Started a sword!
James R.Fuller
I have been dying to make a sword, so, here I go. It is 1095, about 2' 7" long, and only roughly forged out.. Let me know your thoughts! :)
-=JF=-
Oh yeah that is a beautiful shape! Really great lines and the shape is very reminiscent of originals, from the shape of the tang to the way the blade tapers in profile. What does your spring fuller look like? I can't quite tell from the photo but the fuller does go into the tang I'm guessing?
Your forging is very clean and will leave you little grind work later on down the road! I need to work on that :rolleyes:
I will be watching this with great interest! I'm excited to see the plan come together for the hilt, great work! :D
Here is a picture of my spring fuller. I got the idea for forging it out like this from my good friend, John, when I mentioned wanting to forge a fuller when I don't have a welder to make a fullering jig... I started the fuller by doing a very rough go with an angle grinder and then smoothed it out under the spring fuller.. Saved me a crap ton of time... Well... At least 2-3 hours..:P
-=JF=-
Oh man that is a really clever way to make a spring fuller! Good thing about the distance going into the tang, too.
You should make it a type H, a strong classic design that never fails to evoke 'viking sword'
Ok.. So I drew up a general look... But I'm not sure on it... I like the type H fittings, but I also want a longer handle... So I combined them, gave it a bit of an artistic flare, and it looks pretty good (is there a type for this design...?). I'm just not sure if it is.... Right.... Feedback, anyone?
-=JF=-
I would go for a shorter handle, personally. They were usually shorter in the originals, and I think it makes for a better grip one-handed, with the ability to put the second hand onto the pommel when needed for full-power. Most of the fighting was done with sword and shield, so only one hand was needed for the grip.
Otherwise, looking good. The fuller was a great idea. Never seen one made that way.
kc
Kevin, I like the idea of doing it more historically accurate, but I also personally like the feel of a longer handle. the more I look at this general design, the more I like it. I'm probably going to go with a longer handle this time, and make a much more historically accurate one next go around.
Michael, my bad! XD I simply forged the scroll into either end of a piece of 2" wide, 1/4" thick 2' long bar stock. once I had that, I just heated up the center and bent it... Since I only had mild laying around, I didn't heat treat it. Forging a scroll like that was surprisingly easy, the whole piece only took me about a half an hour.
-=JF=-
  • 1 month later...
Perhaps you could try making a wooden mock up of the sword before you commit to the long grip.
You have done some great work with the blade so far: good shape and proportion.
It seems to me a pity to make a grip that is overlong for this otherwise very promising project.
This is partly a matter of personal taste of course. But it will have an effect on the character of the sword, and not only aesthetically.
I a feeling that you may not find a proper, shorter hilt length to be a bad thing if you tried it. Especially type L hilts with their curving upper and lower guards work really well with short grips, and need short grips, in my opinion. For these swords the tight grip is actually an important functional property. A longer grip often interfere with handling in a way that is not good. To my experience this kind of wide pommel does not work very well with long grips. To make it work you have to change things around so that you have a high medieval arming sword dressed up as a viking period sword.
I would shorten the grip with a third of the length you have in the sketch, for starters.
-But that is me :-)
Looking forward to the progress of this either way you choose to go.
the new fitting idea looks promising. Looking forward to seeing what you do with this one.
kc
Peter, I appreciate your advice on this. In the revised drawing, the handle is only about 4" long. Is that still too long? I decided that the longer handle would look just... Wrong on this sword.. So I redesigned it to be a much shorter grip.. Just large enough to fit my hand.. Should it be shorter? I have heard of people
Making sword with 3" handles, but that seems as if it would
Be incredibly small...
Edited by James R.Fuller
-=JF=-
From personal experience a handle that fits the wielder's hand snugly (without being uncomfortably tight) is the optimal choice when fighting. Giving the wielder greater control of the sword without the risk of the handle slipping in their grasp.
Hope this helps with your decision.
