Adam Betts
Twin hand-axes
...not identical twins, obviously, but the heads came from the same Jeep axle and the handles came from the same hickory log and I finished them at the same time. Not made for any particular reason, just to feed my obsession with axes.
One is a Kentucky belt axe type of thing, the other has a miniature Hudson Bay look going on. The longer one is a bit over a foot from heel to head, the shorter one is just under a foot. Edge length is around 3 inches. They both balance just in front of the eye, which is usually desirable on many working axes.
The handles are of local shagbark hickory, felled (if memory serves) in the Ashford area of Connecticut several years ago. They have a sort of rounded diamond profile which I have found indexes the axe very well and looks cool to boot.
Splitting my own handles out of logs ensures that the grain runs straight and true. I finish shaping the handles with a hand scraper, because it leaves a surface that is both smooth and slightly textured, making for a good grip. They are then finished with tung oil. This log was just barely big enough for small axe handles, but the grain was really tight and I really wanted to keep it.
They are wedged with mahogany, both because it's beautiful and because it's an ideal wood for the task, since it is light but hard. Normally it would be a tad expensive to make wedges with mahogany, but I happen to have been gifted a huge box of off-cuts from a friend whose parents built a whole deck out of it at their place in the Hamptons (it's good to be friends with people far wealthier than oneself on occasion).
Thanks for looking!
Now they really are a beautiful pair, an indispensable tool superbly made.
Steve
If you found the handle wood in Ashford, shouldn't it be ash, not shagbark hickory? :D
Thanks guys!
Bill, does that mean the ash log I have from Lebanon is actually a Lebanonwood tree? :D
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
