  • Replies 4.2k
  • Created
  • Last Reply
Top Posters In This Topic
Popular Posts
A few weeks ago a kid (I say kid, college senior doing an honors thesis, probably 21 or so ) came to my local guild meeting to ask if anyone could help him with a sword. His honors thesis involves han
Finished another folder.  Little bitty bugger, 2.5" / 63mm closed, 4.5" / 112mm open.  O-1, brass liners, nickel silver bolsters and pins, ebony scales.  Still needs an edge and some cleanup, but it's
Forging a copper rose pommel for a misericorde I'm working on. Also going to try and make a couple of tiny ones for the ends of the quillions...
Posted Images
5 minutes ago, Peter Killham said:
It wasn't today, but last weekend.  I'm hoping to get some time to work on it this weekend.
Do you want some tips or suggestions on how to grind that clipped point?
Worked overtime Friday and Saturday till lunchtime, then heat treated 3x 52100 blades while drinking beer.
Sad story, 2 of those blades used to be my first sword, forged from one whole bearing race.
I trimmed it down to wakizashi size so it would fit in my kiln, I was busy on the grinder trying to sort out a few last things when it slipped inbetween the platten and work rest.......guess I don't need to tell you what that did.
By the time I ground out that boo-boo the blade was way too thin, so it became 2 kitchen knives.
When I'm stressed, worried and generally fubar, I should stay away from the grinder....these are hand sanding and contemplation times....
Today I HT'ed 3 blades. On one, I tested ATP-641 alone as clay to get a hamon, instead of my usual furnace gasket cement.
It did not work...
Anyways, I still got 3 perfectly straight and hardened blades.
I also reprofiled and reground the filet knife I broke earlier.
  • Like 3
6 hours ago, Joshua States said:
I am saving this one for later use. Thanks Joshua
26 minutes ago, Clifford Brewer said:
Good to see you back Colonel..............B)
Thanks, it's good to be back! You should see some more mustard patinas soon :lol:
Yesterday did some grinding on an experimental Z-wear/ stainless blade and some light chopping into a carved buffalo horn. Also I cut welded doors on the Argentine grill and layed out the vents.
Certainly not the most awesome thing I have ever done or made, but you have to start somewhere....
  • Like 3
The bench top lathe turned up so it was unpacked, bolted into its place on the bench and given a tes run. I will get a bit of a heads up from the engineer on turning speed etc for steel and brass but pleased to have it after years of thnking it would be a handy thing.
  • Like 3
Has been a busy weekend and going to be busy vacation day tomorrow.
Yesterday got the stout all bottled.
Today, got four tomahawk bodies and two tomahawk shaped axe bodies forged up.
Tomorrow bottling the Imperial PA.
Bummer Faye, that was a nice piece of wood too.  Look on the bright side.  Now you can sell it as having a three finger handle!:D
Edited by Alex Middleton
  • Haha 2
Unfortunately, it broke right at the end of the tang, so I don't have a solid wood back any more. I was thinking of putting it back together with blind pins and a fiber gasket. If it survives some abusive testing I might even sell it.
Real sad, it was a beautiful piece...
It is one of the reasons why I refrain myself from using burls and other brittle materials(think pine cone) for my hidden tang handles. Even stabilised it's not very sturdy. But perhaps if used on a framed handle with liners it would be strong enough?
4 hours ago, Faye said:
I had a bad day in the shop. A spalted maple handle came apart in the knife vice.
Too pretty to waste but If you can do casting in an upright container and were accurate with a 2 or 3 pins you could save that handle and at least it would be an interesting experience and add another skill to your tooll bag
Edited by Garry Keown
Bit of reorganisation to run that forge safely. Swapped the bandsaw with the drillpress (which is about half a ton). Moved the press to the right. I need to get rid over all that wood over grinding section too. And perhaps construct a duct over the forge just to suck the waste heat. I cannot make a hole in that wall, so it needs to go out of the window.
1 hour ago, Joshua States said:
That is a really cool drill press.
Its very old one and I want to restore it when I have a bit of a time. Its a bit of a beast, since it takes anything up to morse 4 and can drill a hole 400 mm deep in one go.
