jake cleland Posted May 22, 2020 Share Posted May 22, 2020 Been working on a blade for the past few days. It's a 9 1/4" 9 bar serpent core dagger - silver steel edges with a serpent of alternating 15n20 and 11 layer twist set in mild steel: I'm making it to fit this handle I've been working on, carved from sycamore: it's been pretty fun so far... 7 Jake Cleland - Skye Knives www.knifemaker.co.uk "We can't solve problems by using the same kind of thinking we used when we created them." "Everything should be made as simple as possible, but not simpler." "Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe." Albert Einstein Link to comment Share on other sites More sharing options...
R. Alex Dorris Posted May 22, 2020 Share Posted May 22, 2020 Hell yea! Do you hand carve, or use a rotary? Link to comment Share on other sites More sharing options...
jake cleland Posted May 22, 2020 Share Posted May 22, 2020 29 minutes ago, R. Alex Dorris said: Hell yea! Do you hand carve, or use a rotary? all the actual carving is done with chisels/gravers, but I used a burr for some surface texturing Jake Cleland - Skye Knives www.knifemaker.co.uk "We can't solve problems by using the same kind of thinking we used when we created them." "Everything should be made as simple as possible, but not simpler." "Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe." Albert Einstein Link to comment Share on other sites More sharing options...
Garry Keown Posted May 22, 2020 Share Posted May 22, 2020 (edited) The morning went by with getting some knives sharpened, cleaned up, packaged and away on the international courier and the afternoon was spent going over a request for a short bullnosed skinner and when I had the pattern right, getting it and another 5 blades cut out and profiled. Edited May 22, 2020 by Garry Keown Von Gruff http://www.vongruffknives.com/ The ability to do comes with doing. Link to comment Share on other sites More sharing options...
Alan Longmire Posted May 22, 2020 Share Posted May 22, 2020 11 hours ago, jake cleland said: Been working on a blade for the past few days. It's a 9 1/4" 9 bar serpent core dagger - silver steel edges with a serpent of alternating 15n20 and 11 layer twist set in mild steel: I'm making it to fit this handle I've been working on, carved from sycamore: it's been pretty fun so far... Dang, Jake! That's going to be all kinds of awesome! Link to comment Share on other sites More sharing options...
Joshua States Posted May 23, 2020 Author Share Posted May 23, 2020 22 hours ago, jake cleland said: it's been pretty fun so far... I bet! Any hardware planned? “So I'm lightin' out for the territory, ahead of the scared and the weak and the mean spirited, because Aunt Sally is fixin’ to adopt me and civilize me, and I can't stand it. I've been there before.” The only bad experience is the one from which you learn nothing. Josh http://www.dosgatosdesignsllc.com/#! https://www.youtube.com/channel/UCdJMFMqnbLYqv965xd64vYg J.States Bladesmith | Facebook https://www.facebook.com/dos.gatos.71 https://www.etsy.com/shop/JStatesBladesmith Link to comment Share on other sites More sharing options...
jake cleland Posted May 23, 2020 Share Posted May 23, 2020 10 hours ago, Joshua States said: I bet! Any hardware planned? I toyed with the Idea of a talon shaped guard, but it was too busy and messed with the lines, so It'll get basically a Japanese mount - copper habaki and seppas, small hamidashi style tsuba with some sculpting around the mimi, buffalo horn fuchi. Thinking I might make the pommel nut in the form of a lance head... 1 Jake Cleland - Skye Knives www.knifemaker.co.uk "We can't solve problems by using the same kind of thinking we used when we created them." "Everything should be made as simple as possible, but not simpler." "Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe." Albert Einstein Link to comment Share on other sites More sharing options...
Garry Keown Posted May 24, 2020 Share Posted May 24, 2020 The helve hammer had a good boost today with the base plates bolted down and the nuts welded on the underside of the floor plate. The stands for the drive arm pulley were welded to the base plate then the twin uprights got welded to their base plate with the angle irons welded to the top for the bearing housings to be bolted to. Dosent sound like a lot but it was a full day. Von Gruff http://www.vongruffknives.com/ The ability to do comes with doing. Link to comment Share on other sites More sharing options...
Troels Saabye Posted May 24, 2020 Share Posted May 24, 2020 spend 2 hours trying to repair an angle grinder -.- only one with 230mm discs we got and the locking nut broke into 4 pieces with the thread still stuck on .. Went up to the retort - cold apart from the combustion chamber - gave it a bucket of water to cool off and removed more insulation - todays heavy rain should cool it more, I'll probly have to seal it up later today again or atleast check it Link to comment Share on other sites More sharing options...
Jeremy Blohm Posted May 24, 2020 Share Posted May 24, 2020 Viking camp axe Vs. maple And here it is after some grinding Link to comment Share on other sites More sharing options...
Alan Longmire Posted May 24, 2020 Share Posted May 24, 2020 Bummer. There's a reason axes get a soft temper, though... Link to comment Share on other sites More sharing options...
Gerald Boggs Posted May 24, 2020 Share Posted May 24, 2020 (edited) Could you show a photo of that axe from the top? Edited May 24, 2020 by Gerald Boggs <p>Gerald Boggs <a href="http://www.geraldboggs.com">www.geraldboggs.com</a></p> Link to comment Share on other sites More sharing options...
