Joshua States
Managed to sneak out to the shop this evening for a couple of hours.
A sneak peak of the gun barrel blade I've been working on, fresh off the finish grind with a quick etch.
I had a tiny warp after quenching that I decided to surface grind out instead of straighten.  I didn't think it was going to be enough to throw everything off center, but apparently I was wrong.  That being said, it's still close enough that I'm pretty dang happy with it.
  • Like 6
Just talking to my wood guy and the adiction kicked in so will have these scales sets coming
Von Gruff
http://www.vongruffknives.com/
The ability to do comes with doing.
I see a wolf in that second set of scales. Wonder what Rorschach has to say about that?
better than seeing things in the clouds. If you squint a bit you can see a map of Africa and a map of Australia in the 2 circles.Untitled.png
Von Gruff
Today I made myself terribly unhappy. Oh well. It was a good try anyway. It might still be salvageable to some extent, as I don't know how deep it goes.
  • Sad 3
Bummer.
But if so, please share/ tell me how.
I've got a 4x4 piece from 2 years ago that was going to be a basket weave pattern that has a similar failed weld on one of the pieces...Haven't known what to do with it since.
Edited by billyO
RIP Bear....be free!
as always
peace and love
billyO
Through the process of tile cutting. At first glance, the weld flaw appeared to only go a short distance down the bar. This flawed section could be removed with the first cut at a 30-degree angle.
However, further inspection reveals the other side of this bar may be flawed along the entire length.
So, I might just take the advice of a fellow smith and carefully remove the bar and weld a solid plug of 1095 or W-1 in its place. Then I would have to re-square the bar on the bias and do another 4-way weld. If I cut this bar out, I will probably put it in a can with some 1095 powder. If I had a really good mill (which I don't) I would mill this bar out to get it clean enough to weld a square plug bar in there.
Did something long overdue...
I had some free scraps at work so the total cost was 10 bucks B)
Now I'm going to have to figure out how to craft the "core". Probably going to weld a flat bar on the bottom....
Seeing as you have the steel tube I expect you will have access to one to fit inside the vise so if you split it leaving plenty of room for the lthickest blade you may work on and weld a flat on both pieces you can spot weld the lower half and leave the top half float to allow for the knife insertion. Glue thick leather on both halves to prevent blade damage. You can then make another top  that is a simple flat but just an inch wide and add leather to that as well so that in the case of a small mark on the blade later in the process after the handle is finished (you know we have all done that), you can slide the top half round out and with the handle sitting on the lower half the flat will hold the handle so you can do a few high grit w&d paper passes on the blade to remove the inadvertant mark. I made a seperate very simple wooden fixture for this that relies on wedges to hold the handle and have used it a few times. Invaluable when the need arrises.
Edited by Garry Keown
Von Gruff
Not in my shop, but I took a Mokume Gane workshop with Ted McDonah at Grizzly Ironworks in Phoenix.
Starting billet: 2"x3"X1-1/4", 25 layers or 16ga. copper and nickel-silver.
Fired in a propane forge
Reduced to about half thickness. Will trim, cut and pattern tomorrow.
  • Like 3
Tried my fist canister damascus. I've got four garage doors worth of springs sitting around and finally decided to try them in a canister. Worked out pretty well.
A small amount of the springs I have all straightened.
Cut into 4 inch pieces.
Packed with 1080 + 2 % nickle powder.
The canister pictured above is not the canister I ended using. The stainless steel was so thin that I burned a hole in it as I was trying to weld it up. Ended up with a "standard" mild steel canister coated in Kiltz. Wasn't too difficult to get out.
Took it down to 3/4 inch square, twisted it and then flattened. Cut a small coupon to check the pattern. Kinda reminds me of cable damascus , but with out the issues that cable has.
Edited by Bill Schmalhofer
  • Like 5
Way to go man!
I finished that Mokume Gane class and updated my How-To thread: Mokume Gane (a quick How To Do) - Hot Work - Bladesmith's Forum Board (bladesmithsforum.com)
Was a big day at the grinder today to finish the grind on this batch of NitroV kitchen knives. all grinding done post heat treat
Von Gruff
13 hours ago, Conan Dunlap said:
My first attempt at W's pattern.
I don't see any flaws per se, but I don't see the W's either. It's a very nice and tight high layer pattern though. The end grain looks more like you twisted it somewhere along the process. What's the plan from here? How many of those little cubes have you got?
Maybe I don't really understand how to do W's.  It is 240 layers, I don't really have a plan for this, I will probably draw it out into a Bowie if I have enough.  I only have the one cube.
That is possibly true. How did you get to this point?
I forged 240 layers, rotated 90 degrees and forged down to about 3/8" thick (vertical layers on the end grain) then cut into 14 sections and stacked them with all of the end grain on one side.  I thought this is what created the W's with all of the end grain stacked up.  I don't really know what I am doing, just trying to learn by doing!
You took the billet up to too many layers before turning 90 degrees (called forging on the bias) and stacking. You need to forge on the bias after the initial billet is welded together. Then forge it out flat, cut and stack, lather, rinse, repeat as desired until the end grain looks more like this.
The W's pattern is an end-grain pattern. In order to see the W's, you need to transfer the end grain out to the face.  If you forge what you have out flat, you will distort the pattern and stretch it out. It will still look pretty good, but it's probably going to end up looking more like random Damascus than anything else.
