Jaro Petrina Posted February 9 Share Posted February 9 Weeelllll....... I need to reseal and reasemble the manifold. The sealant is after 1 year of hard use gone. 1 Link to comment Share on other sites More sharing options...
Alan Longmire Posted February 9 Share Posted February 9 Those look good! Like the start of a production run. How is the silicone pipe holding up to the manifold? Still good? Link to comment Share on other sites More sharing options...
Jaro Petrina Posted February 9 Share Posted February 9 44 minutes ago, Alan Longmire said: Those look good! Like the start of a production run. How is the silicone pipe holding up to the manifold? Still good? The silicone is untouched, the manifold is actually quite cold under normal conditions. Just the mortar I used to fix the block in the manifold is dust Link to comment Share on other sites More sharing options...
Jaro Petrina Posted February 9 Share Posted February 9 These big knives eat the belts though and I cannot get a good grind without a fresh belt. The 4 meter belt actually held quite well for some, but I have destroyed two through my own stupidity. The 36 grit one cost 40 bucks. Ouch. 60 grit are cheaper, but not much. 2X72 belts at 36 grit now cost 15 bucks. Hell........ 1 Link to comment Share on other sites More sharing options...
Gerhard Gerber Posted February 10 Share Posted February 10 Not my shop, but a much better one...... Yesterday after work I dropped by a fellow maker's house, bloody shame because we live in the same suburb, and we've been threatening for 2 years. He's a retired engineer of some sort, and I want as much to see his shop and his bonsai, one of the more impressive local collections that I've seen. Not that his shop is to be sneezed at, he's got everything you need, and then there's the stuff he's built. Two items that stood out is a bandsaw he built to saw stumps into planks. Guess you can call it a tire saw since that's what the blade runs on, complete with mag rims! He got a tiny little oven that a retired dentist used to melt gold, turned that into a little tempering oven specifically for folders. Makes me feel like a lazy knuckle-dragger He knows how many knives he's made, and how much he's earned from them. I've lost count a bit, but I do believe I've made more knives, and for sure not earned even half as much. 1 Link to comment Share on other sites More sharing options...
Joshua States Posted February 13 Author Share Posted February 13 After another failed crucible run, I decided to put this thing together. I only had two bolts, three washers, two nuts, and this weird piece of sheet metal left over. I seem to remember someone saying I should grease something or the other on this saw, but I cannot remember what, or where the grease goes on. 1 “So I'm lightin' out for the territory, ahead of the scared and the weak and the mean spirited, because Aunt Sally is fixin’ to adopt me and civilize me, and I can't stand it. I've been there before.” The only bad experience is the one from which you learn nothing. Josh http://www.dosgatosdesignsllc.com/#! https://www.youtube.com/channel/UCdJMFMqnbLYqv965xd64vYg J.States Bladesmith | Facebook https://www.facebook.com/dos.gatos.71 https://www.etsy.com/shop/JStatesBladesmith Link to comment Share on other sites More sharing options...
HSJackson Posted February 13 Share Posted February 13 You can check/change the gear oil in the gearbox under that flat plate near the belt pulley. The oil in mine was nasty looking and smelly from the factory. 1 Link to comment Share on other sites More sharing options...
Jaro Petrina Posted February 13 Share Posted February 13 Well that needed some resealing/maintenance. Impressed with the block material, that havent moved a bit in year and half. 2 Link to comment Share on other sites More sharing options...
Alan Longmire Posted February 13 Share Posted February 13 14 hours ago, HSJackson said: You can check/change the gear oil in the gearbox under that flat plate near the belt pulley. The oil in mine was nasty looking and smelly from the factory. Yeah, that flat plate right above the motor. Mine was packed with what appeared to be asphalt. REALLY thick grease. But then it was made in 1983. I got it in 2002. I scraped most of that old hardened stuff out and replaced it with 90W gear oil and white lithium grease in 2019. Made no discernable difference in operation, but it made me feel like I was doing something for it. 1 Link to comment Share on other sites More sharing options...
dragoncutlery Posted February 14 Share Posted February 14 Mine would trip out trying to start in the cold weather till i swaped out the grease they used ...........i dont rememberif i went 90w or packed it with grease but it runs cold better 1 Brandon Sawisch bladesmith eagles may soar but weasels don't get sucked in to jet engines Link to comment Share on other sites More sharing options...
Jaro Petrina Posted February 14 Share Posted February 14 Tool for serial grinds - I m supposed to make quite few military knives for our airborne veteran club. I am putting the tool on linear table (that cost 170 bucks!). The vice is local scrapyard score. It weights 60 pounds ! and there is nothing wrong with it! 2 Link to comment Share on other sites More sharing options...
Jaro Petrina Posted February 14 Share Posted February 14 (edited) Once the forge dries after the small repair I need to HT this. Blade is 12" Edited February 14 by Jaro Petrina 2 Link to comment Share on other sites More sharing options...
Jaro Petrina Posted February 15 Share Posted February 15 Looks like the reseal of the burner went well.... video000000.mp4 Link to comment Share on other sites More sharing options...
