Posted
I had some catching up to do and just got ahold of this thread.
It's always great to watch your progress and process.
Joshua , thanks. I have had some bumps in the road . Created several ingots with a very cold top…by adding some ore to drop the carbon content…… they will become ingredients . The test did solve an enigma in my mind about an unrelated  .crucible steel process. I will post some pics of the sad ingots in a day or two.
By the way the rains have arrived and I will be able to run the short stack furnace. Question , are you and Frank looking to make cast iron? Cast iron is the easiest to make , steel is the hardest .
Edited by Jan Ysselstein
Posted
I haven't spoken to Frank in a while. I saw his last post on FB a few days ago. It looked like he was making more of those 4%C cast iron buttons. My shop is almost ready to start working again. I'll be doing some melts here after the holidays are over.
So, one problem I had was low carbon iron was not getting incorporated in the melt…this was fixed by “ hotter/longer”….but I now had atop surface I was unfamiliar with. Se pic below. Today I tried for a good melt and got it , though the cooling rate was too fast. I have brought it all back inside where I can judge the temps better. Below are pics of the flat top and of todays solid melt.
The two top pics are out of order.
Posted
I am ready to duplicate today’s run on Monday . I am ok with the cold top today. Thirty-four grams are missing in at 1500 out at1466 grams.
I could not wait until Monday…so I gave it a shot. I will post more pics tomorrow …the crucible is calm and cooling ..I can hear glass cracking but waiting to deal with a cooler ingot.
I have not seen an ingot top like this . The forge gets put back and we will try to forge a few of these.
looking through the lid.
A little hotter than above
cooling calmly
There is something going on I do not understand or am not seeing correctly.  I will know more in a day or two of forging. The temperature adjustments are so different form what I am familiar with . First thing I will do is find a plastic bag to calibrate the air flow rate at various settings on my variac. Next thing is to find a blower capable of delivering a steady flow at lower flow rates, my guess is I am running too hot and not settling on a good  cooling setting.
Posted
Good stuff.
Spencer Sandison is using a small blower that I purchased on his advice. It seems to work well, and the price was right.
https://intexcorp.com/products/air-mattresses/pumps-accessories/quick-fill-ac-electric-air-pump-38-9cfm/
Thank you Joshua , I used to have one very similar…the noise stove me nuts. I will look for another blower in my bone yard or drill a few 5/8” holes in the pipe …allowing the blower to run faster….if that is too much I will cover them (some) with tape.
I have cut the first ingot with a smooth top and unless the carbon is off we are looking good. I will cut a couple more ingots today. There are four ingots waiting to be forged . The forge furnace has been redone and is running well.
I will heat for 2 hrs at above 1100 C and just below 1150 C then air cool for a few seconds and gently touch with a hand hammer. Cool to black heat after each removal from the furnace.
Pics are of the smooth surface ingot shown in the uv light pic above.
The microstructure very much agrees with the texture of the break shown above. We are learning something every day. All 4 samples were made with home made iron and cast iron ...all melts were calculated based on " C " estimates...it is running a little high and may make this collection difficult to forge.
Over the moon. waiting for a miracle.
Well the Miracle has not happened yet but getting close.
Number 2 the very strong dendritic one shown above cracked  during forging, ( I still have the other half ) the cause is able to be explained and should have been predicted.
The other 3 halves are telling me they can go on  without cracking . I will be tracking their main dimension and their weight to see what the rates of change are ( at every resting point ).
I wanted to look at the microstructure of an ingot after the 2 hour soak and about 4-5 forging cycles. IT shows ( PIC below) there is still a lot of heavy primary cementite to be dissolved. I am going to do that before I continue forging.
THe next set of halves will be soaked 4-5 hrs total and I may keep a sample in the austenite zone while forging the first cycles.
IMG_6513.jpegOK I must have forgotten to submit a post. In any case all remaining 7 pieces are in the furnace. Some for a ;2 hrs at heat sauna some for a full 4 hrs. By the end of the day (3 pm) I hope to know more. So exiting!
The seven half ingots were all pulled at 2 hrs at temp. That makes4 hrs for the first batch and the rest have 2 hrs left to go. Below are pics of roasting at 2 hrs and at 4 hrs. I will try forging the first remaining 3 after normalizing them a few times.
Posted
The second set of four is looking good, one has a crack, I c as n still forge it. Three of them look good. The first set has two remaining ingots ….one is missing… but lots to forge. Tomorrow I will weld on some handles so I can continue forging.
  • Like 3
Posted
Jan, please explain what the heck is in that oven.....
Is that a half-ingot covered in clay with a pile of charcoal in the back and a bowl of charcoal up front?
