The crucible furnace has been demolished because I thought it was done ( major mistake )  ...I will make another one. I have 8 pieces of metal to forge , all of which are lower in carbon content than what I used to make in my previous life. I am expecting one ( the last one to be forged ) to hurl me into the past..I may already be there by the time that last ingot comes around.  I am still hoping to find the missing ingot ( failure, full of holes ) to see if it will offer any info.
In the picture below are from left to right, ( in the order in which they were melted )
Low P, High P, MedP, Large Med P, Failed FlatMed P, Failed Flat Med P,  Standard Med P, and Standard  Med P.
Edited by Jan Ysselstein
It is rough go at the start here ..I am experimenting with some of Al's advice. I may have to go for a decarb layer just to be able to weld a rod to the ingot. I dropped ( bounced ) a hot ingot into my water bucket and took forever to fish it out with the tongs. A few cracks but I will forge as long as I can before discarding the ingot. I need to get a better microscope connected as I am seeing cementite convert to spheroids but I am not sure what percent of the material is doing this ( they are occupying the same area). It will take me a few weeks to get through this batch.I am currently trying to forge MedP smaller ingot.
There are now 4 pieces of steel left to forge. All the ingots seem to have a number of small gas pocket in them...these become cracks during forging. Left the forge and it just kept getting hotter and hotter...my big ingot cracked.when I put it under the hammer....very annoying but I will make some lemonade from that. I am still chipping away at the first ingot ...though badly peppered with holes I should end up with a bar. I will remake my furnace this week end and create a few more ingots without bubbles ( I hope). I am looking at adding a simple controller on my forge...it is hard to stand there all day monitoring the temps. Here are some pics.
The good new is ..I have gotten my forging routine back and if I can stay alert I should get some bars ( imperfect as they may be ).
First ingot hammered from the top, about to turn it sideways and draw it out.
One discard for lemonade and one hoping to make it all the way....things are starting to click. I am keeping records of the  microstructure from as cast through the various forging stages.
That ingot on the left will not be making it..I will cut some fragments to see if I can observe the movement of the highly dendritic pattern. Now I am down to 4 ingots, the High P will be forged next. A set of 4 crucibles have been prepared for the next run. I will try to measure some temps next time as I am thinking I am running too hot and my glass is not the right chemistry. I need to conform my forging practice closer to what Al is suggesting ( such an impatient wootz maker) ....I think I am reheating sooner than Al's suggestion because that ingot looks cooler than it is.
Have I learned anything from this disaster and was it worth the effort ?    YES,YES!
Below is a pic of the flat ingot ( cut in half ) now discarded. This is a carbon network which only partly shares location with the dendritic network which can be seen by thermal cycling.
  • 5 weeks later...
The high P ingot is the only ingot with low number of voids...I was able to forge about 1/3 of an ingot to about 3/16". The dendrites are becoming very distorted , this is a picture of one of the few still recognizable . I am quite pleased with the developing pattern. The austenite etched pale color indicating the carbon there was in spheroidal form.  I do not have a camera right now but will post a photo once I am done messing with this piece.frame8.jpg
Posted
That is about as far as  can go with the sample I have thinned it as far as I can..now I need to move the cementite to spheroids and see how much that will change the pattern..I have not yet manipulated the surface for effect.frame17.jpgframe6.jpg
Posted
I have tried to dissolve most of the cementite while trying not to lose to much carbon from the surface. I did not get it all, the hotter areas of the sample seemed to have more cementite missing. Now I am accepting a low level of residual cementite particles and am going to try to move the carbon to the areas having the micro alloys.
The areas in the pictures that are now white should turn dark ( pearlite)
The areas that are now dark will become bright and full of spheroidal cementite ( I hope).
My sample is approaching the thickness of a sheet of paper.
This is very exiting.
Posted
Hi Jan
Just spent free moments over the past two days reading this thread, I also do not understand even half of what I would like to, but I find the whole topic so fascinating I wish I could look over your shoulder for the whole process!
Thank you for taking the time to share.
Thanks guys, looking over my shoulder would be shocking, as the process is quite crude. The above bar was forge welded once ( onto itself) to maintain thickness , the weld is good .
I am dissolving some cementite in a gas forge..so I do keep an eye on the temperature with a thermocouple. In the above case , I soaked the bar for just under an hour at about 950 C..pulling it out every now and then and fluxing to avoid carbon loss. That worked quite well where the surface was clean and not scaled. Next time I will soak to dissolve for two hours in a protective piece of tubing or heat treating foil. Growing spheroidal cementite is a charcoal forge method all done by eye and a Magnet with careful control of the air flow.
Growing the spheroidal particles is a skill I am trying to learn..slow is good..slow is very difficult for a person living in the digital age.  Another skill I am hoping to learn, is to quench to Bainite  and or fine pearlite..... No salt pots.