Martin Tiney Posted February 15 Share Posted February 15 Spent over a hour and a half trying to get my homemade grinders belt to run true, only to discover its a faulty belt . Put on a new belt and it's running fine 2 1 Link to comment Share on other sites More sharing options...
Gary LT Posted February 15 Share Posted February 15 Jaro, I remember when you built that forge, I was really impressed and wished I had the space to do something similar….but I certainly don’t have the skills. This is an awesome vise / score…….Is there a manufacturer name or model # on it? Thanks, GARY LT 1 "I Never Met A Knife I Didn't Like", (Will Rogers) Link to comment Share on other sites More sharing options...
Jaro Petrina Posted February 16 Share Posted February 16 19 hours ago, Gary LT said: Jaro, I remember when you built that forge, I was really impressed and wished I had the space to do something similar….but I certainly don’t have the skills. This is an awesome vise / score…….Is there a manufacturer name or model # on it? Thanks, GARY LT Hello Gary, there is no markings on the vice, but it looks english to me. Its not even that old. Needs to clean inside out. Well aside of mushroomed tip OK. I can imagine this would go through chainmail. 8 mil thick, build like a bayonet. 3 Link to comment Share on other sites More sharing options...
Gerhard Gerber Posted February 17 Share Posted February 17 Running battle with the transport company importing my new grinder, collected exactly a week ago in a town 2 hours' drive from the depot, at least they've found it in the mean time.......... Just had to pay an invoice double the initial estimate, and send a bunch of documentation they received on the 9th already I have a huge issue with unfinished knives, have several of this waiting, but I believe a pause & reset (corporate jargon ) is in order. No more knife making until the new grinder is in place, new burner is fitted to old forge and ribbon burner forge is built. That should take care of the rest of 2023 2 Link to comment Share on other sites More sharing options...
Bob Ouellette Posted February 17 Share Posted February 17 In anticipation of getting my new forge built, I cut a bunch of stock and ground some patterns to forge to. My goal is to get 26 knives forged before my next foot surgery in April. I also turned a couple of pens from bog oak and mild steel. 2 Bob O "When I raise my flashing sword, and my hand takes hold on judgment, I will take vengeance upon mine enemies, and I will repay those who haze me. Oh, Lord, raise me to Thy right hand and count me among Thy saints." My Website Link to comment Share on other sites More sharing options...
Jaro Petrina Posted February 17 Share Posted February 17 Another one 26 cm. I think its well centered. 2 Link to comment Share on other sites More sharing options...
Bob Ouellette Posted February 18 Share Posted February 18 I got the first 2 of the 26 banged out in about an hour and started on one of the 4 bread knives before I ran out of propane. They're not great forgings, but not awful either. First time lighting a forge in over 2 years. The two blades with the pattern in forging to. 4 Bob O "When I raise my flashing sword, and my hand takes hold on judgment, I will take vengeance upon mine enemies, and I will repay those who haze me. Oh, Lord, raise me to Thy right hand and count me among Thy saints." My Website Link to comment Share on other sites More sharing options...
Jaro Petrina Posted February 19 Share Posted February 19 Hm. Link to comment Share on other sites More sharing options...
Jaron Martindale Posted February 19 Share Posted February 19 On 2/18/2023 at 3:56 AM, Bob Ouellette said: They're not great forgings, but not awful either. First time lighting a forge in over 2 years. The two blades with the pattern in forging to. Those look great! I stop forging for 2 weeks and I can't make more than a piddly butter knife looking thing! 1 Link to comment Share on other sites More sharing options...
Bob Ouellette Posted February 19 Share Posted February 19 1 minute ago, Jaron Martindale said: Those look great! I stop forging for 2 weeks and I can't make more than a piddly butter knife looking thing! I appreciate it, but I know I'm capable of better. Here's number 3 of 8 of this shape. I got the material I wanted in the heel and I had to remember to do that. I forged this one yesterday and fought to hit my 14" goal for the blade length of a bread knife. 1 Bob O "When I raise my flashing sword, and my hand takes hold on judgment, I will take vengeance upon mine enemies, and I will repay those who haze me. Oh, Lord, raise me to Thy right hand and count me among Thy saints." My Website Link to comment Share on other sites More sharing options...
Jaro Petrina Posted February 19 Share Posted February 19 5 hours ago, Bob Ouellette said: I appreciate it, but I know I'm capable of better. Here's number 3 of 8 of this shape. I got the material I wanted in the heel and I had to remember to do that. I forged this one yesterday and fought to hit my 14" goal for the blade length of a bread knife. What is the material? Link to comment Share on other sites More sharing options...
Bob Ouellette Posted February 19 Share Posted February 19 28 minutes ago, Jaro Petrina said: What is the material? These are all 1084. Bob O "When I raise my flashing sword, and my hand takes hold on judgment, I will take vengeance upon mine enemies, and I will repay those who haze me. Oh, Lord, raise me to Thy right hand and count me among Thy saints." My Website Link to comment Share on other sites More sharing options...
