Want to share with you my belt grinder build.
- it use 1/4 thick 2 inch square tubing as chassis, really robust.
- I'm extremely happy with the tool rest system. It's rigid, flexible and easy to build. you can see in some pictures I even fold the tool rest inside the grinder so I can turn/true up the wheel.
- the MDF wheel was holding up just fine, couple knifes and some heavy metal grinding later no wear so far. Even if they do wear out, it's super cheap and easy to make a new one.
- the power is 3/4 VFD powerful enough for my need
- machine can setup on horizontal use, with just one screw and one pin, under 5 seconds
- total build cost < $500
I have a blog on how I build it:
IMG 20160621 104312
IMG 20161010 193622
IMG 20161010 193619
IMG 20161010 190453
IMG 20161010 190426
IMG 20161010 184005
IMG 20161010 183448
IMG 20160803 212131
IMG 20160803 211853
IMG 20160724 120943
IMG 20160724 120038
IMG 20160724 120035
IMG 20160724 105744
IMG 20160724 105438
IMG 20160724 105424
IMG 20160724 105335
IMG 20160723 213016
IMG 20160702 213331
IMG 20160702 205430
IMG 20160702 180117
IMG 20160625 202931
IMG 20160625 202915
IMG 20160625 202900
IMG 20160625 191321
IMG 20160623 220044
Edited by rogerxue
