that Thelma Lowe found in her excavations at Konasamudram were between 25 and 120mm internal diameter so from 1 inch to 4.7 inches diameter ingots. The 9 pound ingots that you are thinking of were only found in the Fergana valley of Uzbekistan and those ingots were not disk shaped but egg shaped as shown in the picture, which is why they were able to make them that large and avoid any shrinkage cavities. I had the same thoughts about pattern changes from using large ingots, and with dendritic patterning it does make a difference, but with lamellar pattern structures it doesn't seem to make a big difference, other factors control the spacing of the sheets in those structures. Regardless I look forward to seeing how your patterning experiments turn out with your large ingots. As far as slowing down the solidification in the disk shaped ingots, the ingots that they used in Konusamadram were very well insulated because of the rice husks that were in the clay of the crucible. It made them porous and more insulating than some other crucible materials. By the way, what did you mean by "Applying for the Wootz 1-B class", that one was lost on me? The crucibles from Uzbekistan were the type second from the left in this image. Edited September 17, 2024 by Tim Mitchell Tim MitchellBuffalo River ForgeGreat Lakes, Australia.
Jan Ysselstein Posted September 17, 2024 Author Posted September 17, 2024 (edited) Tim, it has been a while since I looked at what Thelma Lowe wrote. Several things stood out ,the crucibles must have been held over/on the coals and manipulated with tongs to keep them on the hot spot. The metal in the crucibles was called cast iron suggesting a very high carbon content. I made a crucible based on her description by mixing charred rice husks and vegetable oil until the husks were saturated , removing any excess oil and incorporating that husk/oil into a clay/grog mixture. That mix worked quite well. I used it to melt grey cast iron….made the crucible in the morning and melted the iron that evening. I did not use that as a mix any more than that once. At the very end of this thread I will pull some of these old methods together and make it (Wootz) without modern tools/fuels. Regarding shrinkage cavities…if the shrinkage of the cooling metal does not trap the remaining liquid there will not be a cavity …cold tops we often see as a top with a slightly larger diameter than the bulk of the ingot allows the metal to shrink without a cavity. Taking Wootz 1-b means I will continue and not drop out after 1a. It all looks impossible and going up hill but Sisyphus just keeps trying. It will all actually come together one day. Edited September 17, 2024 by Jan Ysselstein 1
Jan Ysselstein Posted September 18, 2024 Author Posted September 18, 2024 (edited) Tim, I forgot to mention the charred rice husks were not whole but run through a small manual meat grinder. The crushed material worked well. Much later I read they used whole husks ....both seem to work. The crucible was forced dried over a charcoal fire.... By the way the P in the 2006 ingot is 0.183% P....not as bad as I would have expected. Edited September 20, 2024 by Jan Ysselstein
Jan Ysselstein Posted September 20, 2024 Author Posted September 20, 2024 (edited) Too many irons in the fire. Finish forging the 2006 ingot bar. Dissolve the large carbides in the 2 bars from the micro cracks ingot and thermal cycle to a spheroidal structure. Repeat the 3Kg ingot with less glass and in a reducing atmosphere. Small ingredient sizes, ingredients are mixed evenly throughout the ingot at the start of melting. Below are some pictures showing attempts at working with bloomery iron ...which has to be reduced to small pieces. Basically the blooms are cut into 2 , flattened and cut into strips, forged into bars and cut into pieces. Some blooms have a loose character and produce a lot of stuff that did not stick to the forging. I am using a shaker with old broken blade pieces to clean that material ( which I have lots of ). Not my favorite activity. Bloom flattened, flattened bloom cut with a wheel, vibrator cleaning oxides off of small pieces of stuff fallen off of blooms. This bloom is a zero carbon chunk so soft it kept trying to grab the wheel. IMG_6107.mov Edited September 20, 2024 by Jan Ysselstein 1