Joshua, yes that is charcoal to scavenge some of the oxygen and a half ingot in a pieces of paper towel ( kind of an iron taco). Lots of them  in the back. The clay is fire clay mixed with a little borax and iron oxide to tell me what it is. That mix should also keep the steel from scaling but not  sure yet. I want to roast some blade blanks and will do so as soon as I get a good mix.
To get that taco in the furnace I paint an image of the steel bottom on the towel and I paint  the steel , set it and finish the sides….cary it holding only the paper towel.
I am very exited about forging this steel which I’think is  very high in carbon. I roasted an ingot from 2006 along with the halves ,that ingot had been roasted but slow cooled ,so I added another 2 hrs. And an air quench. The carbon is 1.6% lab tested…..so far it is very soft…so the halves must be way above 1.6% C . They are still pretty tough.
The forging of some of the samples went fairly well. The main problem was ...my oil forge does not operate well at lower temperatures once it as been very hot......I will have to see a way around that. Forging the "halves"  provides some interesting problems the base ( the centerline of the whole ingot ) cools  relatively fast on a cold anvil and creates a different microstructure profile than the arched top. The cold top rough edge also is a problem as it gets folded back into the main ingot during forging ...I will cut them off next time.
One of the ingots is making it through ..it is now about 7" long and from 1' to 3/4" thick .....kind of a " Merchant Bar" as John would say.
If that were a merchant bar ...I would buy it.
Here are some pics of the best "half ingot" microstructure .
Now I will stay with this size ingot and focus on forging , heat treating and nailing down a some practices with this form of ingot.
  • 4 weeks later...
Lots of samples getting squished and distorted. I am not 100% sure I am looking at what I think I am looking at. The image below seems to be the banding being forged from the side not the top. If you have seen this phenomenon what is it?
Verhoeven , in one of his papers, mentions that Sorel Metal is made from a Canadian Ilmenite ore. The Vanadium in his ingot compositions was found to have come from that ore. I am not seeing great contrast in my blade samples made with 100% home made steel. The ore is magnetic sand which is sorted by a magnet leaving the Ilmenite behind and discarded. Now I am looking at saving that material and adding it back at the ratio occurring in nature to see what the contrast looks like.  The vanadium levels in this ore are quite low but Chromium levels in my early trials were high and that ore may not have been sorted as well as later trials.
So , back to the ore with Ilmenite to make cast iron then some steel.
Edit ....the Chromium levels were high in wootz samples not the iron samples..the chromium source is assumed to have come from dirty or contaminated V2O5 ( chrome yellow is the suspected contaminant) . V2O5 and Chrome yellow look similar to some .
empty photo add.
Posted
Not seeing the photo, but Ilmenite isn't going to provide V or Cr...  It's FeTiO3, the primary ore for Tamahagane, Titanium, and Titanium dioxide.  It's a nasty thing to have in a bloom, makes for very refractory slag.  I have no idea what it would do to a wootz melt, but it can't good.  The chrome yellow is easily mistaken for yellow iron oxide (Limonite), though...
Alan,  I will be processing some ore in the next two weeks and will post a pic of the titanium ore ( only slightly attracted to a magnet ). Whether the Vanadium comes from the Magnetite or the Ilmenite.
...in either case it is a "contaminant".Photo on 1-8-25 at 10.46 PM.jpgPhoto on 1-8-25 at 10.46 PM #2.jpg
The pictures  are what I am seeing in some of the samples ready for a bit more final forging and the quench/TCycling. The left two are a sample with very bold and large patterning ( only 2 more cycles to go) .. My shop has skylights way up high..doing this at night is a good way to go.
Posted
My least favorite activity…..consolidating bloom iron. The press is helping but glad not to be welding it all. Next is cutting it with a hot cut and cleaning it up with the vibratory tumbler.
Posted
You must have a good sized tumbler!
What sort of media you use, and how does it hold up to the forge scale?
-Brian
IMG_6616.jpegBrian,  I am using the larger HF tumbler… but it is too slow and I am switching to 30%acetic acid , a stronger form of vinegar. This will remove the scale overnight. In the tumbler I am using steel blasting grit bought on eBay. That worked very well when the particles had sharp corners but they may be getting rounded off. My concern is the size of the iron pieces are fairly large and they need to get incorporated in the melt.
Now I am finish forging some of current ingot halves and tidying up some older bars . When I am done I hope to have a routine I can use to work with various bars.
Posted
I will give the rotary tumbler a fair chance at cleaning
the low carbon iron. After 6 hours there is some progress. The alte4native will be vinegar soak followed with a pressure washer rinse.  All the large iron and the cast will fit in the crucible (barely). Here is a pic taken today of the tumbler.
Posted
