Gough jig
ScottWright
I decided that the easiest way to get a good grind down with files was the gough jig after some research both on google and here. Today I decided to build and test it out. Not finished filing but I did give it a go on a rr spike I just finished.
I've been looking to make one myself as the cost of a 2"x72" build
is out of reach for now on a disability income, some feedback
on it would be appreciated........ B)
If ya can't be good don't git caught  !!                                        People who say stuff can't be done need to
        git the hell outta the way of people who do stuff   !!!
Show me a man who is called an expert by his peers
And I will show you a good man to listen to ......
Show me a man who calls himself an expert
and I will show you an egotistical asshole...............!!
I've made a few of these as give aways for a few new knifemakers. I very quickly stopped using wood and moved on to using mild steel. The wood is too flexible and doesn't give repeatable results, the guide holes wear, etc. Make a tee piece from two bits of scrap steel by bolting or welding and drill a hole big enough to take a six inch eye bolt at the end opposite the tee. With two nuts and washers this will be your height adjustment for the guide rod. Across the tee section superglue a thin piece of steel, thinner than your blade steel, to act as a repeatable stop for your blade. Using a pair of vice grips, clamp your blade to the tee section, put the rod with the file attached through the eye bolt and use the nuts and washers to adjust for height to give you the bevel angle.
With a bit of fiddling, some masking tape and a few pencil marks, you can produce as many blades as you like, all with a repeatable bevel.
I've probably not explained this too well, but if anybody would like pictures of a finished jig I'll try and get some up later. It's too early here to do it now!
I built one because my harbor freight 4X36 gives inconsistent hand grinding results. I will learn to do bevels by hand once I build a 2X72. in the mean time this jig works pretty good and gives consistent width on bevels, mostly because I have it screwed down to my table front and back. I also go nice slow even strokes when pushing the file.
One thing you can do with a 4" carpentry type belt sander is split the belts in two (or more).
You can also rig some kind of shim between the belt and platen to lift the belt up a little to give more versatility.
I started with such a sander myself. They're not ideal but there are ways to maximise their usefulness.
I find that a 4" sander is great for even flat grinds, but that's just me
it's probably my unskilled hands, I will practice more and post results.
I've just knocked up one of these jigs and had a go with it too (first knife. Well, technically my second, but we don't talk about number one...). It seemed to work pretty well, but I had a bit of trouble getting the plunge lines even. I think I'll just blend them.IMG_8030.JPGIMG_8031.JPG
Edited by Fergal Fleming
On your file, did you get one that has smooth sides, or did you grind off the teeth on the sides?
When I first started, I used one of these jigs as well, worked very well, but I had similar issues with lining up the plunge lines, one side would cut just slightly further in then the other, and had a slightly different shape. in my instance, it was the file teeth on the side of the file causing it.
I found that by grinding the teeth all the way off to flat metal, and using the stop bolt to help line the file up before filing, allowed me to get them much MUCH closer lined up to nearly perfect.
I too had the same issues as Robert. One thing I did extra was to put threaded inserts into the holes to make it last longer and it worked well. But still, Its hand filing and it gave me the nudge to finish my 2X72 belt grinder :D
The finest steel has to go through the hottest fire.
Still haven't had a chnace to finish my file work. I work nights so I usually only get to work on weekends but I rounded my edges off to avoid it getting caught when working it laterally.
I reckon that might be part (or even most) of the issue. I was in a bit of a hurry to get started, and while one side is ground perfectly smooth, the other one is only mostly smooth. I also put a slight radius on the corners, which may have been a mistake, as I doubt these unskilled hands created two identical radii :-)
Edit: I don't mean to jack your thread, Scott. I just thought I might chip in because I've just made Gough jig too :-)
No I'm new here and don't mind everything in read is more knowledge everyday I'm seeing more that makes me want to work even more at this. So hijack away
