18th century Scottish Dirk
Scott A. Roush
Here is another dirk based on the early style. It is based on a piece that went up for auction that had a bit of hullaballo about being associated with Simon Fraser.. the leader of the Fraser clan who was beheaded due to affiliations with the Jacobite risings. He was a bit of a character and I read that 'laughing your head off' originated with him as he was laughing towards his doom due to the collapse of spectator stands as he was waiting to die.
I made an attempt to give the blade some historical steel character by folding up some 19th century spring material that I salvaged from a logging camp. Not exactly sure what it was.. but very high carbon and associated with an old location. Anyway... I cut it up and folded it for a 150 plus layer billet.
The description indicated that the grip was bog oak.. but seems unlikely due to the grain and the yellow wood peeking through damage. Anyway.. it was decided to use my Lake Superior diver salvaged stuff for the grip...despite it's less than favorable carving attributes (I miss boxwood already).
The spine had the Fraser clan war cry scratched brutally into the spine.. obviously not the work of the original maker. In fact... I wonder if the holes in the spine and the crudely scribed half-circles were from the former presence of a brass sleeve over the spine.
So.. I'm really enjoying the dirk and am looking forward to trying some with silver fittings and more elaborate blade engraving. It is very nice to be using high temp salts for heat treating these as it allows me to do the carving/engraving in the blade prior to heat treat.
Dang, Scott, you're just accelerating the excellence, dude! :o Neat-o, in other words. That steel looks like it may have been shear to begin with, but I still like the character it lent by stcking it up like that.
About the piercing, for some reason the Scots were really into that as decoration on swords and some dirks, as well as pistol parts. Look up all-steel Scottish flintlocks to see some impressive piercing on the triggers and hammers. I've seen at least one basket hilt with an off-center short fuller like that dirk that had seven square holes set on the diamond running down the fuller. I sometimes get the impression if one were able to go back in time and ask about certain features on regional decorative arts, (and this goes for everything, not just Scottish stuff) you'd find many craftsmen who would say "that's just the way it's done" until you traced it to the originator who would say "Because I can." B)
I like this piece a lot if you can't tell.
Thanks a lot Alan. I'm really enjoying these projects. And yeah.. I guess I've seen the piercings as well. I have those brass spine coverings on my mind because of a beautiful dirk Vince Evans recently finished that had one. And it was amazing.
As to the steel.. I etched it and it didn't really show any wood grain.. but I've heard that not all shear steel shows that. So.. who knows? It sure hardened well and welded easy. You REALLY have to etch this a long time to get the welded layers to have topography.
I'm also not sure if or how often dirks would have been made from something like shear steel. I haven't really seen any with wood grainy pattern. It seems like most of them were forged from steel made in Toledo or Solingen.. so I'm assuming these would have been crucible steel???
I don't think I've ever seen a picture of the spine of a dirk before. Is that the usual taper of the handle? Very fine work, thanks for sharing.
I said that.
- - -G. K. Chesterton
Grant Sarver
Very high on the "AWSOME" scale!!
If it's not a trade/craftsman secret, what did you use to darken/age your wood on your handle?
Nothing but Tried and True oil Dennis... that 'black oak' really darkens with oil. This stuff is actually white oak that has been in lake mud for over a century and has darkened due to the anoxic conditions. And thanks!
Geoff... Many dirks had pretty thick spines and some not much distal taper either. Mine might have more distal taper than it ought too. Some dirks seems to be made from broken sword blades and these don't have the heavy geometry of the ones that were purposefully forged.
Over the last couple of years I've noticed what appears to be a relationship between Mediterannean dirks, Scottish dirks and Belduque. All of these had very thick spines and were mighty stabbing weapons.
As to the taper of the handle... I'm not sure! It seems like there are various shapes.. but most seem to be pretty bulbous in the middle. And some come down to practically nothing between the main grip section and the pommel piece. I do know one thing.. it feels amazing in the hand.. especially when held in the 'ice pick' style. That is scary.
