Joël Mercier Posted November 12, 2018 Share Posted November 12, 2018 Yeah, for choppers and large Bowie's, better use 1474-1500°f austenizing and somewhere between 375-392°f temper. For kitchen knives, edc's and razors, 1550-1575°f austenizing and 330°-375° temper seems best. Link to comment Share on other sites More sharing options...
Adam Weller Posted January 26, 2019 Share Posted January 26, 2019 Has anyone done any testing on these numbers? I am about to heat treat some 80crv2 blades (small blades, under 3 inches) and just wondering if there was a consensus... My thoughts from what I read above: Normalization: 1) Slow climb to >1600F 2) Slow climb to 1550F 3) Slow climb to sub critical (1420F) Quench: 1) 1550-1575F to Quench (I'm using warm oil) Temper: 1-2 hours of each of the following. (I didn't see a consensus here - so this is my thought based on what I read?) 1) 350 2) 365 3) 375 This should yield a blade in the 61-63 hrc range. Any thoughts on a homemade anti-scale compound (I'm hoping to heat treat soon and don't want to wait for an order of ATP-641 to come in), does this help prevent decarb too? Let me know if I'm totally off here and please address anything I should change. I'll report back my results. I have a couple blades I don't like and will probably run them first and break them. Thanks Adam Link to comment Share on other sites More sharing options...
Joël Mercier Posted January 26, 2019 Share Posted January 26, 2019 Those temps sounds right but the resulting hardness is a bit high. If you want around 61hrc, don't go above 350°f. This steel decarbs more than others because of the higher aus temp and hold time. If you don't use ATP, the longer the soak, the thicker layer you'll get. 2-3 minutes is enough imo. Link to comment Share on other sites More sharing options...
JASON VOLKERT Posted January 26, 2019 Share Posted January 26, 2019 (edited) @aweller I have heard of people using "Boric acid" as "antiscale" Its basically roach killing powder that you can buy for cheap at any local hardware/big box store. I have not tried it. This is just what I have heard about on the "internet" . There is also this recipe I got from another "Forum" "Boric acid and alcohol is the standard cheap and easy anti-fire scale dip for our industry ( goldsmith). I have a 50 pound barrel of it. It also works well as a fluxing agent when mixed with borax and a bit of powdered charcoal. As to making HT anti-scale, mix it with alcohol and satanite. Shake up the bottle and apply a thin wash. It will dry and coat the metal, preventing scale.Let dry well before HT. Removal can usually be done with washing in hot water, or soaking in mild acid ( vinegar works fine).A post HT acid soak is usually desirable for several reasons anyway.What I have been able to reverse engineer from using Turco, is that it is a borate with red/brown/yellow ocher mixed in. There is also some sort of colloidal carrier. Ocher is known as goethite, and is nothing but iron oxide clay ( basically ,red clay). I made a batch with boric acid, borax, satanite and ocher, with gum tragacanth as the binder, and it worked identical to Turco. I used a mixture of red and yellow ocher, since I have both on hand. Chemically, the ocher, which is an oxide of iron (mostly Fe/2-O/3), acts as a reducing agent. The various colors of ocher are just the amount of hydration, and are identical otherwise. Yellow is fully hydrated, brown is partially, and red is anhydrous.Another cheap and very useful anti-scale is plain water and satanite mix. Make a thin slurry and put a wash coat on the blade. Dry it with a hair dryer, or let it air dry. Another thing to try would be a slurry of potters clay.If you wanted to make a batch of anti scale try this (Quantities are in fluid oz.):( This is off the top of my head, so feel free to tweak it as desired)5oz boric acid (roach powder)3oz borax ( 20 mule team is fine)8oz denatured alcohol ( the cheap paint store variety, not the drug store stuff)2oz satanite ( our old refractory friend)3-4oz ocher (any color ocher - finely sifted dried red clay would probably work)3-4oz gum tragacanth ( bottle of leather edge dressing)waterMix,adding additional alcohol until it becomes a well mixed thick paste.Add water until it becomes a slurry ( I think it needs some water to allow proper hydration and solution of some ingredients). Try it on a piece of steel to check results, and adjust the ingredients as needed. Keep in a tightly capped container,away from heat. Shake well each use, and paint it on with a small brush, or dip the blade and let the excess run back into the container. A batch should last for a long time.Do not use above 1600F as the borates will become corrosive." Edited January 26, 2019 by JASON VOLKERT Link to comment Share on other sites More sharing options...
