Anthony Reid Posted January 19, 2017 Share Posted January 19, 2017 As I mentioned in my previous post I am working on streamlining my tools and work flow. One area I see room for improvement in is in how I hold knives while I file or polish them. Right now I use a chunk of angle iron clamped in the bench vise with the blade clamped on top with a small c clamp. I would love to see what other people are using and hear any suggestions you may have Link to comment Share on other sites More sharing options...
Geoff Keyes Posted January 19, 2017 Share Posted January 19, 2017 I use something like this http://www.riversidemachine.net/ecommerce/riverside-moran-vise.html http://www.mstarling.com/knife_vise.html http://www.stoneandsteel.net/knife-vise/ http://www.northcoastknives.com/northcoast_knives_tutorials_hints_tips10.htm http://www.mountainhollow.net/knife-vise.php Geoff "The worst day smithing is better than the best day working for someone else." I said that. If a thing is worth doing, it is worth doing badly. - - -G. K. Chesterton So, just for the record: the fact that it does work still should not be taken as definitive proof that you are not crazy. Grant Sarver Link to comment Share on other sites More sharing options...
Anthony Reid Posted January 19, 2017 Author Share Posted January 19, 2017 Geoff those vises look great! do you use it for blade work or mostly for shaping and sanding handles? I do a lot of draw filing and hand sanding so I need something that will work well for that as well as handle work. How hard would it be to fit a removable blade support for a vise like that? Also do you line the jaws with anything to help keep the knife from scratching/ help it conform to the blade or tang? One of the areas I struggle is with my rhomboid puukko blades as they have no ricasso and in order to fit bolsters the tang has to be beveled the same as the blade otherwise the tang ends up being thicker than the blade bevels making it impossible to get a gap free bolster. All that to say that its hard to clamp a narrow diamond cross section tang so that the blade doesn't move when polishing and I wonder if the vise designs you posted would help? Link to comment Share on other sites More sharing options...
Geoff Keyes Posted January 19, 2017 Share Posted January 19, 2017 I use mine for both handles and blades, Mine is lined with leather. I also use several other things. I use a Jorgensen clamp clamped in a vice. I use a long piece of wood about an inch wide clamped in a bench vice to work on more flexible blades. A long piece of wood with a "U" shaped staple is handy. The tang, or the blade, goes under the staple and a wedge (wood, micarta, hard rubber) is tapped under the stape to hold the blade. You do want to be careful with all of these. One of Don Fogg's students had a long blade clamped to a 2x4 support with about 4 inches of the tip overhanging the end. He turned to get something, turned back and drove 4 inches of blade into his chest. He was pissed because he missed the rest of the class. The rotating vices are nice and a time saver Someone made a ball and clamp setup with a bowling ball, kind of an engravers vice, and two rings. The ball was held in the rings, with a jack to change tension http://http://www.bing.com/images/search?q=bowling+ball+welding+table&qpvt=bowling+ball+welding+table&qpvt=bowling+ball+welding+table&qpvt=bowling+ball+welding+table&FORM=IGRE A vice attached to ball and you'd have a multi position clamp. Geoff "The worst day smithing is better than the best day working for someone else." I said that. If a thing is worth doing, it is worth doing badly. - - -G. K. Chesterton So, just for the record: the fact that it does work still should not be taken as definitive proof that you are not crazy. Grant Sarver Link to comment Share on other sites More sharing options...
Doug Crawford Posted January 19, 2017 Share Posted January 19, 2017 Walter sorrels posted a knife vise tutorial earlier today- looks simple and effective https://youtu.be/0lw9056hbIQ Link to comment Share on other sites More sharing options...
Geoff Keyes Posted January 20, 2017 Share Posted January 20, 2017 And there you go g "The worst day smithing is better than the best day working for someone else." I said that. If a thing is worth doing, it is worth doing badly. - - -G. K. Chesterton So, just for the record: the fact that it does work still should not be taken as definitive proof that you are not crazy. Grant Sarver Link to comment Share on other sites More sharing options...
Dave Stephens Posted January 20, 2017 Share Posted January 20, 2017 I have one of these, and it works great for sanding the assembled blade. Similar concept to what others have posted above. -----------------------------------------------"It is not the critic who counts; not the man who points out how the strong man stumbles, or where the doer of deeds could have done them better. The credit belongs to the man who is actually in the arena, whose face is marred by dust and sweat and blood, who strives valiantly; who errs and comes short again and again; because there is not effort without error and shortcomings; but who does actually strive to do the deed; who knows the great enthusiasm, the great devotion, who spends himself in a worthy cause, who at the best knows in the end the triumph of high achievement and who at the worst, if he fails, at least he fails while daring greatly." -- Theodore Roosevelthttp://stephensforge.com Link to comment Share on other sites More sharing options...
Geko Posted January 20, 2017 Share Posted January 20, 2017 my vise is not as clean build as daves but the same style. i use it just for shaping / finishing the handels. cheers. "Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius - and a lot of courage - to move in the opposite direction." --Albert Einstein Link to comment Share on other sites More sharing options...
