Homage to the Vehmaa sword
This is the story of a sword. The blade began as a little seed in my mind after reading the book “Swords of the Viking Age” by Ian Pierce. As I turned pages 148 and 149, very much at the end of the book and having already seen many photographs of wonderful pattern-welding, I was stunned by two photographs depicting a sword found in Vehmaa and dating to the 8th century. My first impression looking at the photographs on both pages is that I was looking at two different swords but reading the brief notes I was further shocked in realizing that it was only one. Ever since I saw that blade I wanted to try and figure out how the pattern was created.
That was many moons ago. Then going back some three or four years I saw Jeff's repair on the handle of a Viking sword and that sword and another were shown at Fire&Brimstone. When I held the one blade with the Petersen L morphology, I felt a more compelling need to try to make the Vehmaa sword.
petersenL.jpg-nggid041155-ngg0dyn-0x0x10
It took me the best part of a year of on and off reviewing my original notes on the pattern and developing new ideas to sort out how could it be re-made. Aided at times by a 3D CAD program to determine the composition, layer count and arrangement of the rods, I was able to figure out the individual patterns but not quite able to determine how where they put together and the transitions from one pattern to another realized. One day when I least expected it, I came up with a plausible solution and even if it is not how the original was made, I was happy enough with the plans to make some billets and get ready to test my thoughts in the fire.
m1.jpg-nggid041143-ngg0dyn-0x0x100-00f0w
I used 1095 and 15N20. About 6 kg of steel to begin with and run the tests I wanted with enough material to spare. I made core rods and edge rods. The edge rods were 1095 and W2.
m3.jpg-nggid041145-ngg0dyn-0x0x100-00f0w
The five rods that were to become the core of the blade needed to be twisted and/or manipulated to very precise dimensions. The day I did the twists I had two pages of carefully detailed directions as to where to start and stop each twist and how many turns to do. It was nerve wrecking as any one single mistake would have thrown the pattern off. Everything needed to line up as close to the layout directions as possible.
m4.jpg-nggid041146-ngg0dyn-0x0x100-00f0w
The next issue was to figure out how much material to remove from either side to expose the pattern exactly where it was intended and for most people who have done this, they would realize that the pattern is shown at different depths on different sections on both sides of the blade.
m5.jpg-nggid041147-ngg0dyn-0x0x100-00f0w
m6.jpg-nggid041148-ngg0dyn-0x0x100-00f0w
The most dificult weld was the last. Attaching the wrap-around edge to the core had to be done when the billets were ¼” thick and there was no wiggle room for any offset as it would simply ruin the carefully develop pattern.
m7.jpg-nggid041149-ngg0dyn-0x0x100-00f0w
Unfortunately, the first sword did not show the correct patterns after grinding as a result of miscalculating the depth. The blade was very interesting in itself but not was I was going after. So a second blade was started and with the gained knowledge from the previous one, the patterns were pre-arranged where after grinding they will show at the correct depth.
m8.jpg-nggid041150-ngg0dyn-0x0x100-00f0w
So now it was on to profiling on the grinder and heat treating. The blade look really pretty dressed in its tempering colors.
m9.jpg-nggid041151-ngg0dyn-0x0x100-00f0w
But it had a little bit of a warping towards the point which I tried and tried to straighten at tempering temperature for a couple days. Finally I thought I had straighten it just to come in the shop the next morning and see that that curve had come back to some degree after cooling. I thought that it was such a little curve that I put it in the vise cold and tried to fix it. The blade broke in two.
m0.jpg-nggid041142-ngg0dyn-0x0x100-00f0w
Too bad as the pattern was for the most part there. The serpent section was not as tight as I wanted but everything else was right on. The next week instead of feeling pity on myself I went back to the shop to make a new set of billets for a third attempt. Although for a day or two I did walk with my head down.
Third time’s a charm. I had the sword I wanted with the correct amount of tightness for the serpent and although one of the chevron sections did not have the correct spacing, it was close enough. I was not planning on hilting the blade or making a scabbard but I needed some sort of sheath to keep the blade in so I made a wooden one and it looked so nice that I was compelled to finish it with a leather wrap and lambskin liner. At that point there was no turning back from making a hilt for it too.
m10.jpg-nggid041144-ngg0dyn-0x0x100-00f0
The blade itself is 950 grams and the length without the tang was 32 ½”. Width of 1 7/8” at the base and tapering from there. Polishing the w2/1095 edge to show contrast was a bit tricky and ended up using a method similar to the Japanese polish for the edge.
I had a smile on my face when it was finished.
sheath-and-sword.jpg-nggid041152-ngg0dyn
aaa.jpg-nggid041133-ngg0dyn-0x0x100-00f0
aa1.jpg-nggid041129-ngg0dyn-0x0x100-00f0
aa2.jpg-nggid041130-ngg0dyn-0x0x100-00f0
aa3.jpg-nggid041131-ngg0dyn-0x0x100-00f0
aa4.jpg-nggid041156-ngg0dyn-0x0x100-00f0
For those interested in trying to figure out the pattern-welding, the following two images are composite images made in Photoshop by combining many sectional pictures. The proportions of the handle and blade were a bit deformed by the program but the pattern is more easily discerned.
side-A-med.jpg-nggid041153-ngg0dyn-0x0x1
side-B-med.jpg-nggid041154-ngg0dyn-0x0x1
My respect for the smith who made the original sword is enormous. I don't think that I actually followed the process that he used to make his sword in making mine. He knew what he wanted to do and how to do it. Thanks to all my friends that help me in one way or another through questions and answers on the making on the different parts of this blade. You know who you are.
This is such a beautiful sword to see being built on here and even better in person. Masterful work Jesvs.
Amazing piece! I am in awe. Your incredible patience and perseverance is commendable and every part of this is fantastic. The scabbard and hilt are a fine complement to this stunning blade.
Edited by SBranson
What a great journey toward a marvelous sword!
You should be very proud of this, Jesus. I greatly admire the persistence, patience and dedication you've shown in pursuing this re-creation.
Inspiring!
Dave
stunning sword. The closeness of reproduction is .. more than impressive. I am very impress with the control of pattern that is shows .. your beard is clearly still burning brightly my friend!
MP+
Fantastic work Jesus! And I whole heartedly admire your perseverance. I can only imagine the headache of having a break that far along in the process, and on a piece so complex none the less. Glad you decided to hilt it after all! The simple elegance compliments the beauty of the blade well B)
John
Wow! That is an amazing sword, and the pattern welding is so good it makes my brain hurt trying to figure it all out. I like how the serpent starts in dramatic waves, and subtlty tapers into the more gentle curves, It really gives the pattern more of an organic flow.
wow. I now understand why you thought it was two different swords. Very good work, Jesus. Great persistence, too! Tell us a little more about the sheath. the story of the blade was so good, I am not ready for it to be over yet. very worthy accomplishment. Hat's off, so to speak.
kc
That is an incredible piece of work. I've speculated that the original blade was made to give the smith bragging rights of a "look what I can do" nature... you sir have earned those bragging rights.
Thank you, guys. I appreciate the comments. I wish I could had made a hilt like Jeff or Petr, this one is rather simple but hopefully suits the blade. The texture of the hilt components was a delicate and slow work made with a small textured punch. Hard to keep the punch perpendicular to the curving surface. The scabbard is alder wood lined with lambskin and wrapped in leather. I found a thin piece of leather from Europe that was very clean and easy to mold to the wooden core. The rest of what you see is tooling of the leather and staining then rubbing off the high spots.
Wow! Incredible work! Wish I could have made it to F+B, just to see this in person would make my year!