Adam Weller Posted January 26, 2019 Share Posted January 26, 2019 4 hours ago, Joël Mercier said: Those temps sounds right but the resulting hardness is a bit high. If you want around 61hrc, don't go above 350°f. This steel decarbs more than others because of the higher aus temp and hold time. If you don't use ATP, the longer the soak, the thicker layer you'll get. 2-3 minutes is enough imo. I don't think I need it that hard, but I'll try sticking below 350. 2-3 minutes is about the longest I can hold a temperature in the propane forge, so I hope that's enough. 2 hours ago, JASON VOLKERT said: I have heard of people using "Boric acid" as "antiscale" Its basically roach killing powder that you can buy for cheap at any local hardware/big box store. Not sure if we have roach powder here (not an issue where I live - roaches don't seem to appreciate the sub zero temperatures) but I'll check when I go by the hardware store today.... If they have some I'll give it a try, otherwise I might just mix up some satanite and try a thin wash. Thanks! 1 Link to comment Share on other sites More sharing options...
Adam Weller Posted January 27, 2019 Share Posted January 27, 2019 Well I gave it a run on a throw away blade. I followed the schedule I posted above with the exception of the tempering which I dropped below 350 per Joël's recommendation. I haven't completed the tempering yet, so there is more to come. (I'm kinda double posting because this is all in my WIP post as well, hope that's okay) After normalization there was a thick layer of scale ( I didn't use any anti-scale coating, no luck on finding Roach killer at the hardware store) After quench the file bit pretty good but after a quick grind I got the file to skate I broke the tang to see the grain. Again, sorry for the picture quality, I took it through a magnifying glass. Let me know what you think, or if you need a better picture. This is about a 1/4 inch wide. closer? I plan on breaking the blade after temper to see what it looks like too, so more to come. Thanks Adam Link to comment Share on other sites More sharing options...
Alan Longmire Posted January 27, 2019 Share Posted January 27, 2019 The grain could be better. It's not terrible, but it could be smaller. How many normalizing cycles did you do, and did you soak before quenching? Link to comment Share on other sites More sharing options...
Joël Mercier Posted January 27, 2019 Share Posted January 27, 2019 The grain is a bit large. Has this area of the tang been through the same heats than the blade? If so I'd add an extra normalization cycle or two. Link to comment Share on other sites More sharing options...
Adam Weller Posted January 27, 2019 Share Posted January 27, 2019 1 hour ago, Alan Longmire said: The grain could be better. It's not terrible, but it could be smaller. How many normalizing cycles did you do, and did you soak before quenching? Three normalizing cycles, minimal soak 1-2 minutes max. I do let it cool to black, still hot but definitely black in a dark room. To answer your other questions the baffle tube is almost completely closed off on one end - there is a 1/4 inch hole in the back plate. I’ll try closing that off, and try the charcoal you mentioned in the other thread, thanks! 1 hour ago, Joël Mercier said: The grain is a bit large. Has this area of the tang been through the same heats than the blade? If so I'd add an extra normalization cycle or two. The tang was probably a few degrees hotter than the blade given it was closer to the burner in the baffle tube, I’m going to break the blade itself as well - so I will post that too. Does it matter that I’m breaking it after tempering? Link to comment Share on other sites More sharing options...
Joël Mercier Posted January 27, 2019 Share Posted January 27, 2019 36 minutes ago, aweller said: Does it matter that I’m breaking it after tempering? It doesn't but tempering is useless if you plan to break the blade. It just makes the blade harder to break and the break line won't be as clean. Link to comment Share on other sites More sharing options...
Adam Weller Posted January 27, 2019 Share Posted January 27, 2019 36 minutes ago, Joël Mercier said: It doesn't but tempering is useless if you plan to break the blade. It just makes the blade harder to break and the break line won't be as clean. I kinda want to see what the tempering accomplishes. How much harder it is to break and how much deformation it introduces... Link to comment Share on other sites More sharing options...
Joël Mercier Posted January 27, 2019 Share Posted January 27, 2019 It sorta makes sense but the resulting toughness added by the tempering will be biased by the larger than should be grain size. You should tune up your grain before doing tempering tests. Link to comment Share on other sites More sharing options...
Alan Longmire Posted January 27, 2019 Share Posted January 27, 2019 I agree with Joel on that. Tempering that blade isn't going to tell you a lot about how good grain size will perform. Link to comment Share on other sites More sharing options...
Adam Weller Posted January 27, 2019 Share Posted January 27, 2019 Good point. I wont worry about tempering yet. I'll adjust, redo and let you know how the next run turns out. Link to comment Share on other sites More sharing options...
