Jan Ysselstein Posted April 28, 2015 Author Posted April 28, 2015 (edited) Mark, Thank you. I cannot wait for this thread to be done...I got some good results, with the wrong crucible. I am actually just at he beginning of this thread. Jan Edited April 28, 2015 by Jan Ysselstein
Jan Ysselstein Posted June 19, 2015 Author Posted June 19, 2015 (edited) A set of crucibles to be used in the next sequence has been fired. There are now five shapes, I have tried to reduce the effects of porosity by making the walls heavier. Small cone, same as in ingots one and two about 800 grams of iron Large cone similar to #2 but much larger about 1500-2000 grams of iron Puck type same as #8, #9, #10, #8a and #8b about 1200 grams of iron Puck type with softly rounding bottom edge as shown in the paper a few posts prior ( http://www.academia...._FS_Weisgerber_ ) ( I only have a few of these, so things must go well ). A round bottomed crucible for comparison to #2. probably 1000grams to 1200 grams capacity...this shape is easiest to make and would make my life much simpler. One can imagine a slight advantage to the Konasamudram shape but it is a bit of a stretch and lots of imagination. This is however the only shape related to this particular topic..the others , though interesting, only provide information needed for contrasting the results. Melting should start in a few days. Jan Edited June 19, 2015 by Jan Ysselstein
Jan Ysselstein Posted July 12, 2015 Author Posted July 12, 2015 (edited) As I examine all the bars made during the start of this thread, I am experiencing some difficulties in getting a balance of large and small cementite particles. Breaking up large cementite fragments into smaller ones (say 1/10th the diameter ) will create a much different appearance....many points of light. I think a volume of material when divided into smaller particles 1/10th the diameter will create a 1/1000 ratio...very much worth the effort. Looking at older bars to use for experimentation, I ran into an ingot fragment ( and a bar fragment) from my very first ingot ever ( what luck) and it seems not much progress has occurred . Here are some pics of that bar ....."dendrites superimposed onto distorted dendrites" Dendrites of Ferric Sulfate partially rinsed off , over my very first wootz bar , dark areas are the bar Bar area without the Ferric Sulfate pattern on its surface. Jan Edited July 12, 2015 by Jan Ysselstein
Jan Ysselstein Posted August 13, 2015 Author Posted August 13, 2015 (edited) "Todays melts were a bust..ingot8c is a belt buckle type disc,,the crucible developed a big hole and most of the metal just poured out ( It was too hot..the crucibles have a temp limit)." The above description is of a wootz ingot which did not make it. Yesterday I repeated that process (almost) just to make sure it still worked and it did. In an attempt to make cast steel, close in composition to W-2, the crucible stand failed and dropped the crucible low in the furnace. I noticed it when I was about to poke the furnace to see if all was liquid. I ended up pulling the crucible and placing it onto the dirt and letting it cool ( very rapidly ). The ingot is gassy but seems homogeneous and I should be able to weld it shut. The reason for inserting this W-2 steel experiment into the thread is (I need the w-2). I have found the disc belt buckle created by the "above incident" and hope to fold up some high carbon steel from both incidents ( and stay above .6% C ). This steel (W-2) requires my little furnace to go to about 2700 F and it is not really made for that. Tomorrow I will duplicate this test (successfully I hope) and again try to make some very clean W-2. Should be able to add some pics later but here is the crucible just pulled, sitting on the dirt. Edited August 13, 2015 by Jan Ysselstein
Jan Ysselstein Posted August 15, 2015 Author Posted August 15, 2015 (edited) I now have two ingots,gassy ( large bubbles), but homogeneous steel....... and one disc "lens" at who knows what carbon content. Today I will attempt to repair my stressed furnace and go for a good ingot at the same carbon content as the two gassy .85% C ones. The gas problems are being caused by me ...I should be able to get a good ingot today if all goes well. Melting steel requires a little practice each time...one does a series of melts . The required temperature will be about 2750 Deg F or 1510 Deg C . This steel making material will be pulled into its own thread after this post, under the topic "experiments at the forge". I will get some pics when I get the camera charged and unloaded of the current pics. Jan Pic of second gassy ingot cooling quickly in a SS beaker on dirt. As I will be looking for Hada and Hamon in this steel..slow cooling gives me no known advantage ( though I have looked at some wootz bars- clay quenched, their hamon looks really good). The arithmetic is; 1 part smelted cast iron at about 3.4% C 3 parts smelted bloom at about "0%" C Should equal 4 parts of homemade steel at .85% ( plus Gas ) and micro alloying ( no Manganese ). Edited August 16, 2015 by Jan Ysselstein
