Badly designed charcoal forge
OK I had a look at my charcoal forge just now after it had cooled off and I have noticed a serious design flaw. Namely no way to clean ash that drops in the air pipe. On the plus side the charcoal I use isn't leaving huge clinkers. Only a handful after a full days work. Any tips on a work around for the ash problem would be appreciated. So far it seems to mostly be filling the gaps between the hebel bricks and acting as extra refractory.
Most folks using that design just unscrew the end cap and blow out the ash, or push it out with a rag on a stick.  Charcoal ash is pretty light, it shouldn't give you much problem with getting into the pipe to begin with.  I mean yes, some will always get in there, but it shouldn't be enough to cause problems.
Can you drill the end of it at the forge end and thread it for a bolt, then you can take the bolt out and put the air hose in to blow any ash out through the elbow that you would unscrew.
Edited by Garry Keown
