Jeremy Blohm 573 Posted April 5, 2017 Share Posted April 5, 2017 (edited) So i have been looking around on the internet for info on people using a weed burner/roofing torch for there forge and people have been but with terrible results. I figured it out and decided to share with everyone here since nobody has shared there discovery if anyone has actually done this. First off you need a harbor freight roofing/weed burning torch. But you need the one without the igniter or anything similar that the bell/burner can be screwed off. 1 1/4 pipe 12 inches long. Threaded on one end. 1 1/4-2 inch bell reducer. 1 inch wide flat stock. Tools include a drill, welder, 5/8 drill bit, grinder with grinding wheel So here comes the difficult part. Cut the flat stock the width of the 2 inch end of the bell reducer. Drill your 5/8 hole dead center in the flat stock. Grind some off the sides of the flat stock to make for more air flow. Weld the flat stock to the 2 inch end of the bell reducer with the hole directly over the center. Now screw the bell reducer to the 1 1/4 pipe and the burner is complete. The flat stock can be drilled and tapped into the sides of the bell reducer if you dont have access to a welder. And the flat stock can be drilled and tapped for the weed burner to screw into. But these are all things that can be improved upon. It works perfect the way i have it set up. Now all i did was set up a post next to the forge so you can zip tie the hose if the weed burner to it and with the end off the weed burner set it in the hole of the flat stock pionted directly down the burner pipe. This is basically the same concept as the Ron Reil burner just uses different parts. I happend apon this design by chance. One day i was in the mood for a change and i wanted to make the big transition from coal to propane so i did my research and found a burner i liked. So i go to the hardware store and i get to the pipe fittings and the shelves are almost bare. The wheels started turning. So i gather an arm full of stuff and decide i will start tinkering. Well nothing was going right from grabbing wrong size fittings to drilling offset holes. So i started getting frustrated. I start going through all the drawers in the shop looking for all kinds of stuff i know we dont have. Thats when i looked up and seen the torch hanging on the wall. The wheels started turning again. Anyways it wasnt more than an hour later i had a functioning burner. I will get pictures of everything and post in a day or two!!! Edited April 6, 2017 by Jeremy Blohm Link to post Share on other sites
Jeremy Blohm 573 Posted April 9, 2017 Author Share Posted April 9, 2017 So i got pictures of everything and now i cant figure out how to upload here from the gallery on my phone. Any help wiuld be appreciated. Otherwise i will attempt to post pictures directly from the camera. Link to post Share on other sites
Alan Longmire 3,674 Posted April 9, 2017 Share Posted April 9, 2017 I find it much easier to download pics to a desktop, edit for size and contrast, then add them to the post. Then again I am on the older side of tech stuff. I also don't care for the new forum software, makes it much harder to do stuff with a phone. I am interested in seeing how you solved the backpressure issue those burners have. Link to post Share on other sites
Jeremy Blohm 573 Posted April 10, 2017 Author Share Posted April 10, 2017 Ok i tried posting pictures directly from the camera and no luck. I will take it to the library and upload from there or I will make a YouTube video and post a link. Sorry for taking so long to post pictures but i have been a so occupied with building my power hammer I've lost sight of everything else. I will start another topic on that if i can figure out how to post pictures. Link to post Share on other sites
Jeremy Blohm 573 Posted April 10, 2017 Author Share Posted April 10, 2017 Link to post Share on other sites
Alan Longmire 3,674 Posted April 10, 2017 Share Posted April 10, 2017 Ah, gotcha. Basically a standard venturi burner, but using the torch orifice instead of the usual MIG tip. Are you using a regulator, or just the needle valve on the torch handle? Link to post Share on other sites
Jeremy Blohm 573 Posted April 10, 2017 Author Share Posted April 10, 2017 Yes sir. I am not using a regulator just the needle valve on the torch. And this burner set up is fully capable of welding also. I have welded several times with it and had no trouble getting to temperature as long as you are hooked up to a 100lb cylinder or have a full 20lb and even then you are sucking so much from the tank it starts to frost and you have a huge loss in pressure when that happens. Link to post Share on other sites
Brian Madigan 20 Posted May 5, 2017 Share Posted May 5, 2017 I use 2x20 lb tanks in parallel, feeding a single 1" atmospheric burner that fires in from the bottom. I rigged up copper tubing to 'parallelize' the fuel delivery, which gives you a lot more flow at the orifice end without icing the tanks. Even with a 100lb tank by itself icing was a problem. I tend to run the thing very rich to reduce scale and the need for flux. You can get something like this for a multi-tank setup: https://www.amazon.com/Mr-Heater-Hook-Up-30-Inch-Assembly/dp/B000K287CG Link to post Share on other sites