Jan Ysselstein Posted October 12, 2015 Author Posted October 12, 2015 (edited) The last two posts should not be here but in the Hamon thread ..they are a bit relevant here as I try to melt, not cast iron as usual, but steel, and will need a higher temperature system. Here are a couple of relevant pictures indicating the chemistry of the atmosphere in the crucible above the slag/flux layer. The dissolved oxides ending up in the slag layer react with the carbon in the melt creating gas and prils of iron. These little droplets are usually of lower carbon content than the melt itself. The two photos show prils in 1) an oxidizing and 2) a neutral or reducing atmosphere. I am attributing the difference to a better glaze on the fire side of the crucible. Note the moonscape on the second picture indication not only prils but droplets of slag are flying around. I hope to start melting as soon as the rains come back to the West Coast. Jan Edited October 12, 2015 by Jan Ysselstein
Jan Ysselstein Posted November 17, 2015 Author Posted November 17, 2015 (edited) I am trying to get my head back into this topic, here is where we stand on the first sequence of melts. #2 has potential and will be duplicated in the next melt series #5 is an ingot somewhat unrelated but still in existence , Here are my notes on the test " "Kos #5 is a crucible test 1000 grams of anchor chain was heated for 1 hr with 25 grams of carbon, no glaze , no glass , furnace cooled. #5 is very rough looking top 1/2" og ingot needs to come off and remnant should be forged." #8 gave a beautiful even pattern, this is the one closest to my ideal ( for now) I still have the bar #8a gave a dramatic very strongly dendritic pattern in the central region of the long bar ( I still have it ) #8b is not uniform, some areas look like #8, I will start by attempting to forge #5 after cutting off the top, then plan the next series of melts. The next series will be lower in carbon content. Bar #8 needs to be reetched and photographed. Jan Ingot #5 on the right ( shown upside down) ( he has only one eye, but he is smiling ) Edited November 17, 2015 by Jan Ysselstein
Jan Ysselstein Posted December 1, 2015 Author Posted December 1, 2015 (edited) The ingot on the right above is ingot #5. ( a crucible test)..I have ground off the top irregularities and find the ingot quite porous. The pattern when etched is interesting and that alone makes it worth forging. This ingot does not seem to be made of cast iron but a carbon composition just below cast. Here are some pics. Ingot Kos#5 with top removed ( the bar is related to another post ) Ingot Kos#5 showing porosity Those are not dendrites Self portrait in the lower left side, I have been waiting for this to appear What seems to be several structures Jan Edited December 1, 2015 by Jan Ysselstein
DaveJ Posted December 6, 2015 Posted December 6, 2015 the self-portrait is great, it reminds me of an old ink and brush style painting... Davej - Crossed Heart Forge * islandblacksmith.ca * instagram * youtube
Jan Ysselstein Posted March 29, 2017 Author Posted March 29, 2017 (edited) I had forgotten this thread existed, the time is right for getting back to it ( for a week or so). I took an old random wootz sample and wanted to do a DET to disperse the cementite throughout the bar....I normally do this by just heating the bar and leaving it in a sealed ( closed) furnace......the furnace has some heat mass but not much. This time I did it after rebuilding my furnace and it seems the furnace was either too hot and or cooled too slowly ----I got a granular structure. I don't think I will change it but will try to cycle some more at lower temperatures . I have started to plan for some crucibles and have the forged bars of ingot #5 ( above) ready to final forge and heat treat, Ingot 5 was forged as a bar longitudinally ... the cone tip is one end and the flat top is the other end of the bar ( the top of the ingot had to be removed). Here is a rough picture of the structure on a 2mm field. Note there is no obvious dendrite related pattern visible ( I hope I have not lost it completely). Edited March 29, 2017 by Jan Ysselstein
Jan Ysselstein Posted September 20, 2017 Author Posted September 20, 2017 Having been away from this topic a while means there are new ideas to test and old attempts to repeat. This week I will start melting a series of ingots with slight variations of a few variables. Basically a greater emphasis on successful ingot forging ( no more cracks) ...as that is one of the last steps after a major investment of time and money into getting to that point.
