Harbor Freight Temp meter
Terry_Dodson
I went by Harbor freight today to get a set of the needle files (i just got a knife shoulder filing jig from Koval Knife Supply today ), and happened to pick up one of thier flyers while i was there. I just looked at the flyer and it has a Digital Thermometer with probe listed, here is the description:
Large easy-to-read four digit LCD display with back lite
Gives Celsius, Fahrenheit or Kelvin readings
37'' long probe
Automatic shut off
Tri pod mount
Includes 9 volt battery and carrying case
Tripod mount: 1/4-20 thread, Measuring range -50° C to 1300° C, -58° F to 2000° F, 223° K to 2000° K, Overall dimensions: 6-3/8'' L x 3'' W x 1-3/8'' T, Tool weight: 0.75 lb.
ITEM 92242-0VGA
I was wondering if anyone has used this one? I already have a temp meter with a type K thermocouple that i use, but it only reads Celcius, this one reads both.
I am usually overly skeptical but here is my two cents worth.
1. A $35 contact thermometer is probably a 5% instrument. This means that at full reading of 2000F, the error could be up to 100 degrees.
2. 2000F is not forging temperature but could help with heat treating. However, even a 1% instrument can be off by 15-20 degrees at heat treating temperatures.
3. Most steels at heat treating temperature will have some scale on it and the scale will interfere somewhat with getting an accurate temperature.
4. For $35, what the heck, go for it! :P
Which is worse; ingnorance or apathy? Who knows? Who cares?
I have one, and with the caveat mentioned by R.K. it seem to work fine to me. I use to double check digital H.T. oven. and to monitor my toaster oven when tempering. Well worth the $35. If you want a meter that goes up to 2350 F. for a bit more $$, check out ENCO.
Jerry
I haver one and like it,i did replace the piece of junk flimsy wire lead with a 12 " ceramic coated lead and it is as accurate as any ive put it up against.
N'T McAhron Sqwaukin Vulture Verrinder
"to create is to make art"
TREMBLING EARTH KNIFE WORKS (website coming soon)
Jerry
27958[/snapback]
Jerry,
I couldn't find a thermometer that goes up to 2350 on the ENCO website...do you have any further information on it? If you do..thanks!
Lambert
This may be a stupid question, but can you the 2 thermometers mentioned above to set the temperature in the forge and after a good soak the steel should be the same, then it doesn't matter if it has some scale on it?
Thanks
Chris
じょうざいせんじょう
