Joshua States
21 hours ago, Alex Middleton said:
That was my thought as well.  I'm going to give that a try next time I'm out in the shop.  I have a feeling that it's not going to do anything though.  It sucks.  The motor isn't a TEFC, otherwise I'd put it on my 2x48 as one hell of an upgrade to the 1/2 hp that's on there now.
its not ideal but until i upgraded to a 3phase motor so i could use a vfd to control speed i never had any thing on my grinder that wasn't an open motor never killed one but i did out grow one or two
Brandon Sawisch bladesmith
Appreciate it sir.  I just tried switching them and got nothing.  Shy of getting really creative, that motor is a no go for the surface grinder, at least running on 115 anyway.  I was thinking about switching everything around to run in the opposite direction, but I'm afraid it could cause the wheel to loosen up which would be less than ideal. :D
Edited by Alex Middleton
  • Haha 1
Finally got my forging area laid out a bit better.
Also finished roughing out my first real foray into forged kitchen knives.
213 layers of 1084 and 15n20, with a 15n20 edge bar welded on.  My little bottle jack press made a huge difference in getting this thing done.  I'd probably still be hammering on the second stack without it.  We'll see how well this ends up coming out.
It's alive, IT'S ALIVE! MWAHAHAHAHA!!!!
I had an old face mount pump motor sitting on the shelf.  Turns out that one was reversible.   The temporary mounting system is somewhat, "custom".
But now that I know it works I can fab up a new mounting plate for it.
  • Like 4
Hello all.  It's been a good week.  Had decent weather for a few days, so took advantage and remembered to take pics of what was done yesterday.
These (along with 3 others from yesterday) are now soaking in vinegar, and 6 others from the other days are now in their 1st tempering cycle after quenching...
Edited by billyO
  • Like 3
RIP Bear....be free!
as always
peace and love
billyO
Handsanding on the 7 1/2 (rimu) and 5 1/2 inch chef's (dyed lacewood) and a heavy hunter I want to try on the hill next hunt with the orange liners and spacer.
Von Gruff
http://www.vongruffknives.com/
The ability to do comes with doing.
Good morning, all.  For some reason, I seem to be in a picture taking mood, and here's the blades after heat treating.  2 of them had slight warps out of the quench, and this time I only needed the normal 2 tempering sessions to get them straight.  I need to remember to do my asymmetrical grinds after  heat treating....20211128_082410.jpg
PS- The funky shaped tang on the bottom one is where I had a coupon that I broke off to check the grain.  This one is my first completely powder blade and I wanted to check my grain.
as always
peace and love
billyO
Nice array of stuff, guys!
Personally, I screwed up a folder beyond repair at the last step of the build.  I can salvage the blade and spring, but the liners and bolsters are trash, as are the briar burl scales.<_< Sucks, but that's why not many people build traditional slipjoints, right?  If it was easy everyone would do it.  Every single step is a chance to screw up, and I do, frequently! :unsure:
And I also discovered that the 1/16" nickle silver rod I ordered months ago is 0.064" instead of 0.0625" like my drills, reamers, and heading die. Expensive, unusable (for my purposes) trash. Wish I could remember where I got it so I could call 'em up and let them know my feelings on the subject.   I have told the place that sold me AEB-L marked 0.094" that was actually 0.112" (a pic of the label with a micrometer helped), and they made it better.
  • Confused 1
  • Sad 2
I came home from 4 days in the NM woodland and found this had arrived. One of my winter projects is a step closer to reality. Actually, several projects got a step closer.......
  • Like 3
Not trash. I have had the same problem and I fix it with a bit of 400 grit sandpaper between my thumb and forefinger and the drill press........YMMV
Tore out all the firebrick in my forge today, it was definitely time.
When I first started forging I was so efficient that I could forge and work on bevels with my file jig in between heats. Or at least I thought I could, untill the forge got up to heat and I melted a horseshoe rasp in half. Since then I have tried multiple times to melt steel together with copious amounts of flux to make damascus.
However, I am older, wiser, and more educated now, so I am redoing my forge in preparation for my next damascus endeavors. ;)
10 hours ago, Matt Walker said:
I think I know where that one was going and I'm :(.
You and me both.
And Joshua, I know I can do that, it just greatly annoys me that I have to. Rod sold as 1/16" should be that, not 5/64".
Not entirely knife related, and it was last night, but I thought I'd share the hobby that helps pay for the hobby of knife making :)
A Few small Beads and other trinkets I dremel out of brass and other various materials.  I know my soldering is atrocious, but after patina-ing it turns out kind of neat. :lol:
Large two-face Tag3.jpg Wide Eyed Oni brass-cu.jpg Wide Eyed Oni Cu-Brass.jpg Wide Eyed Oni menpo glow horns.jpg
Edited by Jaron Martindale
  • Like 3
Added another resident to my "Shelf of Shame".  I've been working on a damascus kitchen knife lately.  Finally got it ready to etch, and the pattern was completely jacked.  It was supposed to be 106 layers on each side of a 15n20 core.  Poor forging caused it to come out off center a touch and ended up with a nice pattern on one side, and almost no pattern whatsoever on the other.  I'm pretty sure I know where I went wrong so I'll chalk it up to get another learning experience.
Why not complete it and keep it for yourself? If your welds are good and you like the shape, it'll make a good tool you'll use daily and will eventually come up with pointers for the nexts.
Someday I may.  There's a few minor design issues that I wasn't totally happy with as well. My shelf is right above my workbench.  It gives me a constant reminder of the mistakes that have been made, and how to avoid them.
1 hour ago, Gilbert McCann said:
Finished forging this chef knife yesterday....
Looks pretty good to me.  Is that going to be an integral? What was the starting stock size?
Edited by billyO
as always
peace and love
billyO
Yes integral. I started with 1 1/8 I used that because I had been having so much trouble pulling down the heel. I think 1 inch would be ok now. Here it is with some profiling and tang grinding.
Edited by Gilbert McCann
Spelling
  • Like 4
22 hours ago, Gilbert McCann said:
Yes integral.
I would very much appreciate seeing you grind that. An integral is on my list and I'm trying hard to figure out the grinding.
I have a similar shelf that is getting crowded.....:blink:
