AS08: Double-Edged Clip-Point Fighter
Jason McEntee
My first commission piece, this is loosely based on the blade used by Tormund of the free-folk from Game of Thrones; however, this one is double-edged. The blade was heat treated by Lyndle Driggers of J&L Custom Cutlery. Here's the blade it was inspired by:
The specs:
Steel: 1075
Overall length: 19.75"
Blade length: 13"
Distal taper: 4.6mm to 2.4mm at 1" from tip
Grip length: 6.75"
POB: 0.75" past front of grip
Weight: 1 lb, 2 oz
Handle: Bocote
Edited by Jason McEntee
Fixed image links.
The only thing that I can suggest is that you start with thicker scales and try for a bit more of a palm swell in the middle. It will make it want to sit in the hand better than a flat slab.
