LeeMalco 0 Posted August 17, 2015 Share Posted August 17, 2015 Hello all, I had a derp moment during the forging of a stick tang fighter and managed to burn the tang. So now instead of a through tang it's a partial. Planning on some mild steel my neighbor found with his bush hog for the guard. It's rusty and pitted but when it's polished that his gives it a cool textured look. I'm planning burl oak for the handle. Since the hole won't be all the way through the handle I'm wondering if I'm safe to burn the tang in or if I need to just drill it and needle file it to fit. Also, should I drill the hole for the single pin I plan to use before or after shaping the handle? Link to post Share on other sites
Doug Lester 273 Posted August 17, 2015 Share Posted August 17, 2015 I drill a hole in the handle to establish a "path" for the tang as I burn the tang in, though you can use needle files to enlarge the channel and then burn to fit. I drill my pin hole before shaping the handle. Doug Link to post Share on other sites
Alan Longmire 2,648 Posted August 17, 2015 Share Posted August 17, 2015 Burning in is fine. I'd drill the pin hole before shaping the handle to avoid unwanted surprises. Link to post Share on other sites
LeeMalco 0 Posted August 18, 2015 Author Share Posted August 18, 2015 Thank you both for the advice. I'll post a pic when I get it finished Link to post Share on other sites
JJ Simon 123 Posted August 18, 2015 Share Posted August 18, 2015 This method works but using a dedicated "broaching" tool makes a really nice rectangular channel.http://i1217.photobucket.com/albums/dd388/Bladeworks2011/Wheeler/394.jpg http://www.americanbladesmith.com/ipboard/uploads/monthly_04_2011/post-1-13021232921078.jpg I made my own in two sizes and they cut down on time and slop. Link to post Share on other sites
Isaac Humber 8 Posted August 18, 2015 Share Posted August 18, 2015 Great advice from these guys. One thing I would like to expound on is the fit of the tang. It's really easy when you are burning the slot to burn TOO much material out and end up with a very loose fit. Naturally, you want a little bit of space if you're going to be using an epoxy. It sounds like you may just be using a pin, so in that case it is extra critical you do not have a loose fit. My method for getting a tight fit is rather simple. Instead of the tang having a flat end, I round it. Then, when I burn the slot, I make sure there is a gap left between the guard and the handle. Approximately 1/8" . With the touch up filing, and charred wood being removed, the slot is naturally lengthened. That 1/8" of space is nearly taken up, and with a few good hammer taps,the rounded end of the tang compresses the remaining wood and you have a very tight fit. Link to post Share on other sites
Jeroen Zuiderwijk 231 Posted August 18, 2015 Share Posted August 18, 2015 When you're burning in the tang, as soon as enough of the tang is in the wood to guide the direction, place the tip of the blade against f.e. the wooden base of the anvil, and strike the back of the hilt lightly with a hammer. Each hit presses the hot tang into the wood, burns away what it's in contact with. With a bit of luck you can burn in a tang all he way in, as the burning of the wood heats up the tang, keeping it hot for quite a long time (depending on wood and size of the tang of course). I tend to burn it in a bit further, so the blade part burns in a few mm as well. This allows you to cut back the handle a bit, so you get a cleaner end. It takes a bit of practice to get good at this, but the end result is a hole that fits so well, that you're problem won't be a hole that's oversize, but the fit being so tight that the tang is stuck inside the wood. Plus that there's no room for glue, so the tang has trouble getting all the way in when you've added glue. So oversizing the hole a bit after you created a really tight fit by burning may be required (just heat up the tang, and insert it into the hole without hitting in further a few times). Pre-drilling definitely helps guiding the tang into the right direction, particularly if your wood doesn't have a lot of excess material to correct the straightness. Also ensure the tang is straight and symmetrical, particularly the end or it will go sideways. Link to post Share on other sites
LeeMalco 0 Posted August 19, 2015 Author Share Posted August 19, 2015 Thanks for the advice, and I think I'm definitely going to oversize the hole because I'm doing epoxy. Yeah, I'm not confident enough in my abilities to get things to fit tight and flush to do without epoxy. It's going to have a pin AND epoxy. Even cut notches in the tang to get it to grab better. I probably need to make myself a broaching tool too Link to post Share on other sites
