Mick Maxen Posted April 18, 2016 Share Posted April 18, 2016 Both rings are about 21mm diameter, 1 Link to comment Share on other sites More sharing options...
JDWare Posted April 18, 2016 Share Posted April 18, 2016 WOW... FANTASTIC! J JDWARE KNIVES Link to comment Share on other sites More sharing options...
Justin Mercier Posted April 19, 2016 Share Posted April 19, 2016 <3 pattern welding your name into them. Now you need to make the One Ring... with the elvish script pattern welded into it ! *ducks and flees from impending flogging* --- Justin "Tharkis" Mercier www.tharkis.com Link to comment Share on other sites More sharing options...
deker Posted April 19, 2016 Share Posted April 19, 2016 (edited) Very nicely done Mick! If you don't mind me asking, how many twists per inch did you do on the stock? Edited April 19, 2016 by deker Link to comment Share on other sites More sharing options...
Alan Longmire Posted April 19, 2016 Share Posted April 19, 2016 MICK! How've you been, sir? Did you make those from that bar of Maxen-steel you've had for a while, or were they from another purpose-made bar? If so, you've outdone yourself once again. Top form! Link to comment Share on other sites More sharing options...
Mick Maxen Posted April 19, 2016 Author Share Posted April 19, 2016 Hello Alan, very well Thank you although I am another year older today. The name bar is from the stock I made years ago. I probably have about 20" of the stuff left. Matt, there are no twists in the ring other than the side pieces that were made with 28 layers and twisted. Think of the ring being just a square about 25mm by 11mm before it was ground to a ring. Mick. Link to comment Share on other sites More sharing options...