Jan Ysselstein Posted September 21, 2024 Author Posted September 21, 2024 (edited) Well, I highly recommend the little HF vibratory cleaner..this is a small model ...quite adequate. Dirty cast iron going in 3 hrs later ...silver coming out ..what a deal. I have ordered some steel blasting material to test as a cleaning medium...and will let you know. Today I will bring a couple of strips of the cut bloom to a welding heat....consolidate the rough edges by hand hammer ...then draw the material into a thin bar. The thin bar will be cut by a chisel under the treadle hammer...the pieces will be vibrated before using as ingredient here ( crucible ) or as an ingredient for a "hearth furnace" for adding carbon ( that is a topic for another post I will elaborate on later) .. The topic of crucible steel in History deals mostly with carbon added via the atmosphere or carbon added via cast iron. A while back I tried a couple of runs making just steel by controlling the slag quantity and slag content. It worked quite well and will do it again this Winter....though not directly connected to this thread topic I will be testing it soon..much more direct than all the work involved in making ,breaking and cleaning cast iron......plus the making of a bloom , cleaning the bloom and so on. Here are a couple of pictures of this steel made directly in the furnace..it did require cleaning the bloom with a miner's pick and wire brush. I am not sure of the exact carbon content but it is very high and quite consistent between the two blooms. You are looking at a cross section, top and bottom views of the bloom steel. Edited September 21, 2024 by Jan Ysselstein 2
Jan Ysselstein Posted September 22, 2024 Author Posted September 22, 2024 (edited) It is time to guess the carbon content of the ingredients lots of bits and pieces of iron to go into the next few 1500 gram melts. Stepping away from a very large ingot because that furnace is a mess ( a discard). I have cast iron at 3.2% C ( a guess) sorted containers of “ low “ carbon bits and a container of”high carbon “ bits. None of the bits are homogeneous so we will do our best to get it right. I will call the low carbon bits to be .2% C the high carbon bits to be 1% C These 3 ingredients plus’s the charcoal in the head space will determine the total carbon of the ingot. The soft iron from the bloom is in the vibratory shaker. I will post some worst case carbon numbers and some pics of the ingredients . Small pieces of low carbon bloom , shown below. Cleaned of sticky black slag in the tumbler. I am still learning how to use that thing for removing scale and slag/flux. Edited September 23, 2024 by Jan Ysselstein 1
Jan Ysselstein Posted September 27, 2024 Author Posted September 27, 2024 (edited) So, the vibrator electric motor failed …..the motor seems to have bushing not bearings…..too bad but I have enough done to go quite a while. I am backing away from the very large ingot as it will give me problems I do not want to deal with now. So it will be flat ingots at just over 4” inches in diameter. No alloys added for the first two melts. My target carbon content will be 1.3% C plus enough carbon ( charcoal) to bring the total up to about 1.6% C sealed crucible. Ingot size 1500 grams. This procedure will eliminate oxidization of metal not in the cast iron bath. A larger rotary vibrator with bearings is in the works. Edited September 27, 2024 by Jan Ysselstein 1
Jan Ysselstein Posted October 20, 2024 Author Posted October 20, 2024 (edited) Rice husks are charred by holding them over the melting furnace in a sieve……pic. I did a melt today in the crucible size close to the 4” diameter of the “ hoard” ingots ….the weight however is 1439 grams ( lost 61 grams ). The ingot is smooth on top and fairly smooth on the bottom. Both sides give a nice spark. Here are some pics. ….The rice husk charr crucibles will be made with fireclay and grogg.grog and oil soaked husks. I will keep that posted. The concept of a charcoal melting furnace is taking shape. Not too exited about standing over that for 3+ hrs. . Edited October 20, 2024 by Jan Ysselstein 2
Jan Ysselstein Posted October 22, 2024 Author Posted October 22, 2024 The smooth top will have to be investigated as it was not a characteristic “cold top” . I will start by looking at the literature recently looked at. A cross section of the ingot will tell me more. Interesting.