Charles dP Posted September 29, 2017 Posted September 29, 2017 Wonderful work Jan. TBH, I wish I understood half of it . "The way we win matters" (Ender Wiggins) Orson Scott Card Nos qui libertate donati nescimus quid constat
Jan Ysselstein Posted September 29, 2017 Author Posted September 29, 2017 Charles, I do not understand it myself and do these experiments to learn about iron and steel. As the "Student" I have created a ferrous metallurgy lab class for myself and it has been a great experience . The problem is, each trial requires a lot of materials/time/expense and often result in "failure". This particular topic is a bit challenging because so much can go wrong. I am pretty confident I can do it , if I cannot, we will let one of the "Masters" show us how. Jan
Charles dP Posted September 30, 2017 Posted September 30, 2017 (edited) Someone (Edison perhaps) said that a failure is simply learning another way of how not to do something so you will eventually find the way to do it. Edited September 30, 2017 by Charles du Preez "The way we win matters" (Ender Wiggins) Orson Scott Card Nos qui libertate donati nescimus quid constat
Richard Furrer Posted October 3, 2017 Posted October 3, 2017 On 9/29/2017 at 5:10 PM, Jan Ysselstein said: Charles, I do not understand it myself and do these experiments to learn about iron and steel. As the "Student" I have created a ferrous metallurgy lab class for myself and it has been a great experience . The problem is, each trial requires a lot of materials/time/expense and often result in "failure". This particular topic is a bit challenging because so much can go wrong. I am pretty confident I can do it , if I cannot, we will let one of the "Masters" show us how. Jan I would like to talk to some of these masters.......I have questions as well. Ric Richard Furrer Door County Forgeworks Sturgeon Bay, WI
Jan Ysselstein Posted October 3, 2017 Author Posted October 3, 2017 Ric, We will just keep chipping away until we get it....I am sensitive to he use of "Master" , I have only known 2 "Masters of their trade" and they were very exceptional people....one a blacksmith ( my teacher ) and one was a ceramic artist. Jan
Jan Ysselstein Posted November 29, 2017 Author Posted November 29, 2017 (edited) Ok here we go again, Pendray's video has given us some clues and why not try it. One of these pictures belongs in the what did you do in your shop thread but I will just put it here. I did a melt of iron and cast iron ( all made here ) and it looks OK, I have little tabs all over the surface and am not sure why. Here is a picture of the just made furnace in use and a picture of a furnace shell made from castable high alumina for another day. The ingot made is a Southern Indian crucible shape..we will change over in a few days. Edited November 29, 2017 by Jan Ysselstein
Jan Ysselstein Posted November 29, 2017 Author Posted November 29, 2017 (edited) I have added a pic of the ingot and asked forensics to help me state what went wrong. The ingot weighs 200 grams less than the contents. I have been told the slag ate the crucible wall at the slag level prior to the incorporation of the large chunk of low carbon iron. The iron ran out of the hole..this was the first to melt material and it was very high in carbon. Now my ingot is of lower carbon content than I planned. The good news is ..may furnace is capable of melting 1% carbon steel as well as 1.5% carbon steel. This is a new furnace and performance will decrease as time goes by. I did notice some sparks during the run , I assumed they were from the SS air/gas inlet. Edited November 29, 2017 by Jan Ysselstein
Daniel Cauble Posted November 29, 2017 Posted November 29, 2017 Im right there with you Jan! My Youtube channel: https://www.youtube.com/user/TAGMushy/videos
