Salem Straub 168 Posted April 2, 2017 Share Posted April 2, 2017 (edited) Stainless/carbon damascus san mai keyhole integral fighter with desert ironwood. Sorry for the dang phone video, I'm a little short on production time right now! Edited April 2, 2017 by Salem Straub Link to post Share on other sites
Wes Detrick 488 Posted April 2, 2017 Share Posted April 2, 2017 Beautiful work Salem! I love the san mai with stainless and damascus! Link to post Share on other sites
Wesley Alberson 138 Posted April 2, 2017 Share Posted April 2, 2017 I love it! Link to post Share on other sites
Dave Stephens 428 Posted April 3, 2017 Share Posted April 3, 2017 Damn dude! You are doing some seriously impressive work lately. Do you sleep?! The quality + quantity of your work lately is pretty intense. Respect, man. Dave Link to post Share on other sites
jheinen 41 Posted April 3, 2017 Share Posted April 3, 2017 Stunning work! Link to post Share on other sites
Joshua States 1,782 Posted April 3, 2017 Share Posted April 3, 2017 Purdy, real purdy. Nice drum solo too! Link to post Share on other sites
Chris C-S 148 Posted April 3, 2017 Share Posted April 3, 2017 ^ What they said and more. That is fantastic work. Well done. How did you do the bolt through tang? I am assuming you have threaded somewhere on the bolster and fed the bolt in after handle assemble? Link to post Share on other sites
Salem Straub 168 Posted April 3, 2017 Author Share Posted April 3, 2017 Chris, the keyhole is cut into the bolster, then a blind hole is drilled and tapped in the front of the keyhole, towards the blade. It's all marked out so the bolt hole intersects with it. I've pressed the block back out, drilled it and re-pressed it in, which works, though on this one I marked it out accurately enough to carefully drill a 1/4" bolt hole all the way through the grip to meet the drilled/tapped bolster hole. Took a little fussing at the end. The bolt head is covered by an african blackwood plug. 1 Link to post Share on other sites
Clifford Brewer 372 Posted April 3, 2017 Share Posted April 3, 2017 More good chit as usual dude......... Link to post Share on other sites
Chris C-S 148 Posted April 3, 2017 Share Posted April 3, 2017 1 hour ago, Salem Straub said: Chris, the keyhole is cut into the bolster, then a blind hole is drilled and tapped in the front of the keyhole, towards the blade. It's all marked out so the bolt hole intersects with it. I've pressed the block back out, drilled it and re-pressed it in, which works, though on this one I marked it out accurately enough to carefully drill a 1/4" bolt hole all the way through the grip to meet the drilled/tapped bolster hole. Took a little fussing at the end. The bolt head is covered by an african blackwood plug. I am eons away from doing something like this, however the wood worker in me loves the keyhole (odd shaped dovetail) fit. Well done. Thanks for explaining it. Link to post Share on other sites
Kenneth Mauldin 16 Posted April 3, 2017 Share Posted April 3, 2017 Beautiful man, can't see the glue line on the vid.That damascus san mai is killer. 1 Link to post Share on other sites
