Joe kemp 0 Posted February 27, 2017 Share Posted February 27, 2017 Hello, so I'm trying to forge weld some thinner pieces of steel that I have, I do know after spark testing that these pieces have a decent carbon content. I managed to get the metal up to a light orange color while fluxxed. I proceeded to hammer the pieces together at this temp but I could not get the pieces to stick. They were properly cleaned with a grinder before tack welded together. I will add some pictures of the pieces soon. But as for now does anyone have any suggestions or ideas as to why this is not working for me. Also should be noted that I am using a forced air wood forge. Link to post Share on other sites
Brian Dougherty 1,210 Posted February 27, 2017 Share Posted February 27, 2017 Sounds like you might have been too cold. I would describe the welding temp for high carbon steels as a butter yellow. Thin pieces can be hard to weld because they cool down so quickly. (Unless you have a lot of them stacked up to create a big thermal mass) Other than that, there isn't much to go on. The pictures might help. Link to post Share on other sites
Joe kemp 0 Posted February 27, 2017 Author Share Posted February 27, 2017 I was using borax and I had four pieces stacked. 1 minute ago, Brian Dougherty said: Sounds like you might have been too cold. I would describe the welding temp for high carbon steels as a butter yellow. Thin pieces can be hard to weld because they cool down so quickly. (Unless you have a lot of them stacked up to create a big thermal mass) Other than that, there isn't much to go on. The pictures might help. Link to post Share on other sites
Mason Simonet 54 Posted February 27, 2017 Share Posted February 27, 2017 id have to agree with Brian, orange is definitely not hot enough. Link to post Share on other sites
Geoff Keyes 525 Posted February 27, 2017 Share Posted February 27, 2017 There are also some steels that simply won't weld. 5160 is well known for failing to weld to itself. All flux does is keep O2 away from the surface to prevent scale, which will interfere with the welding project. In and of itself, flux won't make the weld happen. Geoff Link to post Share on other sites
Markku 5 Posted February 27, 2017 Share Posted February 27, 2017 I'm just a beginner myself but i have noticed just what Brian said. Its much easier to weld bigger billets. I've had success in coal forge without using flux. I don't think its necessary using solid fuel. Link to post Share on other sites
Joshua States 1,779 Posted February 27, 2017 Share Posted February 27, 2017 Another thing flux does is tell you when the steel is ready to weld. The flux should be visibly bubbling and boiling on the billet surface. If it isn't you are still too cold to weld. Link to post Share on other sites
Brian Dougherty 1,210 Posted February 27, 2017 Share Posted February 27, 2017 (edited) 2 hours ago, Joshua States said: Another thing flux does is tell you when the steel is ready to weld. The flux should be visibly bubbling and boiling on the billet surface. If it isn't you are still too cold to weld. How accurate is this? I've heard this a lot, but the Mule Team Borax I use start bubbling around 2000F in my forge which I always though was too cold to weld with a hammer an anvil. If I have my forge screaming at max gas flow, I can barely reach 2200F. At this point the flux is boiling like mad, but it always feels like it is just marginal to get the weld to take for 1095 and 15N20. I can't really get low carbon stuff to weld reliably at all, so I must be pretty close to the edge of the temperature range. Edited February 27, 2017 by Brian Dougherty Link to post Share on other sites
Jerrod Miller 462 Posted February 27, 2017 Share Posted February 27, 2017 Considering the boiling point of borax (sodium tetraborate) is 2867F, I think it is safe to say none of us that have seen that phenomenon are actually seeing it boil, thus it is a different reaction that we see. As such there is likely to be variables with the atmosphere in the forge (and possibly the surface of the metal) that will be changing the temperature at which it is bubbling. My bet is that it has to do with the water content finally breaking free, so anhydrous borax probably doesn't do this at all. Link to post Share on other sites
Karim 62 Posted February 27, 2017 Share Posted February 27, 2017 usually i see something's happen in the fire or just above it, waiting any longer sparks will fly and the steel s burning. The atmosphere change above the fire is my queue for setting the welds. Of course this is whit coal, maybe anybody can relate this to a gasforge. Link to post Share on other sites
James Higson 83 Posted February 27, 2017 Share Posted February 27, 2017 You are looking for the borax to start 'snowballing' - I was told by the blacksmith who taught me that it's like looking down on a kids snowball fight. Always worked for me and it does kind of look like that! So yeah, it's always at around a high yellow, should be so hot it makes you feel a little queasy looking into it (though you shouldn't be looking into it for too long!) James Link to post Share on other sites
James Higson 83 Posted February 27, 2017 Share Posted February 27, 2017 Also, if you have a long very thin piece (around 0.5mm thick) of bar stock then you can poke the billet with this and at welding it should start to stick just by touching it. Link to post Share on other sites
Joe kemp 0 Posted February 27, 2017 Author Share Posted February 27, 2017 7 hours ago, Brian Dougherty said: Sounds like you might too cold. I would describe the welding temp for high carbon steels as a butter yellow. Thin pieces can be hard to weld because they cool down so quickly. (Unless you have a lot of them stacked up to create a big thermal mass) Other than that, there isn't much to go on. The pictures might help. Here's what ive got as a result. These are just some pieces I have cut out of the overall piece. Link to post Share on other sites
