Mike Ward 90 Posted December 28, 2019 Share Posted December 28, 2019 Made yet another knife, some small hooks and a hot cut hardie. The hardie is mild with a edge of some scrap 80crv2 welded in. 1 Link to post Share on other sites
Chris Christenberry 346 Posted December 28, 2019 Share Posted December 28, 2019 I spent the better part of today fitting the brass guard to the EDC I'm working on. I've never made a guard so this has been a serious learning process for me. Think I have it to a point I can leave it alone until I get the knife heat treated and am ready to solder the guard. I've got some 60/40 solder, but don't know what flux to use. Someone mentioned Clean Brite, but I think that's not for electrical solder. Any suggestions? Link to post Share on other sites
Alan Longmire 2,723 Posted December 28, 2019 Share Posted December 28, 2019 6 minutes ago, Chris Christenberry said: suggestions Don't solder. A press fit is best, or JB weld if you screw up. The soldered guard is a uniquely mid-20th century complication. If you must, don't use 60/40 or any lead-bearing solder. Get the lead free plumbing stuff and use zinc chloride paste, preferably Lennox tinning flux (has tin powder in it). But again, solderless is happier. A hidden pin can do wonders. Your EDC is stainless, which greatly complicates soldering. Just some advice. Link to post Share on other sites
Chris Christenberry 346 Posted December 28, 2019 Share Posted December 28, 2019 Dang, you would go and complicate matters, wouldn't you????? I've made it so I have .003" gap in it for soldering. JB Weld won't harden in that thin a cross section, will it? I've already drilled it and the knife for the two brass pins...........so no hidden pin is possible at this point. Since I've never soldered a guard before, I never gave a minutes thought to the fact that soldering Nitro-V would pose any problems. Hmmmmm! Link to post Share on other sites
Joshua States 1,717 Posted December 29, 2019 Author Share Posted December 29, 2019 1 hour ago, Chris Christenberry said: Dang, you would go and complicate matters, wouldn't you????? I've made it so I have .003" gap in it for soldering. JB Weld won't harden in that thin a cross section, will it? I've already drilled it and the knife for the two brass pins...........so no hidden pin is possible at this point. Since I've never soldered a guard before, I never gave a minutes thought to the fact that soldering Nitro-V would pose any problems. Hmmmmm! Time to make another guard. I know you didn't want to hear that, but post a pic somewhere and we can guide you to a method (or six) on how to proceed. Then again, you could always just call David and ask him...….I'm sure he'd help you out. Link to post Share on other sites
Chris Christenberry 346 Posted December 29, 2019 Share Posted December 29, 2019 ??? Why do I need to make another guard? I don't understand. Link to post Share on other sites
Joshua States 1,717 Posted December 29, 2019 Author Share Posted December 29, 2019 Also, check out this thread in the ABS forum: http://www.americanbladesmith.com/ipboard/index.php?/topic/2554-fitting-a-guard-–-topic-for-september-2016/page__p__18143__hl__Guard fitting__fromsearch__1&#entry18143 1 minute ago, Chris Christenberry said: ??? Why do I need to make another guard? I don't understand. If you left a gap for the solder and want to go for press fit, you want .003 or .004 too thin, not too wide. Link to post Share on other sites
Chris Christenberry 346 Posted December 29, 2019 Share Posted December 29, 2019 Link didn't work, Josh. Link to post Share on other sites
Joshua States 1,717 Posted December 29, 2019 Author Share Posted December 29, 2019 Crap. It's in the "members only" section. Link to post Share on other sites
Chris Christenberry 346 Posted December 29, 2019 Share Posted December 29, 2019 (edited) Yup, and I'm not one of those. 30 minutes ago, Joshua States said: If you left a gap for the solder and want to go for press fit, you want .003 or .004 too thin, not too wide. Not sure I understand what you mean here, Josh. By "gap", I mean the slot in the brass is .003" wider than the thickness of the blade. Also need to add this is a "U" shaped guard, if that makes any difference. Edited December 29, 2019 by Chris Christenberry Link to post Share on other sites
Joshua States 1,717 Posted December 29, 2019 Author Share Posted December 29, 2019 1 minute ago, Chris Christenberry said: By "gap", I mean the slot in the brass is .003" wider than the thickness of the blade. Yes. In press fitting, the slot needs to be .003"-.004" narrower than the thickness of the blade. There are two methods in press fit. The 2-shoulder and the 4-shoulder method. I cannot explain this filly right now, but can do so later. It's movie night and Liz wants popcorn Link to post Share on other sites
