guarnera Posted August 10, 2005 Share Posted August 10, 2005 This has probably been covered, but I did a search and couldn't find the answer. I was looking at the book "The Viking Sword" last night, and I was wondering how they did the wire inlay on the pommels and gaurds? I know how an engraver would do it. He would cut a grove about the diameter of the wire, then under cut the sides of the groove, and then lay the wire in the groove and tap the wire into place so that it expands into the under cut of the groove so that its fixed in place. However, the wires are laid so close together on these gaurds and pommels that it does not look like there is enough room to under cut the grooves. Does anyone know how this was done? Thank you Tony Link to comment Share on other sites More sharing options...
Michael Posted August 10, 2005 Share Posted August 10, 2005 http://www.bladesmithsforum.com/index.php?showtopic=3379 Link to comment Share on other sites More sharing options...
Jeff Pringle Posted August 11, 2005 Share Posted August 11, 2005 (edited) ...and the grooves are cut to somewhat less than the diameter of the wire, so they (the wires) spread out over the surface as well as into the groove. Edited August 11, 2005 by Jeff Pringle Jomsvikingar Raða Ja! http://vikingswordsmith.com Link to comment Share on other sites More sharing options...