Joshua States 1,779 Posted February 28, 2017 Share Posted February 28, 2017 5 hours ago, Brian Dougherty said: How accurate is this? I've heard this a lot, but the Mule Team Borax I use start bubbling around 2000F in my forge which I always though was too cold to weld with a hammer an anvil. If I have my forge screaming at max gas flow, I can barely reach 2200F. At this point the flux is boiling like mad, but it always feels like it is just marginal to get the weld to take for 1095 and 15N20. I can't really get low carbon stuff to weld reliably at all, so I must be pretty close to the edge of the temperature range. I still have a box of that 20 Mule Team and I have to say it never worked well for me at all. This is the product I use: https://www.knifeandgun.com/ProductDetails.asp?ProductCode=FWF and it never fails. (only I do) It is a very significant effect when the correct temp is reached. At lower temps it will move about and look right, but it's not ready yet. At proper temp it really froths and expands is the best way I can describe it. When I have done this in a forge with a thermocouple and digital readout, it's right around 2450* for Hi-C steel. Low-C steels typically require higher temps to weld. Link to post Share on other sites
Alan Longmire 2,821 Posted February 28, 2017 Share Posted February 28, 2017 Did you have those clamped tight and tack welded? Thin stuff like that is a pain to try and weld unless there's a lot of it and it's as tight as it can get. Link to post Share on other sites
Brian Dougherty 1,210 Posted February 28, 2017 Share Posted February 28, 2017 I'm not sure what to make of the pictures yet. Did you have to grind on the stack to get them apart, or did they just fall apart like that? Link to post Share on other sites
Joe kemp 0 Posted February 28, 2017 Author Share Posted February 28, 2017 27 minutes ago, Brian Dougherty said: I'm not sure what to make of the pictures yet. Did you have to grind on the stack to get them apart, or did they just fall apart like that? Those pieces were originally thicker. About one inch square and were pressed as tight as I could get them with my c clamps. I then proceeded to tack weld each corner once on the middle of each end and three more tacks on the longer edges. After I finished pounding it out I cut off the edges with an angle grinder I ground down the edges to see if the welds stuck but I saw lines on all of the edges. At that point I new none of the welds set. I then pulled the pieces apart and those pieces pictured are the inside edges of the pieces. Before clamping and tacking all pieces were ground clean and flat. Link to post Share on other sites
Alan Longmire 2,821 Posted February 28, 2017 Share Posted February 28, 2017 Between that info and the pictures, you're either using stainless or you were not running nearly hot enough. You should not be able to look directly at the billet for more than a second. Did I miss what steel you have and how thick? Link to post Share on other sites
Joe kemp 0 Posted February 28, 2017 Author Share Posted February 28, 2017 28 minutes ago, Alan Longmire said: Between that info and the pictures, you're either using stainless or you were not running nearly hot enough. You should not be able to look directly at the billet for more than a second. Did I miss what steel you have and how thick? I do know that it is not stainless steel. But heat may be an issue. I have been burning would but I am trying to get some coal instead as it will burn hotter. Trouble is finding a supplier in my area. Link to post Share on other sites
steven smith 101 Posted February 28, 2017 Share Posted February 28, 2017 I can only get my welds to stick if the borax is steaming and I can see the vapors, Just boiling isnt enough, with thin sheet you should add a few extra layers because the outside layers usually dont stick. Link to post Share on other sites
Joe kemp 0 Posted February 28, 2017 Author Share Posted February 28, 2017 I would imagine then that it is the outer layers are losing to much heat too quick then and not maintaining a forge welding temperature? Link to post Share on other sites
James Higson 83 Posted February 28, 2017 Share Posted February 28, 2017 3 hours ago, Joe kemp said: I do know that it is not stainless steel. But heat may be an issue. I have been burning would but I am trying to get some coal instead as it will burn hotter. Trouble is finding a supplier in my area. If I am taking from that that you're burning wood... You're not going to get anywhere near hot enough. Max you can get to is around 600C and you need to be about twice as hot as that. Coal or charcoal is essential. Coal I have always found much easier and you go through a lot less volume of fuel. Link to post Share on other sites
Joe kemp 0 Posted March 1, 2017 Author Share Posted March 1, 2017 Yes I am planning on picking up a bag of charcoal to burn in my forge for the time being as finding a supplier for coal in my area is rather difficult. The nearest supplier is a 30 minute drive from where I am so it's not easy to just make that drive for coal. But sometime soon hopefully I will be able to go there and pick up a big bag of that. Link to post Share on other sites
Alan Longmire 2,821 Posted March 1, 2017 Share Posted March 1, 2017 Keep in mind all coal is not created equal. You want blacksmith's coal, or technically metallurgical grade bituminous, low ash, low sulfur coking coal in stoker size. I can get stove coal easily, but the batch the guy here has is high sulfur high ash and doesn't coke worth a darn. I drive over an hour one way to get the good stuff for forging. It is getting harder to get as well, the last few hundred pounds have been about 5% rocks. If stoker is all you can find it's usually okay, just avoid any with white or yellow spots (sulfur) and be aware some of it is oiled to keep the dust down. This doesn't affect forging, but it makes a huge flame when you light it up and stinks terribly until the oil is gone. Not that unoiled coal smells particularly good, of course. 1 Link to post Share on other sites
owen bush 287 Posted March 1, 2017 Share Posted March 1, 2017 On 27 February 2017 at 10:42 PM, Jerrod Miller said: Considering the boiling point of borax (sodium tetraborate) is 2867F, I think it is safe to say none of us that have seen that phenomenon are actually seeing it boil, thus it is a different reaction that we see. As such there is likely to be variables with the atmosphere in the forge (and possibly the surface of the metal) that will be changing the temperature at which it is bubbling. My bet is that it has to do with the water content finally breaking free, so anhydrous borax probably doesn't do this at all. I weld with anhydrous borax and it still displays this phenomenon, in my experience the bubbling is more vigerous in a rich environment than it is in an oxidising one. to the extent that I would change my gas mix if there was no bubbling. when I weld with borax I look for the "kids running around in a playground" vigourous bubbling that has been mentioned and that the borax is smoking. The colour of the steel is so subjective..... 2 Link to post Share on other sites