Chris Christenberry 346 Posted December 29, 2019 Share Posted December 29, 2019 Notice my last sentence in last post. It was an "edit". Link to post Share on other sites
Alex Middleton 499 Posted December 29, 2019 Share Posted December 29, 2019 (edited) The .003"-.004" can produce a suprising amount of wiggle, or a relatively noticeable gap to a discerning eye, if it's not filled in like you intended to do with the solder. Especially if you still need to finish sanding the blade. If you haven't finished the edges and face of the guard yet, you can always lay it on edge on your anvil and smack it with a hammer. It will help to close up the slot but will obviously distort other areas that will need to be cleaned back up. I would do it after you finish the blade and have the tang inside the guard when you hit it. You'll end up with a perfect fit. Edited December 29, 2019 by Alex Middleton 2 Link to post Share on other sites
Alex Middleton 499 Posted December 29, 2019 Share Posted December 29, 2019 Shoot, I just saw that you have pin holes drilled in your guard already. That will complicate things. Link to post Share on other sites
Chris Christenberry 346 Posted December 29, 2019 Share Posted December 29, 2019 My dear "sainted" mother always used to say one of my favorite words as a precocious little child was "compilated". She would always laugh and say "Chris always seems to make things compilated in life." Oh well, the road has been rough and I'm used to it. "I shall persevere!" Link to post Share on other sites
Zeb Camper 780 Posted December 29, 2019 Share Posted December 29, 2019 Cool stuff Mike! Finally got in the shop. I had to choose between all my current projects. Made more headway with the guitar. Forgot to get a pic though. In due time! Welded this up on friday though. Happy new year y'all! 6 Link to post Share on other sites
Chris Christenberry 346 Posted December 29, 2019 Share Posted December 29, 2019 Zeb, that's beautiful. I really like it. It's one thing to hammer out some "cute little leaves" on the anvil.........................but it's another to create a thing of pure beauty such as you have. Link to post Share on other sites
Troels Saabye 41 Posted December 29, 2019 Share Posted December 29, 2019 I tried to find my anvil... we held one heck of a party (25 year anniversary for living on the farm) and in that occassion my anvil was moved, and never seen since So the hunt is on. Link to post Share on other sites
Alan Longmire 2,723 Posted December 29, 2019 Share Posted December 29, 2019 Good luck on the anvil hunt, Troels! Nice railing, Zeb! And Chris: the complication of stainless is solved by using a specific solder and flux combo, the name of which escapes me, but is available from Sheffield Supply. But, no gap, even for solder. Press fit no matter what. There should be no visible line after soldering, it will wick its way into the tightest joint as long as the metals are clean and fluxed. It's the "clean" thing that causes problems with stainless. The chrome oxide layer that makes it stainless repels solder like a layer of grease repels water. Edit: Sheffild part #SXS1 solder and #YXS1 flux. If you want antiflux, #MB01. Again, no gaps. Ever. (Insert Mommie Dearest screaming "NO WIRE HANGERS! EVER!!! and you'll get the idea) 1 Link to post Share on other sites
Alan Longmire 2,723 Posted December 29, 2019 Share Posted December 29, 2019 Oh, and your blade has to be heat treated before you solder the guard, so wait until that's done before you start the new one. Link to post Share on other sites
Chris Christenberry 346 Posted December 29, 2019 Share Posted December 29, 2019 Well, while I'm a total neophyte to all of this, Alan, I do know I've got to wait until the blade has a HT to do the soldering. I just want to be sure and not ruin it with the soldering heat. Thanks for the Part numbers. I'll get right on it. Link to post Share on other sites
Troels Saabye 41 Posted December 29, 2019 Share Posted December 29, 2019 Thanks Allan yeah I got a pretty good idea of where it is, the only problem is lack of tools to dig it out... 200+ kg af steel doesn't play nice with manual lifting... Link to post Share on other sites
Alex Middleton 499 Posted December 29, 2019 Share Posted December 29, 2019 That must have been one helluva party! 1 Link to post Share on other sites
Chris Christenberry 346 Posted December 29, 2019 Share Posted December 29, 2019 I agree with you, Alex. I remember a party while I was in the military "way back when" that was so wild I lost my car keys.................but I've sure as heck never misplaced an anvil. Link to post Share on other sites
Martin Tiney 41 Posted December 29, 2019 Share Posted December 29, 2019 (edited) I went to a party and lost a whole weekend, that was a good party..... I think !!! Edited December 29, 2019 by Martin Tiney Typo.... Again! Link to post Share on other sites
