Yesterday I started welding together my first billet of Damascus steel. I started out with six layers of bandsaw blade for my initial weld, which I then welded, drew out, cut, stacked, and welded again. Before I spend too much time on this billet I would like to know if it will show any pattern at all when etched, given that it is made out of only one alloy of steel
We are waiting for you to tell us that.....there should be a pattern due to the change in composition at the welded surfaces. That change is often associated with decarburization you may be able to limit that to a very slight amount. Cable damascus is an example of that process.
Jan
Yes, Scott Roush made a couple of swords or parts of blades from pieces of 1095 shim stock (I had a coil that I traded him that was about 10 yards long of .05" x 1.25"). He made some really interesting blades with this. Subtle, but visible.
Etch with very dilute ferric chloride.
kc
