How IS YASURIMEI done?
JeffFogleboch
hey guys i was just wondering if you could explain how the decorative filing on japanese blades is accomplished. Yes, I do know it is done with the file and I have done perpendicular file marks using the corner of a file but there must be some trick. Whenever I try the file does not cut a straight line or it skips. I really want to know how to do the "Kesho" pattern. If you look at some howard clark blades and nihonto the filing is near flawless! Thanks!
Practice. There is no trick.
My life is like shaving with a razor sharp machete. It's a bit awkward and I feel a sting every now and then, but in the end I'm happy with the results.
Great pic. Looks like a special file as well. I see two prominent ribs. I hear in the past the file was held at an angle to cut with edge....
I wonder if the thumb guide has a lip on the other side to help anchor it in place?
Regards
Brownells also sells "checkering files" starting at 20 lines-per-inch and going as high as 75 lines-per-inch. I thought of those when I saw this. I believe they sell jigs for holding the files at angles too. Cheating, I know... ;)
  • 3 weeks later...
I have checkered many a 1911 frame with these files. I've also used them to cut lines in the end of drill rod to make wood checkering tools, and made checkered end chisels for stippling. I feel that the files are worth every penny in time saved.
