Joshua States
I'm a work-rest grinder, which means I grind all my blades on a work rest and use a push stick to apply pressure where I need it.
As for the file-jig with the carbide faces, those can be pretty pricey, so if you primarily set your plunge cuts with files rather than a grinder, or you can be pretty careful with a 2x72 running at slow speed, you can make your own file jig from hardened O-1 like I originally did.
And for those of you who are not familiar with work-rest grinding technique: https://youtu.be/il88qhfoJnQ
Looks like I need to rethink my grinding setup.     Great vid Joshua,  never thought of approaching flat grinds that way.  Seems much more efficient than just using the flat platen.
Got to do some sharpening and testing of my latest this evening.   It thinned out more than I'd like in my efforts to make it sharp.   I got it sharp, just not razor like I'd like.  I guess because it's so thick at the ridge and narrow at the base, I couldn't get the right edge geometry, even with the hollow grind.  I got it at .250 on the nose at the ricasso, then .215 at the base of the ridge  which tapers down to around .167 at the ridge of the tip.     It's sharp and will cut, but it's more of a sharpened shank than a fine cutter.
My leather wrap rode up the handle a little whilst I was throwing the thing.  It sticks pretty darn good and deep from 5 paces.   Stabbed into some cat's claw, a real dense wood in the Ironwood family,  stabbed and twisted, stabbed and bent out, and chopped into it as good as I could.   No damage.  The tip bent slightly a couple times during throws and stab/bend tests, which is expected, but no breaks, and stabbed and bent the other way to true it back up, which worked well.   Then I stabbed into an old pressure tank which is probably 1/8" thick or so.   Tip came out unscathed.   All in all, I liked how it performed.
A question for the metallurgists around.    Is there any negative affect a long tempering process can have on a blade ?   I tempered this one in a convection oven at my work.   Left it in there around 7 hours at 350.   Touched 420 for about an hour, then back to 350 for the rest of the day.  Probably overkill.  I dunno.     I mean, in theory if I left a blade in an oven at 350 - 450 (whichever) for over 24 hours,   I don't reach critical temp, so no real negative effects?   So all that can happen is I get full conversion from martensite to tempered martensite ?    Probably just overthinking things again..,
So this showed up at the shop yesterday. Working on getting it set up. Perfect guard slots, here I come!
Jeff H.
CFI/CFII/MEI
KE7ZMH
"Give a man fire and he will be warm for a day. Set a man on fire and he will be warm for the rest of his life."
What model PM is that J ??
I'm in the process of installing a DRO system on my RF-31 style mill drill, and planning on a DRO for my lathe soon.............B)
If ya can't be good don't git caught  !!                                        People who say stuff can't be done need to
        git the hell outta the way of people who do stuff   !!!
Show me a man who is called an expert by his peers
And I will show you a good man to listen to ......
Show me a man who calls himself an expert
and I will show you an egotistical asshole...............!!
It's a PM-25MV. I got it set up and it's surprisingly quiet. I'm glad I got this one vs. the Grizzly. I've also got a X-axis power feed that I need to install.
Jeff H.
CFI/CFII/MEI
KE7ZMH
Yer gonna like what you can do with that puppy...................:D
Speaking of which, beyond milling guard slots, shoulders, and fullers, or making the odd file guide or two, what do you folks use your mill for?
Jeff H.
CFI/CFII/MEI
KE7ZMH
Shaft key ways, rifle parts, tool holders, gears, bolt hole patterns on flanges, and bout any thing ya can't do on a lathe
within the capacity of yer machine..........B)
I should be done grinding on this tonight....its close. I need to lose about 3/8" off the spine to get under 2"...and about 1/4 off the blade to get at/under 10".
My grinding jig is just this piece of aluminum angle. The drill bit stops me at the same spot on my platten/rest for a nice crisp plunge line.
I am still working on my power hammer project; i got the anvil welded in solid, filled the empty spaces under the platform with wood, spray foam, and sheet foam to deaden the sound, and yesterday i was working on layout for the column, and cutting for the upper anvil to column brace. I had ran out of gas for the cutting rig, and switched over to plasma cutting yesterday, but smoked that, too......off to the gas supplier today for O2 and acetylene. I will try to remember to take some photos today.
Well, I'm an engraver now... Luckily the piece I'm using for inspiration is just as sloppy.  I don't think he'd ever engraved anything before either.
Phosphorus bronze destined for sheath fittings...
George Ezell, bladesmith
Buffon
view some of my work
RelicForge on facebook
You can also surface grind stuff like blades, guards, spacers, butt caps, etc. Surface grinding your scales for frames or full tangs is easy to do on the mill. Get yourself a flywheel cutter.
Not bad for your first go laddie…..
Heck, I've been doing it off and on since 2001 and I still can't do parallel lines freehand! :lol:  Looks good, and yes, captures the feel of the period.  B)
I finally have a working coal forge.  Most of the forging I've done up to now has been at friends' forges or at venues where we demonstrate muzzleloader gun barrel forging.  Now I need to make my fire tending tools.  All I have is a coal rake.
It takes practice, as well as putting it off for years until you can gather enough confidence, or just get tired and want to finally finish something and go with whatever happens :)  Is that for the Dürbheim longsax by any chance?
Jeroen Zuiderwijk
And I finally got another big cermonial bronze sword finished! That's no.2. Then I can start finishing no. 3, then another one for myself, and then I already have people lined up for more.... But once I finished no.3, I'll see if I can do some other stuff purely for fun again. I need that :)
Edited by Jeroen Zuiderwijk
Photo added
Jeroen Zuiderwijk
I have a 2" face mill. How do you hold a blade for surface milling the ricasso? I can't see how to do it in a vise. Someone told me you can use a liquid metal fixture like bismuth, but that seems like it would be rather more work than it's worth.
Jeff H.
CFI/CFII/MEI
KE7ZMH
I'd read that straight lines are extremely difficult so figured that would be a great first project...:)
My client and I have a theory that the artist who did the original was rather drunk at the time, so I think I hit that low bar with flying colors.
It's not going to be an exact replica, I'm borrowing design elements from several places.
Buffon
That is an epic piece of work.
Buffon
Do you have a set of hold-down blocks?
Yes, I've got a set of those step-blocks that adjust to different heights. I suppose I could clamp the blade and tang with those, just ensuring that I don't bend them too far.
Jeff H.
CFI/CFII/MEI
KE7ZMH
I put one of those pyrometer-thermos coupler thingys on my welding forge.
Yes, the temp reading looks accurate...…