Leaving aside the possibilities brought up by Alan Williams of the Ulfberhts being crucible steel, crucible steels were unknown in the West until the 1790s. Bloomery steel was available but not well understood nor the desired outcome of the bloomery process. That leaves the Evanstad method which is apparently unique to parts of Scandinavia and the blister/shear process. Since it is easier to get relatively uniform carbon diffusion and cleanliness from that process it was from bloomery, that was the main method of production foraround 2200 years or so. If you triple-refine wrought and then blister it well and then triple-shear it you get the highest grade of steel easily available in western Europe from antiquity to around 1820. You still find 19th century tools stamped "triple shear" or "cast steel." The cast refers to crucible steel rather than method of manufacture.
To further hijack the thread, Huntsman invented crucible steel while trying to make a more uniform clock spring for marine chronometers during the race for the prize to whoever made a clock accurate enough to measure longitude. He did it by melting triple shear.
Okay.. In my head I keep thinking 'cast steel' was developed earlier... but that wouldn't show in dirks until the 1800s then. So... blade steel being forged into dirks in the 18th century would still be either straight bloomery steel or shear steel. Or some Evanstad method.. if that was indeed being done outside of Scandinavia.
Thank you for your reply,
Also you and Alan for sharing your knowledge, great stuff!
Regards
Edited by Dennis Mitchell
Excellent work Scott, you have me wanting to make a few dirks... I love the fact that the materials you used give it an aged look without any artificial aging.
George Ezell, bladesmith
Buffon
view some of my work
RelicForge on facebook
Thank you George. Dirks would suit your style it seems to me....
Beautifully done Scott!
As for Euro crucible steel I will have to disagree with Alan about the dates: Huntsman first produced it in the late 1740's for his clock springs. The French began using it for knife blades in the 1750's although the English makers didn't start using much of the new steel until the late 1760's - one reason being it was too hard to work compared to blister and shear.
By the late 1830's enough crucible steel was being produced that at least two Americans - Wesson and Remington - were using deep drilled cast steel for pistol and rifle barrels.
As Alan noted there are various grades of shear steel based on various grades of WI. The few original pieces I have etched of double and triple wrought seldom show much of a pattern.
Chuck Burrows
Wild Rose Trading Co
chuck@wrtcleather.com
www.wrtcleather.com
You are welcome Alan - sitting on my butt recuperating from a week of chemo doesn't leave me much energy other than read the forums......
Chuck Burrows
www.wrtcleather.com
Scott - I don't usually like dirks, maybe a function of the lowland Scot ancestry (did they use dirks often, or not)?
I used to be able to say with confidence that I only liked the dirks that Vince Evans and Grace made. Now, I have to add yours to that list. Seriously, the attention to detail and the way you strive to be true to the historical traditions (with cool modern tools like salt baths) is a joy to behold. It has been a great pleasure to see a friend develop such formidable skills as a craftsman and lay-historian.
In short, you geek out on this stuff just like the rest of us, only better.
This really is quite wonderful work. Honestly Scott, I don't think I have ever seen anything you have made that I wasn't impressed with. That carving is so tight too. Did you use carving chisels or the knives and scrapers?
Thanks.
http://www.krakenforge.net/
Sorry to be late responding to comments. I've been.. surfing in California and introducing my kids to the ocean! I miss the West coast....
Anyway. Thanks for the comments. And thank you Chuck for clarifying and noting that few dirks show any kind of pattern. This is something I've *felt* but didn't know for sure. Still.. the customer and I liked the idea of showing just a hair.
I really appreciate it Kevin.... It's an honor that you include my dirks with the Evans. Not sure how I could do it without their work for inspiration.
Wes... This oak was a pain to carve. I used a combination of carving chisels, very pointy knives and the 'higane' scrapers I've learned to use through my studies in Japanese metal work.
