jheinen 41 Posted May 25, 2017 Share Posted May 25, 2017 Apparently nickel silver is hard to drill? I tried drilling 1/8" pin holes in a 1/4" thick bolster, and ruined a bit on the first hole. Is there a particular bit or technique I should be using? I was using a regular bit in my drill press with cutting oil. I didn't get the typical curls of metal like I do when drilling steel, just pieces of ground up metal. Link to post Share on other sites
ScottWright 16 Posted May 25, 2017 Share Posted May 25, 2017 Not sure about with nickel silver but I know with some other non ferrous metals, in particular copper, drilling with oil usually jams your bit with material and overheats them. Dry drilling it dry and at slow speed next time. Link to post Share on other sites
Alex Middleton 529 Posted May 25, 2017 Share Posted May 25, 2017 I don't have any experience with nickel silver specifically, but when I'm dealing with hard material I will use a carbide end mill to drill my holes with. Any machinists on this forum will cringe if they imagine an end mill chucked up in a drill press, but as long as you don't have any significant run-out in the spindle of your drill press, it works great. Link to post Share on other sites
Brian Dougherty 1,210 Posted May 25, 2017 Share Posted May 25, 2017 (edited) Nickel silver drills pretty much like brass in my experience. It can be a little gummy, and can clog drills, but I wouldn't say it was hard by any stretch. Not using cutting fluid and a slow drill speed, as Scott said, are good advice. Nickel can be very hard. You didn't get a hold of pure nickel by chance did you? Edited May 25, 2017 by Brian Dougherty Link to post Share on other sites
Dan Bourlotos 26 Posted May 25, 2017 Share Posted May 25, 2017 Nickel is very soft by itself, and nickel silver should also be soft. I just follow the same technique I use with copper and brass: wd-40 and slow drilling speed. I usually bust bits because I'm drilling too fast. Link to post Share on other sites
Brian Dougherty 1,210 Posted May 25, 2017 Share Posted May 25, 2017 54 minutes ago, Dan Bourlotos said: Nickel is very soft by itself, and nickel silver should also be soft. I just follow the same technique I use with copper and brass: wd-40 and slow drilling speed. I usually bust bits because I'm drilling too fast. Hmm, I have some pure nickle sheet that I use for electroplating, and it is very hard to cut. However, it probably work hardens like copper does since it also has a body centered cubic crystal structure. It may be that the sheet I have is just very hard because of the rolling process... Link to post Share on other sites
jheinen 41 Posted May 25, 2017 Author Share Posted May 25, 2017 I'm drilling at 290 RPM. Is that slow enough? Also, should I use a cobalt bit? I'm hesitant to use my expensive bits. Link to post Share on other sites
Al Massey 65 Posted May 25, 2017 Share Posted May 25, 2017 There's no way NS should be so hard you need cobalt bits. Try heating it to a dull red, then let it air-cool. Link to post Share on other sites
jheinen 41 Posted May 25, 2017 Author Share Posted May 25, 2017 Heating it up did the trick. Thanks! Link to post Share on other sites
Dan Bourlotos 26 Posted May 26, 2017 Share Posted May 26, 2017 22 hours ago, Brian Dougherty said: Hmm, I have some pure nickle sheet that I use for electroplating, and it is very hard to cut. However, it probably work hardens like copper does since it also has a body centered cubic crystal structure. It may be that the sheet I have is just very hard because of the rolling process... If I remember correctly, fcc has a higher work hardening constant than bcc. The atomic packing factor is higher in fcc, and that half atom on the faces likely increases the energy required to form dislocations in the structure. But yeah, both copper and nickel are fcc, and work harden super easily. Link to post Share on other sites
Brian Dougherty 1,210 Posted May 26, 2017 Share Posted May 26, 2017 6 minutes ago, Dan Bourlotos said: If I remember correctly, fcc has a higher work hardening constant than bcc. The atomic packing factor is higher in fcc, and that half atom on the faces likely increases the energy required to form dislocations in the structure. But yeah, both copper and nickel are fcc, and work harden super easily. Yep, I stand corrected. You promoted me to go look it up, and my memory was wrong. (Seems to happen more and more often) I would have sworn that coinable metals were BCC! Link to post Share on other sites
