No anvil for now
Rexs
I broke my crappy first anvil , it was a chunk of rail way cast iron and my forge at the moment isn't up to my standard of heat out put so I have to stick with just plain stock removal at the moment which is proving to be tedious lol these are cut out if 1095 cra, I heat treated them since they are thin I I used motor oil to quench and then in the oven at 440 for an hour , I should have done two separate hours but only did the one , the mini chef knife was still so hard a new file would barely scratch the tip ! I worked out the scratches with 220 wet dry sand paper , and polished up some with wet 500 grit , next I'm going to use a wedge handle on the chef and a bocote for the mini hunter more pics to come later