There are some forging methods available that may eliminate the need for this loop but I have no ingots to forge this week.
The new furnace shell is done and I will melt more iron next week.
I just remembered I do have another bar to take through the pattern developing process, it is this one...
I will weld it by folding once and forge it..and try to get it into a state of Martensite, Bainite , Fine Pearalite or a mix of some of  these.
Now going back to the sample above. An area of the sample did what I wanted to but some off the surface has not converted. The pictures below show a fine cementite ( spheroidal ) structure and a background etching black. Back to the books to see why. Now it is getting really thin and I will abandon it.
In a day or two, I will forge weld the above bar ( same as shown in these pics) onto itself ...two 4" long pieces...welded and forged into a bar about 12" long. I could just forge out what I have as it is about 3/16" thick.....however I have a blade I would like to be inspired by and it will require me to use the pretty surface of this bar as the welding surfaces ( high risk behavior ) and to have the rough pattern become the exterior surface(s). I think the pics will explain my thinking. The spheroidizing will be done  using the DET ..I will try not to grow large cementite during forging. The last picture ( the blade ) is the one I think is similar to in nature to the two pics above it. The blade picture was provided by Jeff Pringle.
The forge welding did not work on this sample for reasons I am not sure about. Now we will have to find out why...I have welded it in the past and just recently. I really do not have enough material to take this detour right now, however my plans depend on being able to weld this material.
I will play with the remnants ( this is all I have that I am willing to gamble with)  to see if I can get anything worth looking at..I should be able to weld something here if I have enough material.
Posted
Bummer. I was really rooting for this one too. Watching your progress is both motivating and scary at the same time. I feel your determination and I so want you to succeed.
Posted
Thanks Josh,
Things are coming together..I will use the above twisted bar to confirm the heat treating sequence. Things are looking good for wootz.
Posted
The twisted bar sections are very thin and I do not think I can take them through the whole heat treating process. I did run into a piece of bar #2 from very early on in this thread..I am posting pictures  of a relatively small area of number 2. These edges were heated the most both during the quench and during the thermal cycling....it looks like the TC is working. Most of #2 still has a lot of large cementite which I will try to displace.frame3.jpgframe5.jpgframe7.jpg
  • 3 weeks later...
Posted
We are up and running again...I have made some charcoal ( Pit Charcoal Thread) and plan to smelt tomorrow ( inside the shop). I am in the process of making an improvised propane fired tempering furnace ( should be able to hold 21"long material )  controlled by a digital controller.  This furnace is 10" in diameter while my forge is 6" in diameter. I bought a point and shoot and will be able to better document the details. The crucibles have been fired and are ready to go....most of the work now will concentrate on duplicating some of the results from ingots 8 through 10 above with less forging trouble.
  • 3 months later...
Today I had the chance to test the new crucible shape, using older crucible steel bits. The new furnace is not holding up and will be replaced in a day or so. All in all I think the melt was a success even with the persistent crucible porosity problem lingering on. Here are some pictures of the event. I attempted to create a sealed crucible which I could open during the melt...that did not go as planned and will be attempted agin later.
Today I will try a furnace patch and prepare the next crucible ( duplicate of yesterday's ) ..I will hold for 1.25 hrs at heat rather than the 1. hr yesterday.....that should remove the gas. Both crucibles are remelting older crucible steel bits( broken blades ).
Edit:  The furnace has ben patched and should be good for another run or two.....the crucible is loaded,  sealed and plugged like the one shown above. There is no added glass in these crucibles..just a bit of carbon and silica.  We will try to run very hot. The last two runs were done on a 5 gallon propane tank by running hotter I may have to burn a bit more. The picture below shows the ingot melted prior to using the large "flower pot" crucibles.
Today's melt went very well...the cake is lenticular with a smooth very thin low carbon top surface ( no glass was added ). The weight of the cake is about 1200 grams. There is an area about 3/4" x 3/4" near the edge which is standing above the rest of the surface by about 3/8" of an inch. I have attributed a cause and should be able to avoid it next time. The cake looks very solid and will remain intact until I have forged related samples. We now have 3 related samples and will have a look before proceeding with more melts. I will start the next batch of crucibles and will add a bit of thickness to the walls.
As soon as my pictures are available I will post a few.
Posted
Cool stuff Jan. what do you think caused that lump? Was it near the tuyere?
Posted
Charles , I poked into the crucible ( no tuyre  ) several times and used the same metal tip which was burning when pulled out of the melt ...that oxide gave me some bubbles and the lump. I removed it just now and found a few bubbles which should not give me much of a problem.  It is amazing to discover that though you are going flat out the material is just barely liquid.  I am very exited at being almost finished with this topic..Hoping to let it go in a couple of weeks . The low carbon top surface captures the bubbles and they cannot get out from under...I will try to carburize the surface layer next time just before pulling the plug and beginning the furnace cool down.
....then back to other topics .
