Gyuto and funayuki damascus kitchen knives
Here are two kitchen knives i just finished, a gyuto and a funayuki. Both are forged from a composite bar of 4 alternating twists with a straight laminate edge. They are both symmetrical double grind and full convex with a micro bevel. Here's a link showing some of the making process.
Critique and criticism very welcome, it will help me make the next ones better!
Gyuto
Total length: 395mm
Blade length: 250mm
Height: 46mm
Point of balance: right at choil
Weight: 230 grams
Thickness after collar: 3mm
Full distal taper
Funayuki
Total length: 280mm
Blade length: 147mm
Height: 44mm
Point of balance: Where copper collar meets wood
Weight: 195 grams
Thickness after collar: 3.4mm
Full distal taper
Thanks for looking
  • Like 3
Wow, those have a lot of style. I would love to use those in the kitchen everyday. Bravo!
Are the collars soldered to the blade? If not, I would be a bit worried that moisture and bacteria would collect under there causing rust and other nastiness.
the copper on the end is a cap, not a solid block, right? Not that it matters except that I think it is cool. I just want to know more about how it is built. That is a really nice design. Copper is, after steel, my favorite metal to work with, and the most appealing to me (after steel). Silver is a close second, but everyone uses silver...
kc
Thanks Brian, and yes the collars are silver soldered on.
Kevin, no the end cap is in fact solid, and acts to bring the point of balance up to the choil.
Dan, I haven't noticed any issues with the collar over the last few weeks of using it, but i'll bear that in mind, thanks.
gorgeous gorgeous blades my only issue would be how much effort are u inferring to the owner with the upkeep of the gorgeous copper!? Its not a huge deal just some lemon juice and a wash down -- only knock i could think of
Thanks Steve and Gabriel. The copper does oxidize to an extent, but it is only surface oxides, and will not go very deep at all, unlike steel. Plus i personally prefer the look of aged copper that is polished and shiny on the parts that get handled the most, and a nice deep red/brown colour in the lower parts.
  • 4 weeks later...
These are breathtaking. I really love the shape of the handles. I've never worked with copper, but am looking forward to giving it a try. Thank you for sharing these!
Didn't notice these before, Wow both are stunning. What's more, both look very comfortable to use. Most knife makers seem to forget that chefs use a pinch grip while cutting, these knives look like they would fit the hand very nicely.
Beautiful work! The blades have that chatoyant quality I really like. Also look like the pinch area should feel right working with these. Question? How did you s. solder and etch? Did you use some sort of sealer or mask over the copper? Or did you solder after etching, something I'd be very nervous doing.
