Propane Gauge and Regulator
Eric Dennis
Hello,- I'm working on putting together a forge and am looking at propane regulators. I don't know a ton about this stuff so bear with me. If I get a regulator like this, can I put a gauge down the line from it since there is no port on this particular regulator? How does one add a gauge to line? Can it simply screw into a T-Fitting of some kind?
Help me shed some light on this conundrum.
Thanks,
That unit looks a lot like the regulator on my turkey fryer. Are you certain that the pressure is adjustable or is it just basically on and off? A regulator like that wouldn't need a gauge because it only runs on one pressure setting. It will be a bit more expensive but do the job and be less likely to crap out on you but you can look at High Temperature Tools and Refractory. You can get the entire assembly that you need with the POL coupling, regulator, gauge, and hose for in the main $60 range, depending on the length of hose that you order.
The link says that it is fully adjustable from 0-20 psi. And I think you could put a T and gauge in later (with mildly reduced accuracy, I would think). You would have to have the 1/4 turn ball valve near the forge (that you have for safety) turned off to read the right pressure though. But by the time you buy the gauge and T and such, I don't think you'll be saving much, if any, money. The flip side to that though, is that I would argue that you don't actually need a gauge. You need to be able to adjust the pressure to match your orifice and air intake (for either forced or naturally aspirated) and get that ratio correct. Putting a number on it doesn't really mean much.
Hmm. Good point about not necessarily needing a gauge. I guess it can be a reference point though- so if something changes I can refer to how the forge ran at a certain psi. Not necessarily important in the short term though. The forge is forced air, so I would prefer a set up with a gauge not more than 20 maximum psi. I figure if I'm going to have a gauge, a 1-10 or 1-15 psi range would be better for accuracy when I'm trying to dial it in the under 5 psi range.
Missed the 20 psi on the regulator. Next question is will that going to be enough pressure? Before I went to a blown burner the venturi burner that I got from Zoeller Forge came with a 60 psi regulator and I think that that's what High Temperature Tools and Refractory recommends for the aspirated burners they carry.
