• Announcements
    • Alan Longmire
Followers 0
Matthew Mafera
Veneer scabbard for a long sword?
2 posts in this topic
I know a common (and I believe historical) way to make scabbards is to laminate several sheets of wood veneer together around the blade. Would this ever be done for a long sword? I've only really seen it done for daggers but I would assume it would be the same construction for a larger sword.
As far as I know, but I'm no real expert, this method was indeed used on medieval sword scabbards, using thin veneers of bent wood to create a very slim and light scabbard. Because the scabbards were covered in cloth or leather applied with animal glue, this creates a form of composite which is stronger than the thin walls would suggest.
It also would be faster to make a scabbard this way instead of carving from a block of wood and easier to make a well fitted slender shape.
This thread by the expert on this subject, Peter Johnsson, shows the process of making such an historically accurate scabbard for a dagger, but i'm shure it would work for a sword from the same time period:
Guest
You are commenting as a guest. If you have an account, please sign in.
Reply to this topic...
×   You have pasted content with formatting.   Remove formatting
  Only 75 emoticons maximum are allowed.
Loading...
Followers 0
