Bar Stock - TN
JohnnyC
Curious if anyone knows of a vendor or supply house in the Nashville area that carry's bar stock for knife blanks. Yes, can order on line, but thought there may be a local supplier or metals company that has stock.
Understand NJ Steel Baron is preferred vendor, but just starting out and looking for materials locally before ordering any volume of materials.
thanks
JC
If you a going to do HT yourself, I highly recommend going to an automotive spring manufacturer. Personally, I'd start with Nashville Spring Services. If they don't have any then they should be able to point you in the right direction. There MUST be someone in the area that does it.
You are almost certainly not going to find a local supplier of hardened and tempered steel, so I hope you're at least planning on heat treating (even having someone else heat treat it) after the stock removal. It is nicer that way, too; as you can remove material quickly without worrying about ruining the temper and going through a lot of abrasives.
