Rasp Axe wip
Rob Toneguzzo
Here is an axe/hawk made from an over size rasp our farrier uses on the heavy horses. Get a good supply of these and they are good USA steel.
A tree fell in a storm on my fence so I thought it was a good oppertunity to test it
Had chainsaw but just could not use it..old school all the way haha..very rewarding!
Held up great on 6 inch trunk.
Awsome for limbing but also cut through thickest part in under 60 seconds..great little axe and fun to use..very rewarding..love making axes.
Any comments/feedback appreciated.
Rob
  • Like 3
Thanks fellas.
Caleb, I did grind them down flat. The rasp was rusty too and I figured the cleaner the better. I usually weld on the other side of a rasp where the teeth are smaller.
I have never made an axe, but I like them. I should probably make myself one like that for use around my home.
I have to finish my machete first, though.
kc
G'day mate!
Outstanding work on the one!! It turned out well!
How wide and long was that rasp when you started, it looks like one of the biggest I have ever seen??
Hi guys, thanks for the feedback.
1 hour ago, C Craft said:
G'day mate!
Hi there CC...the rasp is 50 cm by 6 cm here is a pic next to a standard one.
Edited by Rob Toneguzzo
Gotta git me summa those  !!!..........B)
If ya can't be good don't git caught  !!                                        People who say stuff can't be done need to
        git the hell outta the way of people who do stuff   !!!
Show me a man who is called an expert by his peers
And I will show you a good man to listen to ......
Show me a man who calls himself an expert
and I will show you an egotistical asshole...............!!
Great work Rob. What did you use to shape the eye?
Hi Josh,
I have a tapered Tomahawk drift I have made and I bend the rasp around that.
I knock the drift out then take a second heat.
I then tap the drift back in and with the drift in place I drop the blade in the vice and squeeze the blade together which really pulls the eye tightly around the drift.
I then tap the drift out and do the weld.
Once the weld has taken I again drop the blade in the vice and tap the drift in and true it up. I do this so the eye weld is supported and clamped shut and can't separate.
I then forge out the blade as normal.
This is just how I do it and it works for me.
Thanks kris,
James, i just welded that sucker together and forged it out. Given it (and numerous others like it) a real shelacking and they hold up fine with some pretty heavy work.That being said I intend to forge some bearded style axes and will weld in a center peice to give more material.
Hi Rob,
Clearly this was pre-finger/hand injury. :P --- Hope all turns out well for you today. I know that hospital too well unfortunately.
As for the Axe. Nice. Where do you source your rasp's from? I wonder if I can scrounge some up down here somewhere?
Cheers,
Chris.
I get them from our farrier. Not sure where he gets them from though. Most farriers i have met are happy to give them to you. I just always test them as some are just case hardened.
Here is another comparison  between a standard and large rasp axe.
On another note I rub the raven oil leather dye on the handle before boiled linseed oil. Brings out the grain and and gives an ok effect i think.
On ‎3‎/‎5‎/‎2017 at 1:47 AM, Rob Toneguzzo said:
Hi Josh,
Edited to add: What is Raven Oil?
I think your idea of holding the eye in a vise after the weld for some later work is brilliant. I think I saw that done during one of James Austin's vids. Either way, it is a smart trick. The finished products look very nice.
Hi Kevin,
Raven oil is the dye I use to colour the leather sheaths. I have black and brown. I rubbed some on a handle by accident one day and when I wiped it off it had stained the grain so I just did it all over. Kept some of the natural wood colour and darkened some grain highlights. I would not do it on everything but it looked OK on the axe handles.
Very nice piece, it is inspiring!
Please come and waste some otherwise perfectly good time, looking at my knives!
www.prometheanknives.com
