Question about tempering my blade
Hi I have just quenched my blade and I need to temper it but all the methods I seem to find are to whack it in 300 C heat for a couple hours. I am just wondering if there is another way because that uses a bunch of propane. I have heard about watching the colour of the steel and the spine turning blue and the blade turning into a wheat colour. Just wondering about suggestions and also if the colour method works do I have to heat the metal up for a couple hours still thanks.
Most folks use a toaster oven set at 350-450 F, depending the steel. The torch method (watching the colors) is to use a torch to heat up the spine and watch the colors. It's pretty unreliable however and not very precise. 300 C is awfully hot, most steels require temperatures between 180 and 230 Celsius.
Trying to make each knife just a little better than the last
The toaster oven I use is electric, very cheap, and seems to work well! The temperature indicated on the controls is wildly inaccurate, but you can fit a "K" type thermocouple to measure the temperature accurately for not much money!
bob
1 hour ago, dragoncutlery said:
full size oven if you clean the blade good first you can make dinner at the same time
I'm glad I'm not the only one who has done this :)
-Brian
  • 3 weeks later...
