This project began as a personal challenge and an exploration of the beauty and symmetry that can be found in the sankaku style yari. The cross section of the blade is triangular in this style, the spine quite thick and strong, and the tip is centered on both axis. The basic form is fairly defined, but there are several historical variations on the lengths of the blade and tang as well as the style of sculpting the neck area.
Historically, this type of lance would have been mounted on a sturdy hardwood pole about two metres in length, though there were examples up to six metres for defense against cavalry. The top of the pole would have a lacquer finish, several iron bands, and a strip down each side, and like a tanto, the yari would have a copper habaki and a bamboo peg through the tang to hold it in place.
(click the centre photo to see the hada in more detail...)
Blade construction is muku with a sankaku profile and a raised/centered tip.
The blade is approximately 7.5″ long, the tang is 10.25″ long, and the overall length is about 17.75″.
Specifications
長さ/刃長 Nagasa: 6 sun 2 bu 7 rin (190mm)
元幅 Motohaba: 9 bu 3 rin (28mm)
重ね/元重 Motokasane: 2 bu 8 rin (8.5mm)
反り Sori: straight
中心/茎 Nakago: 8 sun 5 bu (258mm)
形 Katachi: sankaku
刃文 Hamon: suguha
帽子/鋩子 Boshi: ko-maru
中心/茎 Nakago: kaku, no mekugi-ana, signed midway
銘 Mei: hot stamped katabami-ken kamon
read more: islandblacksmith.ca/2015/07/hatsu-sankaku-yari/
"Appreciation for detail in everyday utilitarian objects is one of the elements that shows up in traditional Japanese craft. Historically, this was expressed by attention to the precise development of form, line, and detail, and is found even in components or areas that were hidden from view or secondary in importance."
This yari is made from reclaimed shear steel from a horse-drawn carriage axle. The axle has evidence of forge welds on it and may have been repaired by a blacksmith at some point using locally available materials. The blade was hand forged in a charcoal fire, shaped with files, differentially hardened using traditional water quench yaki-ire, and polished by hand with water stones to reveal a suguha hamon and a subtle hada.
On the left a horse-drawn carriage axle, in the foreground a forge weld where a last-century blacksmith joined the stock hubs to a length of available scrap to complete or repair the axle. While most stock axles in this era seem to be mild steel or wrought iron, a break test indicated the centre section to be in the neighbourhood of .5% carbon and possibly shear steelabout half (~4″ x ~1″ square) of the segment on the right was used for this project.
The sunobe begins to take shape, allotting material for the tang and the blade. A neck forged and then cleaned up by hot filing at the vice with a rasp while at a red heat.
After the final rounds of forging. At this point it is about 18″ long, drawn out from the original 4″ bar. This type of yari has a sankaku (triangle) cross section so the back is flat and the spine is quite thick.
Filed and drawfiled in preparation for the traditional yaki-ire method of hardening using clay, a charcoal forge, and water. Note that the flat back curves up towards the point to centre the tip.
The dried clay mask just before yaki-ire. The thicker clay slows the cooling while the thin charcoal-rich clay speeds the cooling causing a very hard edge to form while the body stays tough. Note that the centre spine is also exposed near the tip so that all three leading edges are hardened there for a distance.
Showing the comparative size and shape of the same volume of steel at different stages from the original axle section at the top, pre-sunobe, and just after yaki-ire at the bottom.
Cutting dry with a very coarse diamond stone to true up the flats after yaki-ire and then down through the grits with water on the stones. At the coarse stages the blade moves perpendicular to the stones and for each new stone the scratch pattern angle moves closer to parallel (eg. 90 degrees, 45 degrees, 20 degrees) and then all the rest are at 0 degrees, along the blade.
2015-sankaku-yari-18-narutakido-stones.j
Beautiful natural stones from Japan, I received them in fairly raw form and chiseled and chipped them into useable flat block shapes and saved the chips for making fingerstones. To make the hazuya and jizuya stones I flatten one side of the chip on a diamond plate and use natural urushi lacquer to paste on a piece of washi paper for strength, then when dry flatten the other side and cut to shape. The stone powder from flattening will go into the clay mixture for yaki-ire, "clay tempering" and into an uchiko ball for removing old blade oil.
The final stages take as long as all the previous stones together and involve working with a tiny piece of stone under the thumb to work over every few mm of the surface, removing the final scuffs and bringing up the texture and grain of the steel. Here the tojiru slurry forms an interesting wave pattern as the blade is polished with the narutakido jizuya fingerstones.
thanks, @Ben! i knew i had to get this one done because you were waiting on the results!
Dave,
Though I have seen this on your blog a while ago...it remains a beautiful project all around. The sequence of work step pictures are precious to us "would be" Japanese smiths. This degree of documentation of the work done on a blade, must also be of great value to an interested customer.
Thanks for posting it
Jan
I really enjoyed watching this blade come to life, and have a deeper appreciation for the process with your explanations. Your use of hand tools and reclaimed materials is to say the least very inspiring! Thank you for once again sharing this with us!
That is very nice. I enjoy seeing relatively and graceful simple shapes that are well executed.
You have made my newbie head hurt though by causing me to think about how to forge a triangle with only a hammer and an anvil...
Edited by Brian Dougherty
I wonder how the space for the tang was carved out for the shaft when mounted? Is the whole shaft in two, or is a smaller portion of the shaft attached to the rest of it?
That one looks really difficult to forge, beautiful work!
Wes
That is so cool! are you going to make a shaft as well?
Thank you for sharing and documenting all of your works, it is both inspiring and educational.
