Nflanders Posted April 3, 2017 Share Posted April 3, 2017 Good afternoon, this may sound like a stupid question, but does anyone use brake lines to run propane for their forges? I found a set of burners for sale on ebay, but he says to use brake lines to run the propane... Link to comment Share on other sites More sharing options...
Brian Madigan Posted April 3, 2017 Share Posted April 3, 2017 By brake lines I'm assuming he means hard lines. I use copper or copper-nickel. Copper nickel or cupronickel are the ones used for hard lines in cars. There's no problem using copper or copper nickel lines as long as they are not subject to a lot of bending. They're not meant to be flexible lines. If you keep bending them back and forth, they'll get a kink and will crack or break. This is probably not an issue in a stationary forge. Just be careful if you have to bend them not to overdo it. Mine are 3/16" lines soldered to brass fittings. As always, check propane fittings for leaks. Link to comment Share on other sites More sharing options...
Nflanders Posted April 3, 2017 Author Share Posted April 3, 2017 his listing ( and after asking him ) he said that he literally uses brake lines to run his propane, he said to buy a 1/4" inverted flare line from an auto parts store. Would it make sense to get 1/4" copper line, and flare it/ solder it instead? Link to comment Share on other sites More sharing options...
GBrackett Posted April 3, 2017 Share Posted April 3, 2017 (edited) Lines from a propane company are not that high in price and last as they are design for the job. Edited April 3, 2017 by GBrackett ”Whoever pursues righteousness and love finds life, prosperity, and honor!” George Brackett American Bladesmith's Society, Apprentice Member Hialeah, Florida Link to comment Share on other sites More sharing options...
Joshua States Posted April 5, 2017 Share Posted April 5, 2017 (edited) How about something that is actually manufactured for the specific purpose? http://www.homedepot.com/p/BrassCraft-ProCoat-1-2-in-MIP-x-1-2-in-MIP-x-48-in-Stainless-Steel-Gas-Connector-5-8-in-O-D-106-000-BTU-CSSC44-48-X5/100138397 these also come in 3/8 inch diameter (ID) http://www.homedepot.com/p/ProCoat-1-2-in-FIP-x-1-2-in-MIP-x-36-in-Stainless-Steel-Gas-Connector-1-2-in-O-D-71-100-BTU-CSSD54-36-X/100161743 Edited April 5, 2017 by Joshua States “So I'm lightin' out for the territory, ahead of the scared and the weak and the mean spirited, because Aunt Sally is fixin’ to adopt me and civilize me, and I can't stand it. I've been there before.” The only bad experience is the one from which you learn nothing. Josh http://www.dosgatosdesignsllc.com/#! https://www.youtube.com/channel/UCdJMFMqnbLYqv965xd64vYg J.States Bladesmith | Facebook https://www.facebook.com/dos.gatos.71 https://www.etsy.com/shop/JStatesBladesmith Link to comment Share on other sites More sharing options...
Nflanders Posted April 5, 2017 Author Share Posted April 5, 2017 That's the plan, I'll have to check out the connectors when they show up Friday, and work from there, I'd like to set up a shut-off so that I can run a single burner. Link to comment Share on other sites More sharing options...
AndrewB Posted July 12, 2018 Share Posted July 12, 2018 On 4/3/2017 at 1:07 PM, Nflanders said: Good afternoon, this may sound like a stupid question, but does anyone use brake lines to run propane for their forges? I found a set of burners for sale on ebay, but he says to use brake lines to run the propane... That's just dangerous I would advise against it. You can get a good 4 foot propane hose for under 20 bucks. In some stores. Link to comment Share on other sites More sharing options...
Alan Longmire Posted July 12, 2018 Share Posted July 12, 2018 Actually, seamless copper tubing is the best for gas lines around forges. Think about it: propane hose is easily meltable rubber. You just have to get comfortable with compression fittings to use copper. Link to comment Share on other sites More sharing options...
Mike Jesensky Posted November 20, 2019 Share Posted November 20, 2019 I came here looking for what some guys are using for a connect to their tanks and I see a recommendation for the yellow dryer hookup from home depot,these are made for up to 5 PSI,I tried them before and in my case I kept smelling gas at times ,it didn't bubble soapy water,and it didnt get past 1700 degrees and the yellow flex tube wouldnt let me get more gas.If you want to get a flex line and you use anything other than a low pressure regulator I would make sure all parts of your line are rated for high pressure or soldered hard lines Link to comment Share on other sites More sharing options...
Doug Lester Posted November 21, 2019 Share Posted November 21, 2019 Wayne Coe and High Temperature Tools and Refractory both carry the the connections you need to go between the propane tank and the brass nipple for the injection tube. The set ups come with the POL fitting to hook up the regulator to the propane tank and the regulator. No guessing if they'll work, they will. Doug HELP...I'm a twenty year old trapped in the body of an old man!!! Link to comment Share on other sites More sharing options...
Joshua States Posted January 3, 2020 Share Posted January 3, 2020 On 11/20/2019 at 12:54 PM, Mike Jesensky said: I see a recommendation for the yellow dryer hookup from home depot,these are made for up to 5 PSI CSST (corrugated stainless steel tubing) gas lines like this one, are rated to 37 psi operating pressure. I don't think I have ever run either of my forges above 8 psi. “So I'm lightin' out for the territory, ahead of the scared and the weak and the mean spirited, because Aunt Sally is fixin’ to adopt me and civilize me, and I can't stand it. I've been there before.” The only bad experience is the one from which you learn nothing. Josh http://www.dosgatosdesignsllc.com/#! https://www.youtube.com/channel/UCdJMFMqnbLYqv965xd64vYg J.States Bladesmith | Facebook https://www.facebook.com/dos.gatos.71 https://www.etsy.com/shop/JStatesBladesmith Link to comment Share on other sites More sharing options...