Jan Ysselstein Posted December 5, 2017 Author Posted December 5, 2017 (edited) Today I ran an ingot of high Phosphorous..high phosphorous will result in about .05% P so I will have 0.0% P, .05% P and two ingots of .0125% P ...if all goes well. So far so good, the ingot is solid, sparks high in carbon. I hope to do another melt tomorrow forging them all asa group. Just over 800 grams in weight. I have not looked for crucible defects yet..though there was no failure, I want to know if we were close to failure. Only the 0.0 % P ingot is 100% homemade iron the rest contain various amounts of wrought . Edited December 5, 2017 by Jan Ysselstein
Jan Ysselstein Posted December 12, 2017 Author Posted December 12, 2017 I now have 3 ingots giving a spread of P content. I should be forging my bloomery iron to refine it and remove more slag ..that slag is creating a black/gray glass which reacts with the metal and the crucible wall. I will melt 1 more and start forging.. the last two were adjusted for carbon ..I brought the cast iron up to about 50% of the charge.
Jan Ysselstein Posted December 12, 2017 Author Posted December 12, 2017 (edited) The last ingot has ben pulled from the furnace, it has a few pits, not too bad ( 1512 Grams before grinding surface). I now have 4.5 ingots ( one ( the defective one ) is missing? ) to experiment with. Forging wootz is my weakest skill in the sequence of steps to a blade. This series of ingots is lower in carbon than what I am familiar with. Making this set has given me back some familiarity with melting and made me comfortable again around that type of noise and so on. The process I am hoping to do will require a different crucible shape ( I have them ready ) and produce a different shape of ingot. My ingots will be a bit convex and about 3" diameter 1" thick. Before I start the next series of ingots ( convex lens ingots) I will attempt to forge what I have in ingot form. Just doing it for practice. I melted 4 ingots using one 10 gallon tank of propane and have enough left for a preheat of another ingot. Edited December 13, 2017 by Jan Ysselstein
Jan Ysselstein Posted December 16, 2017 Author Posted December 16, 2017 (edited) I am going to try to determine the high temperature of the furnace during the melting process....My 2600 Deg F bricks are melting and shrinking ( I will post a pic later ). I am assuming I am somewhere above 2600 ( say 27000 Deg F.) . I want to be able to go to about 2850 F ( 1566 Deg C) .. I have an optical pyrometer and do not have total confidence in the readings, I would not mind getting a pyrometer reading confirmed by some physical phenomenon..so I will look for events that occur when a material reaches 2850Deg F . If I cannot get much higher than 2700 F I will start a preheater build for the air supply. I will start looking at some polished ceramic samples to see if ceramic structures are a good indicator of temperature. I suspect they are and that my limited knowledge is too remote from being able to use it. Edited December 16, 2017 by Jan Ysselstein
Jan Ysselstein Posted December 20, 2017 Author Posted December 20, 2017 (edited) The ingot pulled Dec. 12 looks good, I made a "standard ingot today an easy to repeat small ingot made so I can compare results of chemistry changes. Yesterday I made an ingot ( only 1/2 of it can be forged) using the larger crucibles, ouch! The ingot is about .3 to .4 % carbon..though I am glad to be able get that hot ( over 2700 F ) I am not happy with the ingot and the failed crucible. The little standard ingot made today is a jewel. I do not seem to be plagued with oxidizing slag today . Here are some pics...I now have 5 good ingots to forge two failures.. ( one earlier failure I did not bring up as I did it to myself). Out of 8 runs I see 5 with potential and 3 scrap metals. My success rate is 62%....and I lost a lot of propane staying at 2700 F. Small ingot 713 grams Top of the small ingot Small ingot and Dec 12 ingot Failed ingot .3-.4% C Edited December 20, 2017 by Jan Ysselstein