Chris Christenberry Posted May 24, 2020 Share Posted May 24, 2020 (edited) Just beginning to mess around with my new 2x72 belt grinder. Already realizing how much sweeping I'm going to have to do. So today I spent about a half hour making a temporary "laundry chute" for the metal grindings to go down directly into my water bucket. I'll see how it works before going with a more permanent build. Saves a whole lot of sweeping though. Edited May 24, 2020 by Chris Christenberry Chris www.chrischristenberry.com WHEW!!! If I could only know now what I "thought" I knew back then.................... Link to comment Share on other sites More sharing options...
Alan Longmire Posted May 24, 2020 Share Posted May 24, 2020 That's a great idea! My bucket is on a pillar of cinderblock that holds it at the bottom wheel of the platen. Catches a lot that way, but the weekly shop-vac treatment is still required. Link to comment Share on other sites More sharing options...
Chris Christenberry Posted May 24, 2020 Share Posted May 24, 2020 (edited) It would be my luck to knock over an elevated bucket, for sure! I'm not kidding myself into thinking this will totally replace the cleanup requirement. I'm just hoping there will be a little less of it on the floor and in my eyes and lungs. (note PPE on the wall) As soon as I wring out the wrinkles of the design and it's mounting method, I'll go to the sheet metal shop down the road and have one folded up to replace this wooden one. Edited May 24, 2020 by Chris Christenberry Chris www.chrischristenberry.com WHEW!!! If I could only know now what I "thought" I knew back then.................... Link to comment Share on other sites More sharing options...
Daniel W Posted May 24, 2020 Share Posted May 24, 2020 6 hours ago, Jeremy Blohm said: Viking camp axe Vs. maple And here it is after some grinding Ouch, I worry the same thing with the welded up one I just finished up. A File will only barely shave it and I'm tempted to temper the edge back to blue from the purple color it was. But I've also looked at how heavy it is, and decided it is not meant to try and split lumber. Or even go through any of the local hardwoods around my area. A black locust tree shattered the edge of my felling axe so something even smaller and lighter would stand no chance. You had a nice bit of edge material to keep its look. Link to comment Share on other sites More sharing options...
Brian Myers Posted May 24, 2020 Share Posted May 24, 2020 Agreed. An axe will chip and crack with such a hard temper. A good light to dark blue will help keep a hardened edge, but allow it plenty of spring to resist cracking. Link to comment Share on other sites More sharing options...
Jeremy Blohm Posted May 25, 2020 Share Posted May 25, 2020 5 hours ago, Gerald Boggs said: Could you show a photo of that axe from the top? Its ugly but here it is. Link to comment Share on other sites More sharing options...
Brian Dougherty Posted May 25, 2020 Share Posted May 25, 2020 Found yet another use for @JJ Simon monkey tail tongs. Perfect thing for reheating my lunch while waiting for a billet to come up to temp. Even this chain store pizza tasted better after being toasted over the dragon's breath. Ok, this is probably a terrible idea, but that pizza will probably kill me before some forge pollution. 3 -Brian Link to comment Share on other sites More sharing options...
Jeremy Blohm Posted May 26, 2020 Share Posted May 26, 2020 @Alex Middleton came over and forged for a few hours about a month ago and he brought this 4140 die of some sort and left it behind....well today I started forging it into a BIG rounding hammer. I ran out of charcoal and I ran out of energy. This is by far the biggest piece if steel I've ever worked!!!! 1 Link to comment Share on other sites More sharing options...
Alex Middleton Posted May 26, 2020 Share Posted May 26, 2020 Glad you found a use for it! Link to comment Share on other sites More sharing options...
Garry Keown Posted May 27, 2020 Share Posted May 27, 2020 Got the floor plate done with the soft pine boards to cushion it against the concrete and sat the main frame and the final drive pulley stand in place. Still have some welding to do on them but I NEEDED so see it like this. On another note this box of handle blocks arrived today. Friday last week I spoke to my wood guy in Texas and today, wed they arrived so am very pleased as they are replacement wood for the handle blanks that have either gone missing or are under 2 months worth of international post in some dark basement somewhere. Lacewood burl and tassie blackwood and I was just speaking to him and he was telling me about some amboyna burl he may be getting in. Von Gruff http://www.vongruffknives.com/ The ability to do comes with doing. Link to comment Share on other sites More sharing options...
Jeremy Blohm Posted May 28, 2020 Share Posted May 28, 2020 On 5/26/2020 at 7:18 PM, Alex Middleton said: Glad you found a use for it! After forging before grinding Link to comment Share on other sites More sharing options...
Chris Christenberry Posted May 28, 2020 Share Posted May 28, 2020 I made a wall rack to store the small wheels for the small wheel attachment for my new 2x72 grinder. 1 Chris www.chrischristenberry.com WHEW!!! If I could only know now what I "thought" I knew back then.................... Link to comment Share on other sites More sharing options...
Garry Keown Posted May 28, 2020 Share Posted May 28, 2020 (edited) A batch of knives under the brood light. As we are getting well down in temps with some heavy overnight frosts I have the brood light going over them overnight for the epoxy to cure. Finally able to get some knives handled for some very paitent customers. I have had concience problems with this taking so long but should be able to go back to my max 6 week order to delivery time frame now that things are running again. I was talking to Jason last night (the wood guy in Texas) and he sent a pic of one of the big pieces of Amboyna burl he is about to cut up so I asked him to put a 4 nice blocks asside for me. It is so nice that I may just get another couple as well. Edited May 28, 2020 by Garry Keown 3 Von Gruff http://www.vongruffknives.com/ The ability to do comes with doing. Link to comment Share on other sites More sharing options...
