It has been tough finding time to hit the forge but I found this evening, not finish but rough forged to shape it will be annealing overnight 52100 pare/paring knife. The wife has been on me but it is 10pm and it is time to head to the day job.
  • Replies 3.6k
  • Created
  • Last Reply
Top Posters In This Topic
Popular Posts
Finished another folder.  Little bitty bugger, 2.5" / 63mm closed, 4.5" / 112mm open.  O-1, brass liners, nickel silver bolsters and pins, ebony scales.  Still needs an edge and some cleanup, but it's
No knife work since right after Christmas, I've been in furniture mode.  The backstory:  I won a couple of steel scuba tanks with the bottom cut off at an iron-in-the-hat at my local blacksmith's guil
Best I can do for today! Needs more grind work, sanding, and heat treatment. I just couldn't resist getting an etch on it before shutting the shop up.
Posted Images
Well, it wasn't today, but yesterday I destroyed 4 perfectly good pieces of burl wood trying to make a frame handle (actually I tried to make two of them) for a Damascus kitchen knife. Sometimes I think the knife has a mind of its own and when it doesn't like the handle you have chosen, it reaches out and jacks things up. Why can't it just learn to speak English and tell me what it wants?
I converted a 4" diameter 4 grooves v belt pulley to a flat belt pulley by mixing some glass fibers and epoxy ..then forming a smooth shape. Now I need to true it in the lathe and test it. That item will fit on a motor and directly drive a large contact wheel grinder ( 3" by 132" belts).
Edited by Jan Ysselstein
  • 4 weeks later...
Well, it wasn't today, but this last weekend I made some cutting boards that double as display stands for my kitchen knives.
Puttered around the house doing minor things like upgrading electrical outlets, cleaning and same as for the last two months more research on starting something I've dreamed of since the late 80's...... setting up a forge and becoming a part time bladesmith
P.s. yes the warden/accountant is slowly coming around to the idea... probably to stop my constant forum lurking and new responses to her arguments against it
Have you tried the pay-off method? That's where you go to an Open Forge event or Hammer-In and make her something or make something for the house that she thinks is needed.
That way you can say "look at the cool stuff I could be making, if I only had a forge"
About one wife ago I came up with a strategy. If she had a hobby or interest of her own I would get super involved in it to the point of her thinking I was obsessed. I knew I'd won when I heard, " We need to get you a hobby of your own."
That is nice Niels. Why do you call it "Ghetto"?
JJ: If you keep this up, you are going to need a website just for your tool line!
Bummer about the drilled finger, Niels!  I knew a guy to do that a couple years ago myself.  He was drilling a 5/64" hole in a piece of 3/4" pipe intended to be a bushing on a power hammer.  Working tired, etc., end result was he had his finger IN the pipe he was drilling to hold it steady.  :ph34r:  I'll let you imagine the result, but he still has the finger and full use of it.  And no, it wasn't me!
Not too long ago I put my sewing machine needle through my index finger. Right through the fingernail actually.
My rule of thumb on handle length: 4-1/4 to 4-1/2 inches  from the spot the index finger rests against to the point behind the pinky. It looks to me like you should stretch that handle out a half-inch and be just about right.
Nice piece of burl. What is it and where did you get it?
Gerald Boggs got me thinking (always dangerous) about things with his topic one thread over. So I decided to do a trial run of something simple and time myself doing it. I haven't forged a steel leaf in years, but I used to make them all the time for hooks, key rings, towel bar ends, you name it and I've stuck a leaf on the end of it. 5 key rings in an hour and 15 minutes.
Materials cost: Negligible, it was basically scrap, but there's most likely about $1 in steel, and 25 cents in key rings (even though I've had the key rings for about 30 years) I probably spent more on the propane running the forge for an hour than I have in materials.
Anyway, I did the math. If I can sell these for $10 each, that grosses $40/hour for my time. We will see if these sell as table items at the art show next week.
Hello all, no blade work today but I did forge out some s hooks/ j hooks and also made a hand fuller. It is forged from 3/4" S7. Still need to cut the excess off to shorten it down. It is the first tool I have forged myself so I'm happy with it.
Not in my shop, but in a friend's shop, started on what will be a mosaic damascus billet.  Started with 44 layers of 1080 and 15N20.  It is a massive billet.  My body is smoked.