Joël Mercier Posted January 27, 2019 Share Posted January 27, 2019 1 hour ago, Alan Longmire said: I agree with Joel on that. Yay! After so many questions, I start getting things right . Link to comment Share on other sites More sharing options...
Adam Weller Posted January 28, 2019 Share Posted January 28, 2019 Second run. I think it looks better. I changed a few things. closed up the 1/4" hole at the back of my baffle tube and added a chunk of charcoal in there during the normalization and quench. All but eliminated the scale. There was minimal decarb, wondering if it was the "down" as I lay the blade in the tube on it's side. Maybe I'll try to figure out how to make a stand so it rests on the spine with the blade up. Here was my set up this time. I turned the whole forge around so the hot zone in the baffle tube was in front of the blade (not involving the tang), the blade sits directly below the thermocoupler. Almost no scale and minimal decarb per file test and grinding and here is the cracked blade, to my untrained eye this looks considerable better than the prior test. The ruler is in cm. Any thoughts? Thanks. Link to comment Share on other sites More sharing options...
Doug Lester Posted January 28, 2019 Share Posted January 28, 2019 It looks like your camera was focusing more on the ruler than the end of the tang but off hand I'd say that it looks a lot better. Doug HELP...I'm a twenty year old trapped in the body of an old man!!! Link to comment Share on other sites More sharing options...
Joël Mercier Posted January 28, 2019 Share Posted January 28, 2019 Seems excellent! Link to comment Share on other sites More sharing options...
Alan Longmire Posted January 28, 2019 Share Posted January 28, 2019 Yep, that's what it's supposed to look like! Link to comment Share on other sites More sharing options...
Adam Weller Posted January 28, 2019 Share Posted January 28, 2019 Thanks all, I'm liking this setup a lot better. I might tweak a few things. I'll try to get to another blade tonight after work and take it all the way through heat treat. Link to comment Share on other sites More sharing options...
Joël Mercier Posted May 27, 2019 Share Posted May 27, 2019 Here's a test piece I've done today. 1575°f held 5 minutes. I can barely see any grain. It took a good 3 pound hammer hit to break the piece in two. The upper part was sent flying and hit the wall 30 feet away. Tough stuff... Link to comment Share on other sites More sharing options...
Alan Longmire Posted May 27, 2019 Share Posted May 27, 2019 Grain? I don't see any grain... Link to comment Share on other sites More sharing options...
Wes Detrick Posted June 24, 2019 Share Posted June 24, 2019 On 5/27/2019 at 2:03 PM, Joël Mercier said: Here's a test piece I've done today. 1575°f held 5 minutes. I can barely see any grain. It took a good 3 pound hammer hit to break the piece in two. The upper part was sent flying and hit the wall 30 feet away. Tough stuff... Did you temper? “In the midst of winter, I found there was, within me, an invincible summer." -Albert Camus http://www.krakenforge.net/ Link to comment Share on other sites More sharing options...
Joël Mercier Posted June 24, 2019 Share Posted June 24, 2019 @Wes Detrick I did not. I used pliers to break the coupon again and it broke much cleaner. Link to comment Share on other sites More sharing options...
JackBarry Posted December 29, 2021 Share Posted December 29, 2021 I need some help with heat treating this steel. I used it for my last two blades and neither hardened like they should have. I’m using an atmospheric (non-blower) propane forge with a baffle pipe, and a thermocouple. I used Wes’ normalization process at 1600, 1550, and 1500, and then brought the blades up to 1500, soaked for 2 to 3 minutes keeping the temp as close to 1500 as I could by adjusting the gas. I then quenched in warmed canola oil. I tempered for 3, 2 hour cycles at 350, 375, and 400. I temper in my oven using an oven thermometer and a pan full of sand to regulate the temp. On the first blade the file bit into the edge a bit but I assumed that was due to decarb and I carried on and finished the blade and knife. The first time I used the tip on a relatively hard a substance however, it bent right over like a crochet hook. To try to reduce the decarb on the next blade, I used anti scale compound and followed the same normalization, quenching, and tempering temperatures. This one seemed to skate a file after quench so I was happy and went on and finished the blade. This one is a Bowie and as I was fitting the guard I noticed that a file was biting into the tang just behind the ricasso. I hadn’t done anything to make that area softer so I was concerned. I tested the edge again with a file and this time it bit into the steel. I had ground and hand sanded the blade after hardening so I can’t imagine I’m still dealing with decarb. I’m now thinking the file skating after quench was due to the anti scale compound cooked onto the blade. Regardless, the blade is not hard now. I’m not sure what I’m doing wrong and any advice would be greatly appreciated. Link to comment Share on other sites More sharing options...
