• Announcements
    • Alan Longmire
Joshua States
First Time into this fray
14 posts in this topic
So, I was cordially invited to participate in an iron smelt sometime this spring. In the discussion about how it was going to happen, I mentioned that I was preparing to make a bunch of softwood charcoal (https://www.bladesmithsforum.com/index.php?showtopic=32964&page=13, post #253) and would gladly contribute all of it, should I be able to participate. So, today I tried it out.
First I had to build the retort. I'm using the barrel off of a small cement mixer that the motor burned out. I cut the bottom off a barrel I got with about 45 gallons of heat treating oil for the burner area and made an opening for the burner.
I split the wood into roughly 2x2x17 inch long pieces and loaded the retort.
The cover is 3/16" plate with a bunch of drilled holes and a handle.
I have an old plumber's stove (for melting lead) and I was going to use this as the heat source. After dicking around with it for about 15 minutes, I decided to just use some old pallet wood and build a small fire.
After about 10 minutes, it started to off-gas through the holes in the retort cover.
It was still smoking after the fire went out about 45 minutes later. I fed the fire a little anyway and it was cooking really well for a couple of hours.
The funny thing is, it wasn't really hot. I could touch the top & sides of the retort with a bare hand.
It's been cooking for about 3-1/2 hours now. and I'm letting it do its thing. More tomorrow morning.
1 person likes this
So this morning came and I took a look inside. Sorry, I forgot to photo that. This was an incomplete burn  Some of the pieces were totally done. Nice solid chunks of charcoal that broke easily in your hand, but remained solid and did not turn to powder. It seems the center cooked well, but the perimeter did not. I rmoved some of the more completed product and rearranged so there was a little more space between the pieces.
Then I lit a small fire and let it die out. I took some of the coals and spread them across the top of the wood pile and down in the spaces. It's cooking again.
So to really make this a retort, you need to funnel the off-gases into the burn chamber to fuel it. I find a retort that is uninsulated needs to have flame wrapping all the way around it- so an outer shell will help you here, to contain that flame.
I also find long pieces take a lot longer, so chopping them short will help.
Handiest thing in charcoal making is a little cheap infrared pyrometer- I don't find a good complete charring unless I've seen 600 to 700 degrees F on the exposed surfaces of my retort.
Thanks Lee. I'm hoping to have enough daylight left when I get home to check the results. I was wondering about drilling some holes in the bottom of the mixer barrel. Currently there is just a single hole where the mounting screw connected it to the motor.
So I made it home in time to snap a few pics of the results from the second attempt.
A quick look inside shows a pretty complete (if not slightly over-done) burn out.
And I pulled a piece out of the center area to have a closer look.
So I think this is working well, but if anyone has an opinion, please offer it up.
This last burn took a long time to stop smoking and even after the smoke cleared, the retort was too hot to touch for a few hours. I finally got around to looking inside tonight. The underside of the lid and the inside of the retort is covered in this black gunk. The lid has so much of it that the 5/16" holes have become completely blocked.
I reached in and pulled out one of the 2x2's and it came out in one piece, but it has no density like regular wood.
I snapped off the end and it has these shiny layers running through it. That's a good thing I'm told.
That looks pretty good! Is that pine? I have only done the kiln method, which is working out really well for me. That same black gunk builds up in the chimney of my kiln. I think that it is the sap or some other part of the wood that collects and dries there. Was this batch fully carbonized? I have found that it needs to go low and slow until the very end where it gets really hot, then I seal it up completely.
This is all Douglas fir or pine (SPF) 2 by something that I split into 2x2x17" sticks.
This batch looks like it fully carbonized. Every stick is charred and lightweight from end to end and you can snap it clean with bare hands. It doesn't crumble.
So I changed things up a bit and have been running this every weekend. I now have about 120 pounds of charcoal. Some I have chopped into small pieces, some I have left as they came out of the kettle (I stopped calling it a retort, because it isn't one).
I recently got 50 pounds of black sand (sifted and magnetically screened).
And a quick video of how the stuff handles and breaks.
1 person likes this
That's pine tar. Keep it, it's got many good uses (cutler's pitch) :)
You have me curious now. Mine is very brittle. I've been chucking it into a pile in the yard. How does one make this into a usable substance?
Add some fat or wax to it which removes the brittleness. Then you can add a filler, like charcoal or brick powder.
