Edge geometry and sharpening a convex edge
Devon
Hey Guys,
Really new to blade making and i am chasing a bit of advice. I'm making a knife with a convex edge and i seem to be having a lot of trouble sharpening it. I guess the question how long should it take me/ how to i know when the edge is sharp/fine enough to move on to a finer grit sandpaper. I am working on the edge with 180grit wet and dry wrapped around some leather. I just have no idea how sharp/fine I should be able to get it and how to test it before moving to a finer grit. Any help here would be greatly appreciated.
Thanks
Geometry is based on the angle and the angle is based on thickness from spine to edge.
So if the spine is 3/16 and your edge before sharpening is .01 there will be a corresponding angle.
I generally am more concerned with edge thickness before sharpening than the angle.
So a work knife I will sharpen between .01-.008.
Get a digital micrometer.
Then when you are at thickness put a secondary bevel on and sand/polish to a desired grit.
220 will be toothy.
600 will be more razor like though both will shave hair.
